Man-made psy-network
Been thanked: 2 times
Post by ЗОМБИ » Wed Feb 08, 2012 7:36
so what will the psi network to do or not??
let us define common goals... they are, as I understand it :oops:
(on the agenda: teleport, almost-perpetual motion on the water)
Has thanked: 5 times
Been thanked: 8 times
Re: man-made psy-network
Post by Воффка » Wed Feb 08, 2012 10:53
Teleport is certainly useful :) The next question focused on the transition from words to deeds. There is technology safe production and use?
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Wed Feb 08, 2012 11:54
I read what You wrote to me.
I write the answer.
Post by ЗОМБИ » Wed Feb 08, 2012 13:53
Voffka
you probably have not found a theme that is carried
so say a network device that can be sharpened by common goals
censored
Humpty Baltay
OK, wait
Post by Шалтай Балтай » Wed Feb 08, 2012 14:32
that would not keep you waiting, you might like to look yet: http://ru.wikipedia.org/wiki/%D0%90%D1% ... 0%BB%D1%8C it is somewhat off, but still someone else's experience, besides real and successful.
and so I write.
Post by Шалтай Балтай » Wed Feb 08, 2012 16:27
Post by ЗОМБИ » Thu Feb 09, 2012 21:08
Humpty Baltay
kind of figured
without distortion, only a small local grid to do that... not too bad...
___________________
maybe here would be to throw the global goal of who have any?
can you figure out why (for the three :) )...
Igor
Post by Igor » Thu Feb 09, 2012 23:38
Very interesting, could you elaborate?
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Fri Feb 10, 2012 10:16
ЗОМБИ wrote:- product: SP, SK, OPGI, and other devices.
You will get a stillborn monster. SK does not fit the company SP and OPGI. First change the channel, or rather there is a "service provider". Past just pump up the native channel.
And the idea of seeing good. Though each seer has its limitations, so it's better if there's not much to see. Will still be a problem that we need to clearly articulate what to look at.
Igor
Post by Igor » Sat Feb 11, 2012 23:38
Lord, I apologize, everything here is very vaguely described, not enough information, not enlighten that as a Yes? You can PM.
Just recently visited thinking about mental synchronization, and how that would look, maybe I'm not out of the Opera?
Post by ЗОМБИ » Sun Feb 12, 2012 9:23
Igor
censored
Ланцелот wrote:You will get a stillborn monster. SK does not fit the company SP and OPGI. First change the channel, or rather there is a "service provider". Past just pump up the native channel.
you want to say that it is impossible to work on one goal at a time by using SC and SP/OPGI? for example there will be two channel, two ISP... will conflict?
the idea of seeing mandatory because without control it is possible to naudit... I was just that seeing there were from ten at least.
since I'm not that topic, Lancelottell me , what other devices can be used for bending reality? Tesla kacher-brovina? anything else?
I do not remember where, Michael_ said that the world is quite destroyed, is quarantined...
Michael_
how about a collective of pulling the world out of your ass?
for it must be done in the first place ("work on yourself" is not acceptable)?
- what for it is necessary to do in the second and third place?
(see, you the programmer and contribute, and yet...)
Ланцелот
Post by Ланцелот » Sun Feb 12, 2012 13:29
ЗОМБИ wrote:you want to say that it is impossible to work on one goal at a time by using SC and SP/OPGI? for example there will be two channel, two ISP... will conflict?
SP/OPGI do not change provider. Anyway, I didn't see it. SK and BZ change. In my case it was the connection at the level of the 7 chakras, completely changes my energy, IMHO, not for the better. In the branch BJ is another description
Code: Select all
Quote("Druid")
A day after the start of curing, I started to feel at the top of the head some tingling (up to painful sensations), now I can formulate how the organization connection, a new communication channel. In both. And I realized that my SC1 is already working. And he did it. Hurrah!.
Conflict will not provider and users who may not like the new provider, even a provider, and podlucky.
Code: Select all
since I'm not as in the subject, Lancelot, tell me, what other devices can be used for bending reality? Tesla kacher-brovina? anything else?
I haven't done it on purpose. IMHO the KK harmless practice, but it is better to check his poklonnikov. All type of gadgets katscher and etc., can be as a temporary measure, it is not necessary for them to sit down, the slightest failure, like promised in December 2012 and a large P all hooked will be provided.
On the topic of 21.12.2012
Post by ЗОМБИ » Wed Apr 04, 2012 10:55
http://trexlebov.ru/zdrava/480-vred-kom ... orova.html
seriously the third article on http://trexlebov.ru read this response :D :D :D
