Novice Navigator
All kind time of day. The people, prompt, please, where there is information on the sessions:
1. What kind of session it is advisable to listen to the first 21 days. Names, their characteristics, listening.
2. Which session is better to go after 21 days.
3. What are the optimal intervals between sessions.
4. What is the "trick" of the waveform.
Thanks in advance.
Thanks in advance.
Re: Novice Navigator
in the instructions to the Navigatorспоилт wrote:the People, prompt, please, where there is information on the sessions
Andrew, thank you so much for your prompt response.
And when you go to L, C, D, S, Your specialized session?
L, S - on demandспоилт wrote:Andrew, many thanks for your prompt response.
D, C - E after
EMDR (opn) - better after R.
spoilt
This session.
This session.
Listened to "R", switched to "E". Question: is it time to listen again, for example "R" or not to mix (of course with an interval of not less than 3 hours) ?
1Андрей1
Of course you can, especially if you need to calm down and relax. Indeed, about the breaks should not be forgotten!
1Андрей1
Yes, better in the first half of the day to do E, and the second - R.
Tell please where it is described as a session of innerpulse\Nova Pro 100 to the Navigator to throw. Thank you!
Easy way not only through the editor segments. All session with the index N after the numbers are direct analogues of those with the Nova Pro 100.Воффка wrote:Poke please where it is described as a session of innerpulse\Nova Pro 100 to the Navigator to throw. Thank you!
Skonvertiruet need in audio format and put it on a flash drive if it really wants their...Воффка wrote:Poke please where it is described as a session of innerpulse\Nova Pro 100 to the Navigator to throw. Thank you!
Yes innerpulse love session "right brain", the analogue of Navigator saw. Can I convert not know how, with the editor never worked, so now I will try to fragments to migrate. I have very vivid memories after the "right brain" especially the first time.
Garbage-war, there is nothing to learn)))Воффка wrote:can I Convert not know how
Only version should not be below 3.7, to her save to wav in the demo version was limited to ten minutes. In 3.7, this restriction is removed. Just open the session in the program and choose in menu "save to wav" - get session mode audiostrobe. If you do not like, you can resave with different settings, but if you like it, then have ready a working session, not a recollection successfully when the existing circumstances)))In principle, the session from the NovaPro 100 are automatically opened and converted to a format audiostrobe using the program MindExplorer SW. If this program is installed on your computer, then you can use navigation just as audiostrobe decoder. The operation is quite appropriate, since the programs NP100 color management is not provided.
And generally I would place the administration has already created a DVD with the most popular New sessions in audiostrobe and had offered(or put?
) him to set Navigator's to such questions constantly arise...
Do I understand that it's essentially re-create the session in the editor for the Navigator just looking at teh data session open in the editor to innerpulse?Андрей Патрушев wrote:Easy way no, only via editor segments.
Voffka
Yes.
Yes.
Clear
Is there any clear instructions or tips for working with MindExplorer SW or any other editor in the Russian language? In the editor from the Navigator and in the same MindExplorer SW is not such that the names of all fields agree with each other and hence the questions.
K-13
I tried yesterday to transfer a session A session Patrushev .wav, happened, something
Session in wav was not similar to the original no sound, no pulsating lights
Voffka Can someone post their altered session, surely someone was doing it for myself.
1Андрей1
Apparently there are none
1Андрей1
Voffka
you mean che?
if necessary photosonics old to drive a session in the Navigator without changing the length, then use MindExplorer to translate the original session of photosonics in *.wav, then on the GPS on his play as gate-entry
Voffka
you mean che?
Like about itЗОМБИ wrote:1Андрей1
Voffka
you mean che?
,in fact it is re-create the session in the editor for the Navigator just looking at teh data session open in the editor to innerpulse
The sessions themselves take up little space, can you say nothing is in contrast .wav. If I also understand correctly, session, much less guzzle the battery, in contrast to the strobe-records.Андрей Патрушев wrote:Easy way no, only via editor segments.
