I understand how having InnerPulse and making the "tambourine dance" you can load prof session, but with the limitation of 25 pieces
A perfect device not only for professionals
Владимир Шумаков
People gathering for the first time to buy a Mind Machine and able to pay money for a device that met all its needs is facing huge delema. As the kettle and in the future the person who will deal with what exactly he wants from the instrument does not suit one in the Navigator, namely the separation of "devices For professionals and researchers" Navigator and Nova Pro 100 and the other device - for "non-professionals" - InnerPulse, which gathered for sessions that are not included in the "professional (the list is not included in the prof version is given below). If a Couple can be involved in session, the extra session of InnerPulse, he prices are not byloby
Not to mention the imperfection of the points and switching to a computer at InnerPulse.
Владимир Шумаков
Re: a Perfect device not only for professionals
And so, both sacred list not enough for full happiness when you first purchase a Mind Machine.
I.
Recreation/entertainment
1. Nirvanamania
Microcycles binaural beats with surf and octave progressions lead to the final 9 minutes of blissful energy-giving relaxation.
2. Sensual magic
This program uses the excitement of the beta range of four colours. The frequency of the chakra associated with sexuality. Make sure that the first person you will see when the session is over, just the...
3. Kaleidoscope
An exciting session offering experience with kaleidoscopic color images.
4. Amusement Park
Unexpected twists and turns give a lively feel to this fun and games session.
II. RELAXATION
3. Calm down!
Calm your frayed nerves, clear the emotional stress these rolling alpha/theta waves. Use after a stressful situation.
4. Waves of tranquility
For quick relaxation. Is used, in particular, kumanovski resonance (7,83 Hz).
5. Wave of relaxation
A relaxing journey. Ocean waves and low-frequency binaural beats that are amplified, then attenuated out of phase with the signal in the glasses, creating the effect of a stay on the beach.
6. Easy/low relaxation
Soft relaxation session. Soothing, but not completely.
7. Deep rest
If You need complete rest and recuperation, then this program is for You. Use it after sports training and hard work. After the session take some time to gradually return to normal activities. It is useful also to impose the sounds of nature to signals of the device.
III. Training
2. Quick stay after class
Use this program immediately after class for quick integration of learned material. The session ends with a return to a state of quiet wakefulness.
4. Memory/ memorization
Applied transitions between alpha and theta ranges for entry into the hypnagogic state, where you float a very vague memories.
5. The rhythm of the Baroque
Some believe Baroque music is the perfect background for learning.
This session uses dual binaural beats in the mode of polyphony – the main features of Baroque music. Apply this session to the music of the Baroque - such a dynamic Duo able to capture the imagination.
6. Accelerated learning
Classic light and sound stimulation for relaxation and remembering.
IV. Visualization
3. Dreaming images
For soothing relaxation in the theta range and the appearance of the dreaming images.
4. Reboot
Restart your mind. Do a full reset! Dual binaural beats, and rapid changes make this an excellent session in order to reboot on the go.
5. Mind spin (rotation of the mind)
Expand your perception with this session. Twisting, turning, visual trip with exciting music.
6. Visualization
The ability to visualize is not easy. This program is designed to help You acquire the skills of deep imaging. Set a goal of a visualization using this session with the active music.
V. Meditation
2. Ground
Lumanovski resonance and its harmonics are used with intervals of the chords ( in the frequency ratio 3/2). This interval is known in Eastern cultures as the "between Heaven and Earth
5. Four octave chakra balance
The first two minutes are smooth transitions by frequency (VFD), conducive to concentration. After a brief period of light stimulation signals in headphones change on the binaural rhythm with the noise, and the exercise begins. Alternately meditate on each chakra starting from the Muladhara and above, ending makuleke chakra. Each meditation period (resp. each chakra) formed a 4-octave microcycle with an interval of 1 minute. The sequence of octaves for each chakra is based on the traditional note of each chakra, and the frequency of the binaural rhythm is selected 7гц as for theta meditation. To work with the program it is desirable to have skills of meditation on the chakras.
7. Cosmic consciousness
No comment. Raised Kundalini, chakra burn. Any longer!
8. Deep low meditation
Carrying even lower tones and binaural beats even slower.
9. Back back
Session deep relaxation/meditation that You come out refreshed.
VI. Energy
3. Full speed ahead
Get up and run! Tones the body and the brain whenever you feel sluggish.
4. To business!
You get a mixture of gamma and beta waves. This session is designed for overclocking in mind.
5. Sports wave
The program will help set up on sports and active physical activity.
6. High energy
Starts at a frequency of 1 Hz and rises up to 20 Hz. Use for energy stimulation.
