Comb - Cosmos®
Done in stickers a comb, size 3.5 x 1.5 cm
In Your hands is an amazing invention – the embodiment of fabulous legends, backed by modern technology.
Comb – Cosmos® is no ordinary comb. It is primarily a tool for creating JOY good mood and structuring thoughts. Using a Comb – Cosmos®, You new organize your life, your thinking, realize your desires and building yourself a happy Future is Bright.
The feeling of joy has always been associated with sunlight. The more light the person went, the more joy. (Starosel. "RA" is the light of the sun, "ven" - wealth, to get).Device Cosmos, placed on the comb, massage brush, you can restore the hair structure, reinforcing the natural connection with the Cosmos.
The accepted idea of combing hair is now forever changed. Now brushing is a creative act, and the comb – a tool of the Creator, the painter's brush or poet's pen.
Use a Comb – Cosmos to strengthen your visual Perception. Device Cosmos can be combed and thoughts! Your thoughts will decrease confusion and increase order. Faster will be new, fresh ideas, decrease fears and complexes.
Device "Cosmos" when "combing thoughts" enhances analytical skills, allowing you to see the structure and "raguenet" where before it had no shades and all was uniform and gray. Hence new possibilities of synthesis, discovery and creativity.
With the help of "Cosmos" can "comb" the light of the meridians of the whole body and not just the head, separating the "stuck time" in the organs and systems, removing violations and congestion.
My dream is to live successfully and feel happy? Must be constructively creative and to think constructively. Structure your thoughts, one begins to form a realization of their dreams directed. Well-directed plan is implemented faster and more efficiently.
Comb Cosmos® will help You to quickly solve tasks that You set for yourself, comb tangled thoughts and give a clear understanding.
instruction:
* Be calm.
* Make smooth movements with your comb, gently brush and massage the skin. head Imagine Your hair in the form of luminous filaments.
* Touch of the comb should be smooth and soft. Do not tear, do not wrap hair comb. The movement should be coherent, whole.
* (You can use a comb – Cosmos® not only for combing heads ,but also to massage other parts of the body – neck, shoulders, back).
* Imagine your thoughts flow in the form of light, as You using a comb – Cosmos unravel them, like hair, are combined in strong light rays and directed in the desired direction.
* For a while, you can leave a comb in your hair, close your eyes, concentrate on the sensations and images in the mind. You may find in them a hint or a straight answer, if You are concerned about any issue. Your thoughts that You have configured and reinforced comb – Cosmos® can now manifest in a visual way.
* Continuous heavy use of a comb – Cosmos® reinforces the effect of a stable mental activity
* Cosmetic effect combs Cosmos® hair look healthier, richer color.<
Re: Device Cosmos
A hairdresser can use in your work?
Re: Device Cosmos
Can! Hairdresser will thus not only the Creator of the hairstyle, creating beauty out of the hair, but will become a Creator of beauty of thoughts of the client and his JOY.ВитЗлат wrote:And the hairdresser can use in your work?
Re: Device Cosmos
Hello! This sticker can then another comb to perekleit or not? (I mean, can it be without puregene to peel off, and stick it on another surface?)
Петр Петрович
Re: Device Cosmos
And the gray Cosmos can remove?
Re: Device Cosmos
If glued by a glue layer of the product, the plywood is not subject. If you want to glue in the future, it is better to glue with tape.Муза wrote:Hello! This sticker can then another comb to perekleit or not? (I mean, can it be without puregene to peel off, and stick it on another surface?)
Re: Device Cosmos
Very pleasant feeling of use. It's like an energy shower head, soft warm jets. Liked. Thank you!
Re: Device Cosmos
Good day! Pleasant sensations.
Tell me, and if massage comb with back mirror, can it be glued?
Thank you.
Thank you.
Re: Device Cosmos
Can. Sticker forms the structure throughout the massage comb and mirror-like surface on it almost has no effect.ВитЗлат wrote:good Day! Pleasant sensations.
Thank you.
Re: Device Cosmos
From what her letters are odd, not "space", and Abracadabra what is this on purpose?АСД wrote:Sticker
Re: Device Cosmos
Cosmos - a Greek word, so I wrote it in Greek.Акела wrote:From what her letters are odd, not "space", and Abracadabra what is this on purpose?
Re: Device Cosmos
That's awesome!!! Here is the thing, slept like a baby! I did not expect from such a small, but proud products of this work!АСД wrote:Cosmos - a Greek word, so I wrote it in Greek.Акела wrote:From what her letters are odd, not "space", and Abracadabra what is this on purpose?
SPA-SI-BO!!!
Re: Device Cosmos
Good thing, the only reason it was now divided from combs and lost
Re: Device Cosmos
Today experienced SPACE at home.
(didn't say should be
All felt! - acts! (myself not writing, because the placebo effect ...)
And put without taking anything on a double-sided tape to the comb, and the top transparent piece of tape to stick.
PS - just remembered that in some salons-hairdressing combs have a similar effect (I'm serious!)
Soothes was in "combat" condition - child on extra classes go...
THANK you!
PSS - my wife said - I would have combed and combed... then called from work and said that it removes bad thoughts.
THANK you!
Re: Device Cosmos
Hairdressers are affected by the procedure itself and the hairdresser. Not every hairdresser can do this. Therefore, in ancient times people trusted to cut hair is not accidental masters. Some didn't trust anyone to not break connection with the Cosmos.АндрейКо wrote:Today experienced SPACE at home.
(didn't say should be)
THANK you!
A small Supplement.
1. Do not stop the comb at the border of the physical body, bring her on, representing their light fibers as a continuation (hair, hands, feet, body).
2. The solution to the problems. Imagine your problem in a tangled ball of luminous fibers, and try to feel the area in the body where concentrated tension from this problem. Brush light fibers in this region. Imagine the reduced confusion of light fibers and feel the reduction of tension in the body or the soul. Repeat periodically until the complete disappearance of feelings of stress. Contact combs with the body can be different from a dense and strong, to feather-light and weightless, depending on the needs and personal feelings.
Re: Device Cosmos
Yesterday I received the Space.
Wonderful vesch!
Came home from work tired and "not in the spirit of" having a headache.
Immediately stuck the sticker - well, that's interesting! Began combing the hair, and the hand itself stretches to keep moving further, further. I read the recommendations of Sergei Dinovich, so you need to act, but "on the machine"
Loved it! The head is not gone, but better. I'll keep looking (honestly - bought for cosmetic effect), but watching will be something, and besides
Thank you to the employees of the office as a gift and put the sticker WAY. Very nice
Wonderful vesch!
Re: Device Cosmos
It is possible to know - how is Space depicted in 1 message from the gradient blue shading with the words COSMOS (instead of the first On - icon)?
Re: Device Cosmos
Only the external pattern, as far as I know.АндрейКо wrote:Can you learn - how is Space depicted in 1 message from the gradient blue shading with the words COSMOS (instead of the first On - icon)?
Re: Device Cosmos
A pleasant feeling
seems the same massazhka
Re: Device Cosmos
My question is, to ASD. And need some time to start the interaction between the combs and stickers? Or stuck once in the fight? I ask because there is the idea to glue Cosmos with a comb a comb often.
Re: Device Cosmos
Turning the front Room Space is usually about 5 minutes - 10. It can be accelerated to their attention. Watch. You may feel you are ready for a comb.Логик wrote:my question is ASD. And need some time to start the interaction between the combs and stickers? Or stuck once in the fight? I ask because there is the idea to glue Cosmos with a comb a comb often.
