Creativity and visualizati (session and use)
Hello, are the owner of the Nova Pro 100 from Photosonix. Interested in the development of visualization and creative abilities. Some will recommend a session of the partition creation/visualisation? what is the procedure of using it? which session is better to listen to in the morning? what night? what to do during the session, concentrate on something? to visualize? or to let your mind wander? is it dangerous to use a camera more than 1 hour a day? (for example, if a 45 minute morning and 45 in the evening) I would really appreciate answers from professionals. Thank you.
Re: Creativity and visualizati (session and procedure for their use
Explain, please! I need to visualize obejct with such brightness and clarity, as if it was a real object. How to achieve this result?
Before creating a new topic, to study the forum, at least just for the sake of decency. Your question was already covered from all sides and solutions proposed heap, just read the forum and find the answers.Роман Д wrote:How to achieve this result?
In this case, please reference. The forum was viewed about creativity and the visualization of the specifics, not found, about the procedure and the use of appropriate sessions too. I would appreciate links. Thank you
"See then believe" - said the ancient Romans. How are You with safety? How are You going to distinguish real objects from thought? I hope You don't want to be schizophrenic?Роман Д wrote:I need to visualize obejct with such brightness and clarity, as if it was a real object.
In the General case, the alpha session greatly enhances the ability to visualize. Long session useless. Best of 3 for 15 minutes (with a break of not less than 3 hours) than the two for 45. It is necessary to sit with a straight back. Not necessarily in the Lotus position, you can just on the chair, feet firmly on the floor, hands on his knees. The rest is not important.
Andrew, thanks for the answer! Safety all right. And there are still a few things I would like to clarify. What specific session you would advise for each day with this request. Every day to listen to a different session? or can I change? If possible, give some algorithm called the sessions (of standard model novap pro 100). What to do during a session? to represent the objects? perhaps, I would advise something else...I Will be extremely grateful for an answer. Thank you!
Roman D
Standard mode
- 3 weeks session of "r", alternating between them at random, then "E" then "C". All for three weeks. It's the preparation. To visualize it is necessary to release visual analyser, so then it will only work with the disc visualization.
Standard mode
You mean the CD "Creative Visualization" ?
However, we've added another night listening to "Massage brain", a lot of feelings and sleep well after it if it is possible in this case to listen to it at night?
Roman D
Everything is in Your hands...
Andrew, tell me, please, use the massage of the brain about 10 days, if you do it at night, in the morning you can't Wake up, very hard. If you do in the morning, then very sleepy, what is the reason? Thanks for the reply.
Roman D
Probably with big debts for sleep... Try 4 hours before bedtime.
Good afternoon. I have the same question as Roman. D. Only I have no car. I'm trying to decide, machines and points. If not difficult please Orient. So I understand that at Luma - one session on this topic at InnerPulse -6, Nova Pro 100 has 14 sessions on this topic. Ie the more expensive the car the more possibilities? Or I not correctly understand everything and you can spool the session ?
Want to buy, but I don't know
Board
For a good visualization you have to build first alpha, then beta waves. Mashinki enough for anyone to visualize and then you can (and should) without mashinki.
Thank you for the specific answerАндрей Патрушев wrote:For good visualization should be built first alpha, then beta waves. Mashinki enough for anyone to visualize and then you can (and should) without mashinki.
Yesterday, the first time I tried alpha waves. All fly away!!!!
This kaleidoscope I've ever seen!!!
I use regular glasses, started with minimal power, because more than half power even I could not do it - too bright for me.
By the way I noticed this kaleidoscope and you can still drive - it's all cool!!!!
Ie you can stop the movement of the kaleidoscope, can be a certain color to grab and expand it to "full screen" so to speak.
Can the speed slow down, but in General can be a lot to do there hike all the colors of the rainbow are present!!!!
PS well that is not picked brighter glasses you can go blind
In General I'm satisfied! Still no cars so to be able
Andrew, tell me, please, when you audition sessions need to be in a state of silence or actively visualize?
Roman D
And there all session contexts painted: visualization, musical creativity, meditation... So, respectively.
Sorry for the insistence, if I understand, during the session on visualization, it is necessary to clearly present the images? can you give some other recommendations for listening to the session data. Thanks in advance for the answer.
Roman D
Another standard recommendation is sitting posture with a straight spine and maximum relaxation.
Is it possible to do between sessions pereryv for example a week? Worked for A session, now think of E , then, but there was a break for about a week And after sessions