VII. Sleep
1. Sleepy head, sweet dreams
Feel how easily and quickly you can fall asleep if you use the power of dual binaural beats. Feel free to remove your glasses or headphones, when you feel very sleepy.
2. Knockout
Powerful flight simulator for sleeping. Use this program if you not only that it gives the previous.
3. Day dream
Starts with a smooth transition in the Delta-rhythms, which is a stop on 18 minutes. Then return to the updated state of wakefulness.
4. Deep sleep
Use double monaurally beats. Good night.
5. Quick recovery
5 minutes down the frequency in an easy 16-minute NAP, then a quick return to active wakefulness.
6. TKO
It is a technological knockout. Useful for those who are accustomed to sleeping pills pills.
VIII. Special
1. Aerobics in the lower part of the spectrum
Random frequency, tone and rhythms of change in 5-second intervals in the alpha/theta range.
2. Aerobics in the upper part of the spectrum
Same as session 1, moved in the range of alpha/beta range of 10-18 Hz.
3. Hut-Ten-Hut
Classic light/sound session for assistance in reducing distractions.
4. Bust winter Blues
Lights moving slowly, as the excitation frequency reduces from 40 to 30 Hz, 15 minutes and 30 Hz, using light to excite in fighting the winter Blues.
5. Left brain
This session stimulates the left, logical hemisphere in the beta band, relaxing the right hemisphere. Try to do mathematics or other logical and intellectual tasks.
6. Right brain
This session is designed to stimulate the right brain, calming the left. Useful for enhancing creativity or other right activities
7. The left hemisphere
This session stimulates the left hemisphere and subdues the right. For linear/logical thinking.
8. The right hemisphere
This session will excite the right brain, calming the left. Suitable for creative thinking.
Programs missing entirely:
TRAINING
1. Quick preparation for class
The power of binaural beats allows you to make this session short, but it gives the calm and concentration. Use to create the necessary learning state of mind.
3. Increased susceptibility to suggestion
This session gives a hypnagogic state in the alpha/theta range, on the verge of sleep, the state of relaxed receptivity. Of suggestion will be most effective after the first 12 minutes. Use in conjunction with your favorite positive affirmations (on tapes, for example, or self-hypnosis).
RESPIRATORY SESSION
1. Natural clear 1
Start with slow, slow breaths.In accordance with the sample slow breath in half.
2. Natural clear 2
Suitable for each after getting used to the slow breathing.
3. The life-giving breath
For thought. Alternate 10 breaths slow and 5 fast. Slow breathing is your natural part of the respiratory process. Quick breaths will give you an increase in vitality. Slow breathing works both in session 2.
4. Pranayama 1
The session will slow down your breathing to match the periods of inhalation and exhalation. Achieve a calm and balanced state. Use multiple times to pranayama 2.
5. Pranayama 2
Ready for deep exercises. For anyone who is fully possessed of deep inhalation and exhalation and can maintain this breathing throughout the entire session. Use after pranayama 1 and the program "four square".
6. Square breathing
Requires more preparation than pranayama 1 and 2. Four phases of breathing (inspiration, delay-on the inhale, the exhale, the exhale delay)must be equal. You surrender completely to the respiratory process.
7. Pranayama 3
Slow breathing throughout the session equalizes the inhalation and exhalation periods of delay. Use after mastering pranayama 1 and 2.
8. Pranayama 4
Requires very much preparation. Use when you reach the mastery in other pranayama. Slow breathing throughout the session equalizes the inhale and exhale, the delay times increase 2 times.
9. Breath yoga
Yoga attaches great importance to the breath. In this session exhale 2 times longer than inhalation.
10. Breath of Tao
In Tao attaches great importance to the ability to accumulate the QI energy in the period of inhalation. In this session, the period of a breath 2 times longer than the period of exhalation.<
I.
1. Nirvanamania
2. Sensual magic
3. Kaleidoscope
4. Amusement Park
II. RELAXATION
3. Calm down!
7. Deep rest
III. Training
IV. Visualization
3. Dreaming images
4. Reboot
6. Visualization
V. Meditation
2. Ground
9. Back back
VI. Energy
3. Full speed ahead
4. To business!
5. Sports wave
6. High energy
VII. Sleep
2. Knockout
3. Day dream
4. Deep sleep
5. Quick recovery
6. TKO
VIII. Special
3. Hut-Ten-Hut
5. Left brain
6. Right brain
TRAINING
RESPIRATORY SESSION
1. Natural clear 1
2. Natural clear 2
4. Pranayama 1
5. Pranayama 2
6. Square breathing
7. Pranayama 3
8. Pranayama 4
9. Breath yoga
10. Breath of Tao
Владимир Шумаков
If you have the opportunity to deliver these sessions in the "Navigator", then I'll buy it for the action: Instruments WUA "Navigator" + "Alfaria" price 33900 rubles.
