С. Альбатрос wrote:But this fact is still somehow distorts the cocoon, even if a person acts under duress or on the basis of imposed value systems? Or other external influences? And to correct these deformations for him, no one will. Or the depth of the deformations associated with the manifested will of man? For example, if a person, say, in the name of God, massacred whole towns in the Crusades, it does not affect its cocoon and does not require further elaboration? Or say, who hinders someone at work or someone else's husband went for the wizards with a request to notify the competitor, based on the point of awareness "what's wrong, everyone does it, I have more than him", resulting in "competitor" deformed cocoon. Whose is in the end the problem? I think the responsibility is at everyone. It may, of course, this "rival" and arrived for the previous error, maybe not, but the result does not change, and in his area of responsibility gets the fix of the obtained deformations.
The deformation occurs, stress in the interaction, and not only negative, excessive unilateral assistance (of course not all), not compensated by feedback, can also create a lower voltage, i.e., the deformation is not just "dents" and "bulges". The depth of deformation depends on the amount of energy and strain in the deforming interaction, as well as its range. Forced can also create tension, which he can implement from the zone of interaction, i.e. work as a "jumper", if integrity, flexibility and elasticity (some parameters of the cocoon) will be enough, the deformation in this case can occur between the end objects, and "jumper" is not affected. When a person performs tasks in the interest of "organisms of a higher order" (e.g. word, "collective consciousness" of the state, territory, religion, occupational, etc.), in this case, it can also be a "conductor" and the main interaction occurs between the end structures, without affecting the very "jumper" (this is for example for the army etc. the force of the collision, where the person having no personal interest, performs "vent to outside" and is not the final structure in interaction, thus a war can destroy hundreds of thousands of egregor compensates for this voltage, deforming it cocoon, and accidentally knocking down a pedestrian car not even death, will receive a rigid deformation). With regards to "went to the witches", witch in this context may be the same "jumper" between the will of the person and his opponent, so even "execution by proxy" creates the communication channel, if the voltage is present it can be realized by a deformation. Again, not every tension only creates a deformation, if in the interaction zone, the deformation is already present, and the voltage has a reverse vector, then such interaction may be compensatory to the previous deformation, and if the deformation occurred in one of the previous incarnations (karmic), it is likely the participants do not remember and do not understand the roots of their collisions and injury for example of one of the participants is merely compensation, which accordingly does not require retribution (retribution Vice versa can create new stress and strain, "ping-pong" like this that can go). At a certain level of evolution of the individual begin to feel tension or a payment in cooperation, in other cases, it again depends on the imagination....... and can be harmful (to create a new strain), again came to the same as the Law....... i.e. if there is no ability to "sense tension in the interaction" is better (more useful) does not invent this tension.
And there's a reasonable explanation, being a "jumper" in more, you can remain only a "conduit" transmitting the tension through the chain, and you can actively participate in the process of the individual (taking responsibility for themselves, inventing their significance in the process). Here.
С. Альбатрос wrote:On this level, he goes, working out and realizing the previous experience, it turns out, the higher the awareness, the greater the responsibility. But the fact of the whole and the difficulty to bring the unconscious into conscious, and it is difficult
And about the excessive liability I agree, it turns out the man falls into the trap of his own pride, and its not working, and others put on yourself. Probably better to talk about responsibility for their own condition, leaving the opportunity to others to work on yourself. MAG. no thanks, in any case, communication helps to articulate some things and at least try to see what you're missing, and maybe someone else will be helpful.
The fact is that at this level getting (judging by my own experience) are not necessarily perceiving past experiences (my childhood), more accurately past experience is not and experience to this level is acquired in the society and he is the "mediator" in interactions with the World (during the transition a certain level of evolution of the individual directly), contact Person with the Law (of the universe, as a system mechanism) the result of direct interaction with the World, if you meet, when referring to him - the Law will protect all inconsistencies "will you pare down", so a contact can be not only useful, but also dangerous. The sense of the Law may result of interaction with him in one of the past incarnations, and perhaps other reasons generating it, it's intuitive (binary Yes/no), i.e., only partial access to his rules (feeling the fit/gap Law in the events and actions). Mind it not to understand. Something like this.......
Again, this is only one of the possible points of view on a multidimensional structure, therefore, should not be taken as the truth, but only a hypothetical assumption, especially looking at the question narrowly, only on your level, so you can have something significant to lose.
Sincerely, MAG.no
