Good day! I would like to know:
1. Is it possible in the car Navigator using an external microphone for voice recorder?
2. Is it possible in the car Navigator using the recorder is operating together with wire programs, music and other audio recordings?
For example, I'd like to try to practice that kind of thing - wearing sunglasses and headphones with microphone (headset), see the resulting images and listening to audio programs, and if necessary, switch the recorder to record your speech (thoughts, images, sensations). Is it possible to do simultaneously?
Work with a tape recorder in the Navigator.
Дмитрий Смирнов
Алексей Крячко__
Re: Working with the voice recorder in the Navigator.
Just want to clarify, for what purpose was created in the "Navigator" recorder : to record short phrases, which can then include with the sessions in the "synchrostart". Therefore, there is only a built-in microphone and a mode in which simultaneous operation of the recorder playing a recording sessions or not.Дмитрий Смирнов wrote:Good day! I would like to know:
Although the hardware allows for example to record from an external audio source connected to the audio input, including the active microphone. Also there is technical possibility to write on tape during the playback file as the recording and playback is conducted in various codecs. However, in the current version of the software, these features are not used. Along with the renovation and development of firmware "Navigator" can all be added if these features will be of interest to other users and approved by other developers.
I want to be able, nevertheless, to use the recorder player at the same time - at least for the same disk, Andrey V. "Music for hypnosis and self-hypnosis". And generally, ideally, it would be nice to have the ability to run a recorded voice file from the audio player to immediately begin to peck installations, and for example, after 10(15,20,30...) minutes after the start, when audio has already had some effect.
Question to the developers.On my Pathfinder, the recorder does not record the file length is more than 17:04 even though there were more time.How to fix?Firmware 1.20.And is it possible to the browser in this case to upload files recorded with other external recorder.Why the recording is saved with the recorder in WAW format?
Алексей Крячко__
1. the time limit is 60min, probably crashing when recording, this has happened with some memory cards.рустам wrote:Question to the developers.On my Pathfinder, the recorder does not record the file length is more than 17:04 even though there were more time.How to fix?Firmware 1.20.And is it possible to the browser in this case to upload files recorded with other external recorder.Why the recording is saved with the recorder in WAW format?
2. you can download and prepare files, voice recordings on another device. Especially in Pathfinder, is quite just made the microphone and not the acoustics achieved by a microphone connected to the computer. In addition, the computer can "sew" long entries and fit them at the time to time sessions, which is supposed to make synchrostart.
an important requirement is that entries must be in mp3 or wav format. Other formats ( W.h. amr dictaphone - not reproduced).
3. wav uses no compression. It is written with a low speed (128kbit/s).
Last edited by Алексей Крячко__ on Wed Mar 02, 2016 10:32, edited 1 time in total.
Alexey Kryachko__
Another urgent request "to unhook" repeat playback of a short file from the inclusion of the next segment in the session.
Алексей Крячко__
now it is done in versions 2.00 and 2.01Андрей Патрушев wrote:Alexey Kryachko__