Vladimir Shumakov
Vladimir, a session in the Navigator this is a modified and adapted program of the Nova Pro 100 (in addition to the unique programs copyright Andrew P.). So there is no cause for concern. With the Navigator You have the opportunity to deal with the most modern and effective programs that are inherent in the device, able to realize their maximum potential in full. The Navigator includes only those programs that in the opinion of the developers and our clients were the most effective. In this device (yet), You will not find respiratory programs, as practice has shown, they were used only 5-10% of users. And just believe me when I say that the rest of the pros of the device Navigator with more than cover this "deficiency".
Владимир Шумаков
Thanks for the reply! About the fact that out of Novopro program included in Navigator - that's understandable. I wrote on another occasion. In Enerpulse all clear programme and this is a big plus. Also reading the manual to it, questions with no. Another question. I read on the forum that you 3 000 rubles changing of defective cost Inreplace. Hence the conclusion. Once you do the repair, then you also sew it. So there is a possibility of the firmware get the underlying session and konvertnut these sessions for the Navigator of the big problems is not. Then there is the next logical question. And where you can get a download or even how to fuck
these sessions?
Vladimir Shumakov
Sessions, Nova Pro 100, there are on this website. You can download them in the program MindExplorer and enable Navigator mode streamdecoder and connecting its audio to the sound card of the computer, you can use the Nova Pro sessions.
If you want to of course
Владимир Шумаков
You probably didn't hear me.
I asked about something else. Turn the other hemisphere, perhaps with a MM.
There is a theme and it's all very clear and understandable:
FAQ for installing new sessions in your mind machine
In Inerplyus to establish a session from from the Nova Pro 100 is not the issue, and Vice versa ------
I'm interested in the session from Inerplyus.
If the Navigator to insert them is impossible, meaning, at least at the primary level for dummies
I am Navigator no. At least only for easy display and cool points of comfort in navigation, built-in player, alarm clock and calendar, and also connect with the computer - it makes no sense to pay 20,000 rubles for the device for professionals.
Go to the forest...Владимир Шумаков wrote:Turn the other hemisphere, perhaps with a MM.
I certainly didn't ask for your advice what I should do.
And I do parallel to what you buy or not.
Владимир Шумаков
Sorry, to offend anyone not wanted.
Just to ask one question, and the answer is quite different.
Vladimir Shumakov
In fact, Innerpulse, except for breathing, all sessions of the Nova Pro 100. Sometimes only the name changed...
On the other hand, if You are really interested in working with mashinoy and don't want to listen to good advice, then buy Innerpulse - also a very decent choice. I assure You that the inconvenience was insignificant.
By the way, gradually all sessions of the Nova Pro 100 will be in the Navigator...
And yet...
The division machin the instruments for professionals and non-professionals is very conditional and applies only to services and not to the sessions. Brains something all the same...
Just being a prisoner of his performances, You don't want to hear the answer, which slightly does not correspond to them...Sorry, to offend anyone not wanted. Just to ask one question, and the answer is quite different.
And yet...
Why make it hard when it's simple?Владимир Шумаков wrote:So there is a possibility of the firmware get the underlying session
Problems, of course not, but time and work requires considerable...Владимир Шумаков wrote:and konvertnut these sessions for the Navigator of the big problems is
Yes, all the same: FAQ for installing new sessionsВладимир Шумаков wrote:And where you can get a download or even how to fuck these sessions?
And in what a problem - MindEx-r 3.7 SW successfully convert to the audio format not only session from Nova and Innerpulse, but also a lot of MM other formats. Still in these sessions, the management of light is one led on the monochrome channel - audiostrobe-Navigator mode this'll be fine. And so a lot of sessions are listed in missing - I for three years the use of three MM(with the Navigator the fourth) so I didn't listen...Vladimir ShumakovYou take is what it is, as long as these are comfortable, the next write - up there even with the wheels on flehi is possible to do six months easy...
Владимир Шумаков
Thank you all for the answers.
Yesterday I bought Interpuls and is very happy. I like the thoughtfulness of sessions and ease of operation. Session all a fairy tale..
Kick in immediately. Slept like an angel and listened to revival E02 and at the end a black screen before the eyes of the TV, with the set of ordered points....
And so, all many thanks for the reply..
Good luck in the Search Path and self-Awareness..
Vladimir Shumakov
Congratulations!
After half a year to ripen Navigator
Congratulations!
- Максим Данилушкин
Thank You. A miracle device. Happy New year, rays of goodness and vibrations of prosperity in the coming year!
