Derealization
Нова
Derealization
Post by Нова » Sat Jan 05, 2013 12:53
Tell me if it'll help, mind machine with derealization?
Has thanked: 5 times
Been thanked: 8 times
Re: Derealization
Post by Воффка » Sat Jan 05, 2013 15:52
What is derealization?
Нова
Re: Derealization
Post by Нова » Sat Jan 05, 2013 16:00
Derealization (depersonalization ellipticheskie) is a disorder of perception in which the world is perceived as unreal or remote, deprived of its colors and which can cause failure of memory. Often accompanied by States of "already seen" (déjà vu), or "never seen" (jamais vu) [1]. Often occurs in conjunction with depersonalization, as a result, in ICD-10 is referred to as: F48.1 — "a Syndrome of depersonalization-derealization," that is, the term "derealization" is often understood as a group of similar symptoms of "depersonalization-derealization" that changes the perception of the surrounding space.[2][3] Derealization is not a psychotic disorder (belongs to the category of neurotic disorders).
Derealization is often associated with depression or other mental disorders.
Has thanked: 31 times
Been thanked: 129 times
Re: Derealization
Post by к-13 » Sat Jan 05, 2013 22:33
Typically causes of this disease are painful experiences(trauma, phobias, prolonged stress, chronic fatigue on the background of constant negative thoughts...), the inability to obtain the desired(excessive demands or excessive demands - usually from improper upbringing), fear of making decisions, the consequences of taking certain drugs(especially in combination with external factors)... In fact is a protective mechanism of the psyche to protect the mind from more complex problems(even is not a psychotic disorder - belong to the category of neurotic disorders), so to fight it is to fight against own shield - you need to eliminate the causes, or the place of departed derealization comes schizophrenia or manic depression :( .
Here find out the reasons, then it will be clear, to help You light-sound stimulation or not...
In any case, if you exclude chemicals(the same fenazepam), it is usually used in psychotherapy - looking for the causes and work to reduce their emotional charge. Helps to develop a healthy apathy - if there is no possibility to improve living conditions, it is necessary to reconsider the attitude to the existing one - to change something, to invent something new - new friends, new job, new apartment, new habits(like contrast showers, Jogging in the morning, hardening, displacement of sleep time to lie down and to rise early in any case good practice). Work with alpha rhythms in most cases to help cope with the problem, but not solve it.
Нова
Re: Derealization
Post by Нова » Sun Jan 06, 2013 1:18
Thanks for the reply.
The reason is clear, but it is much hard and painful to work through it in this state, but if the mm is a little help with this problem, then I'll be able to help themselves.
Re: Derealization
Post by Воффка » Sun Jan 06, 2013 9:46
Nova
Try something from the bracelets of life, version 2.0 for starters as an option.
Re: Derealization
Post by к-13 » Sun Jan 06, 2013 11:36
MM will help to digress a bit if with alpha frequencies work out, it will be easier to control the condition.
About БЖ2.0 don't know - but if psyche decides to use the functionality of the bracelet to enhance protection, not to eliminate the source of danger?
Re: Derealization
Post by Воффка » Sun Jan 06, 2013 12:37
Will use for wearing the optimal way, perhaps this is something the third.
Still think that the disk guide in this case, good fit.
Нова
Re: Derealization
Post by Нова » Sun Jan 06, 2013 14:02
Voffka,K-13 Thanks for the help. :)
I think I will take the Navigator, and Explorer will work. And bangles and I have a skeptical attitude.
Нова
Re: Derealization
Post by Нова » Sun Jan 06, 2013 16:40
Wondering if in my condition auditory training?
Re: Derealization
Post by Воффка » Sun Jan 06, 2013 20:01
Nova
I do not know. Definitely helps good psychologist, I would say that is ideal. But good it is necessary to look, it is a rarity.
Re: Derealization
Post by к-13 » Sun Jan 06, 2013 20:48
Нова wrote:I Wonder, will it help with my condition auditory training?
The more you move between the options, the less likely anything at all to start. Sometimes it is much better to point a finger and start doing first caught the eye, than to wait, when will turn up something "worthwhile".
Auditory training several other goals, then it is better self hypnosis. Turbosplit can greatly lower importance, although it's not really like...
Воффка wrote:will Definitely help a good psychologist, I would say that is ideal. But good it is necessary to look, it is a rarity.
Yes...
ТатьянаС
Re: Derealization
Post by ТатьянаС » Tue Feb 19, 2013 23:06
Yes, to find a psychologist is difficult.
Борис М.
Re: Derealization
Post by Борис М. » Sat Mar 02, 2013 6:52
к-13 wrote:Turbosplit can greatly lower importance, although it's not really like...
Interesting )) and why such a dislike ? ))
