AT5, AT8 not social continued at
АТ5 is a new extension for use on a phone linked to an overall system.
This extension of the new generation, integrating with PCs and therefore are particularly powerful (and also uses completely non-standard algorithms).
key tasks:
-aid the normal operation of the phone even in anomalous zones where it is not always possible
-utilization of radiation for the needs of the operator (processing)
-the ability to connect the energy of personal peace in the presence of PC and small PC experience
-as in the case of at - the possibility to configure (via mental commands or files on the memory card) of various other products, but rasshirenie on the PC (this is a separate post later), I mean regular at-AT2 will not cope with the task of working with PC
-the principle of communication between different probabilistic branches and even different worlds.
the main feature - a HUGE energy potential and the partial effect of the local stabilizer shown properties of PC can be used on any wearable or fixed electronics, but a lot more efficiently and on the means of communication. You can use more than 1pc simultaneously (power increases more than proportionately),
the cost of 55.
As I recall, at the moment there are 30% off for a couple АТ5
Re: AT5 -not social continued social.art.At
At (and its component in the AT2 have a tendency to build some kind of network, with clones (copies) fall under the control of the new operator (the harmonious "Capture the territory", but the increase in "population" at - goes.)
And АТ5 this principle is made somewhat more noisy way - i.e. the process goes, but it's a different network and the appearance of copies is much higher, plus due to the structures TO elementy network can show features of AI and engage in the process.
In my area, the operator receives due to the "spread"virtual ат5 special advantages other axis of control (like approach on the other hand). This is a story "about the scrap" as it is known without the other scrap no reception
Since a number of aspects of society savetodatabase in BMI the body many are called "parasite", sometimes you have to use the technique of building scrap.
Due to inter-probability of penetration (the ability to work in different branches at the same time) ат5 has a very good and unusual point of support for operator actions.
All this post... on good it is necessary to remove
Just unfortunately, at least among users and there are those who may like to read the articles yourself, but there are too few (so far) has in this case to explain in the forehead.
Do I understand correctly that with AMB, АТ5 will become even more effective in assuring the direction of?Михаил_ wrote:opportunities to work at different branches at the same time
probably Yes, although what does the AMB
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
1) АТ5 is an extension of BJ? Or can run without BJ?
2) АТ5 can work on the phone that does not have AT1 and AT2?
3) If your phone has AT1 and AT2, as it will affect the work АТ5?
4) There is a range of products Ax (AD, Keys and doors, Clock, etc.), they are extensions AT. Question: this range of products to be an extension АТ5 for someone who is AT1? Probably АТ5 cannot serve as a basis for the SOCIAL extension because on its own is not social?
1. no, an auxiliary device, such as amplifier and stabilizer. АТ5 is a subset of PC, specialized narrow version.
2.Yes
3.no
4.maybe, but not quite. The energy source can be a base. The vector of from the products out the other (not society), but to feed the social. extensions can.
2.Yes
3.no
Yes, the side "opportunity" ат5 - ability to develop gain control over electronics.
At-5 is an interesting thing. Something similar to PC , but not it. If you take the analogy of a computer ,many of Windows, which clogged the various programmes.I mean the PC . And then there's the channels from each window and branched , multiply like network . The web is such a "world" or universally)))))))))).
Monitor the following. While lying at-5 , such as the actions and sensations from him no special. Take it in your hand you immediately feel the density. The ball at the beginning of a little in hand there, then quickly expands, condenses, becomes heavier. Turns into a big,tight ball , which a lot of vectors. And they are multiplying. How it works on the phone don't know yet, its not. In contrast to the at and AT2 -very powerful and very different in structure.
just what was done to the PC is like toys to kids was posarelli (in a good way)and become at least a little bit to realize itself in the terms of the creative units in the world.
And a number of new pieces - it's adult toys
In fact, further more there is no reference to the phone itself, that is, the means of communication. Otherwise specified reference to electronics, such as energy. And if you attach to a separate battery or a spare cell charged and in your pocket. To society through your phone is still not bindable, bindable to a source of power, and the battery will be more powerful. (The question is that was asked in a previous thread - the phone I was very uncomfortable, nowhere to glue, except that the phone itself is finally to change... and thanks for thatМихаил_ wrote:-help with the normal operation of the phone even in anomalous zones where it is not always possible
yet it is not a sticker on the battery, and what is put on the phone. Phone the means emitting and receiving signals that creates anomalies around, which (also) operates АТ5.
No phone would work too, and AKB did not need, I can thumb the keys hang (hole to drill is possible, nothing is damaged). But better on the phone.
And the reference is not to society but to the networks.
Clear. I think the new phone a decent solution for the money compared to at it is sanity. (And drilling Your artifacts really blasphemy).
Somewhere earlier I wrote about the fact that you can on the notebook-tablet. On the cover or on the battery? If you consider the laptop as a separate entity and not a bunch of batteries and screen, you probably can on the cover. I'm with my laptop half a day or more, such work. But with them not because I don't wear. Tell, pliz. As this is integration with the networks? Wifi? The social network-classmates? Or remote attunement with the pair on the phone. And anyway, if a couple, probably better on different devices, instead of one? Thank you.
a couple can be on different laptop better cover integration with networking in a global sense (data transfer of all types).
Michael_ And discount on АТ5 still how long? Until may 10?
And what is written there in the discounts? I do not remember, but it seems so....
For missing physically on the spot, as I understand it (though better of course to consult with the office), it is a normal scenario is to place an order and pay in return.... generally, I month actually discounts laid... let alone...
You wrote about all the discounts that they generally until may 10. Just decided to concretet it is for a new product
Thank you
Yes, all the discounts of up to one date and ат5 too
Stuck now on the back of the iPhone two pieces at 5
To glue on the cover was not an option, look not beautiful
After the case ( I recommend the girls Michael Kors Wallet Clutch case for iPhone partmone )
was pulled all the metal plates AW, AC,AP, Svetlitsa, ekonorm
case safely fastened.
Gluing is better at 5 on the top and bottom of the iPhone , placing the pads horizontally to clasp in the middle of the cover is well fastened.
Outside cover guys at this obkleivat looks weird to say the least:)
When prying from the case it is better not to pull out:)
About the case - understand
and on the merits of the work ат5 first impressions that is?
Nope, still no impressions.
At lunch today, only glued. It is felt that hoo as moshnenko:)
Michael can affect the performance of АТ5 his picture on display,while the product from the user,and photos in the forum?
1. no, it can't.
2. usually photos get my personal products, or products falling into the hands of office staff, exceptions are extremely rare.
First on the left in the photo is exactly my learned pattern and the characteristic bubbles under the plastic
