Hello))
perhaps someone can please explain the value of each proposal briefly.
a lot of R. to understand there are:
1.presentation is extremely significant information individually. In other words, the semantic effect must be associated with personal characteristics of the subject and associated with his specific affective formations (dominating motives, etc.).
if possible give an example of such a text-suggestion to achieve a goal man
4. A high level of stress. Preferably stresseraser factor was itself a semantic impact. May also be used semantician nociceptive stimulus.--what does it mean?
5) presentation of information on an unconscious level, for example, by using masking, disparatado or dichotic input.
6. the presentation of the key touch information to enable actualization implantiruete engrams. Need to present a fixed frequency (element ASPS-II) during the whole procedure, including the existence and gemopoeticescoy hypnagogic state, so that the key signal was recorded in conscious memory areas.--
with what frequency?
7. The action of non-specific connector (element ASPS) to accelerate the consolidation of engrams. It is preferable to use well-studied in this respect, the drug - etimizol.
question suggestions
Re: question for suggestions
"If something is not clear, - scratched his head. If still not understand then, and don't try". (Kozma Prutkov)
