I've done this: wrapped on the tourmalines of the coil to fill and shaped skirts, long tails (see picture above) are needed for "binding" to the main crystal. Then, holding the tourmaline in the middle of the sides of the quartz-dugosevica, wrapped from the tail upward to the top of the spiral, over the top bit off. The idea was stupid to put on the glue, but hesitated. The following tourmaline shifted by 120 degrees secured similarly, placing the coils between the laid earlier, again took a bite from the top of the surplus. Third, estessno also, just from a tail end formed a conical spiral. The other three "tourmaline diode" is mounted between the existing ones, but winding on Degolevich in the opposite direction. All winding clockwise, although IMHO it's a matter of taste, check pendulum.
Small tourmaline needles peaks not seen
Impressions? In my possession were several components of smaller dimensions than the prototype. As he came up the other stones, probably to judge prematurely. On the enemy forums reviews homebrew not found. But all together admire "Shiva" in the design of which he is part. Takshta it makes sense to try.
The author argues that this tourmaline-quartz composition cleans the space from all sorts of terrestrial contamination)
The prototype here:
http://www.hootenization.com/mini_me_intro.html
