So, very briefly, what is the PC "deal with it", in other words, how to apply and what kind of PC are and other basic information about the technology.
1. a little strange chatter
Perhaps start with the fact that the PC thing is so unusual that relatively recently I could not imagine the possibility of carrying out this technology further, "sensitive information". However, there have been a number of changes, both external and internal, that are allowed to do it. The external changes were completely external (not dependent on what is happening on this forum for example).
Up to this point, some elements of the practical techniques associated with this technology was in practice learned by the audience of the club at openlogic (and it has been for quite a long time) that demonstrated some bug (error) in the extant rare mentions of internal or personal worlds.
In fact, this seems to occur only in the echoes of the Vedic sources, the ability to build these worlds, the excellent in their logic, organization and interaction with all familiar to us, anchored down only for gods. Refers to such opportunities and in a number of specialized literature containing less distorted experiential data (I'm on fantasy mostly).
Practically, I have not yet managed to find a man in whose mind this "feature" would not work at all. The truth was its weak manifestation, however, easily be corrected through practice.
2. the geometry of the interaction of Mir-operator-personal world operators(other)
In the description of processes of interaction of Mir-operator, I had to stick a flat image of what is happening, previously described in concepts such as СК1М (operator, world, their interaction buffer), a stabilizer (the picture of the world in the mind of the operator projected onto the world), 3.0 (operator in the state of the Creator, out of this world, changes the world), as well, and their vzaimopomoschi (example 3.0+OZ operator in the world, and change it as the Creator, not getting involved in the internal game with too much seriousness).
In fact, when the silent aspect of the inner worlds that affect all other aspects mentioned and is quite important.
Briefly think of it this way - each person has the concept of a secluded inner world, not inhabited by other people (so some Castaneda's references and analogies do not quite fit this concept), in such a world are usually natural and there may be some living creatures, including the famous in the mythology (a topic for another and not short of conversation - their place there), not associated in the perception of the operator as "another person", the parameters of such a peace on the one hand very personal, on the other pliable. In fact, for the operator these are two completely different paintings and assemblage (personal world does not communicate, does not intersect and is not bound by experience with the world here and now), as well as different streams of time (while there is no General rule and there are different anomalies).
Sophisticated and experienced operator can create a small zone of intersection of these two incompatibilities that will spot anomalies. Add to that some kind of "Rail" on TO this and will PC.
Theoretically and practically possible navigation of other operators in the personal world of the operator, which will lead to some interesting effects and will not happen without concerted action from both sides, however, such visitors will always be there "observers" or "gaining experience", ie there is for them impossible mode 3.0.
3. principle PC.
PC is a block of user-friendly programs built on a living, harmonious biological principle of (CO) operating in the buffer private world of the operator - the world is here in connection with this feature, the PC has exclusive settings and has the equivalent strength of the lateral connection principles 3.0 (in this mode, the operator outside the personal world) and the panacea-2.0 (when the operator completely in this world and left the mode, the Creator mode "involved in the action").
Technical features PC allow to realize the potential noticeable (even better to say significantly) higher than the potential of holographic labels such as Panacea, both from the point of view of ability to maintain unusual programs (an example of such unusual programs for panacea, it's such as a map migration is a simple trick that has not been done before and was surprised by a friend being "in the know" when I before that told me that "it will work like this", it is now card transfer became in fact ago something familiar), and from the point of view of power connection information - the material and energy potential, the system PC is also superior to a panacea that creates a unique local area, non-deformation, but with the "fixed energy" due to the partial overlap of the spaces of the worlds. It also explains the growth potential of Indonesias programs and data (in comparison with the same cure).
Due to the "bridge" principles with 2.x-a panacea and 3.0 at the same time, PC can with enough power to work with programs to 2.x-panacea and programs to 3.0 (which it seems hardly anyone uses from regular users). If the cure allows you to programmatically specify anomaly 2 BJ.x for example (implemented in the same card transfer), the PC allows you to create not implemented on a tangible medium or projected onto it also and replace 3.0 OZ 3.1
Due to the difference in fabrication technology, the power of the PC will be slightly different, changing the throughput of the forming buffer.
All PC one operator are combined(read: stronger).
The PC is operator specialization, and in contrast to the usual BJ after some time of use (about 2 weeks in local time) transfer to another operator is NOT SUBJECT.
You can use your PC with goals similar to the stickers that used a Panacea. (with a significant increase in the programs)
You can build a virtual substitutes for our products, with the aim to increase flexibility or reduce the size-mass, etc. carry or locally installed products.
Naturally, all this requires either a certain experience or programs included "factory method" in a particular instance.
So potentially PC fully closes the circle and is one versatile product, though the younger version in this mode you cannot use.
On the other hand, many users find such things as BJ 2.0 and 2.1 as was recommended by the start and for a long time at least, remain. So nothing fundamentally changed.
For example, a Panacea, for regular users, I think the clear difference between a pendant and aklakou, about the same story with poderiam PC.<
