A few questions
Агафон
A few questions
Post by Агафон » Thu Jan 19, 2012 15:30
Hello!
I would like to ask a few questions, the answers to which are not found in the manual:
1) When you can charge your GPS - on or off? If in both, then which is preferable?
2) is it Possible to include session during charging, or is it better to wait for the batteries to charge?
3) Can I use headphones, impedance less than 32 Ohms? And if so, what happens then? The sound quality will be worse, or the unit may be damaged?
Re: a Few questions
Post by Андрей Кабанков » Thu Jan 19, 2012 16:49
Агафон wrote:Hello!
1.A charge mode provides that the device is turned on.See the description of the user about battery charge.
2.You can use the device while recharging the batteries.
3.It will be quieter and slightly cut off the frequency range.The device is not damaged.
Агафон
Re: a Few questions
Post by Агафон » Thu Jan 19, 2012 18:05
Thank you!
Another question - how to remove background hiss that accompanies the session (apparently, this is pink noise)?
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 19, 2012 19:07
Agathon
In the editor session in the session need to set to 0% volume.
Агафон
Re: a Few questions
Post by Агафон » Thu Jan 19, 2012 19:24
I mean - generally the sound is clean, or what? :)
The fact that the sounds are "foreground" for me, to listen comfortably and conveniently.
But, for example, in each session of the section of relaxation when this is heard and even muffled hiss. And this is the most hiss (his and all) I would like to learn how to eliminate.
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 19, 2012 19:27
Агафон wrote:I mean - even the sound is clean, or what?
No, only pink noise.
Агафон
Re: a Few questions
Post by Агафон » Thu Jan 19, 2012 19:33
Do I understand correctly: you need to go to Settings, choose Session + audio... and then? To put to zero the bass player?
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 19, 2012 19:37
No need to open the desired session in the editor sessions, uboat the volume to zero for the pink noise, save and upload session device to the library. In the future, to open it from the library and not from the base sessions.
Агафон
Re: a Few questions
Post by Агафон » Thu Jan 19, 2012 19:52
with lighting figured out, but can't seem to find the editor sessions...
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 19, 2012 20:45
viewtopic.php?f=38&t=4311
The program to create sessions version from 1.0.14
Агафон
Re: a Few questions
Post by Агафон » Thu Jan 19, 2012 21:12
Thank you, I will understand.
I have 2 questions:
1) All programs include pink noise? If not all please name any without him?
2) is it Possible to remove or at least reduce pink noise, no editor sessions using settings in the Navigator?
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 19, 2012 22:48
Agathon
1. All.
2. No.
Алексей Крячко__
Re: a Few questions
Post by Алексей Крячко__ » Sat Jan 21, 2012 22:07
In fact, this noise and I don't like. And it would be possible to Commission additional configuration, it turns off, if it is in session there. That edit was not necessary session.
Димас
Сотрудник mindmachine.ru
Re: a Few questions
Post by Димас » Sat Jan 21, 2012 22:23
Agathon
Alexey Kryachko__
Friends, are you? Pink noise has the ability to quickly plunge a person into a state of relaxation and being present in the programs purposefully.
Re: a Few questions
Post by Андрей Патрушев » Sat Jan 21, 2012 22:24
Alexey Kryachko__
This noise greatly increases the efficiency of session...
But if to proceed from the principle that the customer is always right, then... let's get the vodka trade. :?
Агафон
Re: a Few questions
Post by Агафон » Sun Jan 22, 2012 9:35
And maybe, somewhere in the network is already laid out session without the "pink noise"? Then would not have to edit each manually. Just download, copy to card to the library, and all.
Pink noise not completely stop, but I would like to have a choice.
Think strobe-records of Andrei Vadimovich (many sites, at least), made without noise. At least it is not audible. By the way, the records themselves are very nice and efficient, many thanks to the author.
By the way, I hope that the metaphor of vodka is not literal, and no pink noise does not lead to intoxication :)
Re: a Few questions
Post by Андрей Кабанков » Sun Jan 22, 2012 10:09
Agathonnot very clear why it is you.
If you want to use Navigator in quality relaxation with beautiful music and light, use discs audiostrobe or Svetlitsa.The session is designed to achieve certain conditions and effects, removing the pink noise you will lose their effectiveness.
Ирина-К
Re: a Few questions
Post by Ирина-К » Thu Jan 26, 2012 13:07
I have to work with the Navigator have any questions:
-Is it possible to use two sessions such as morning energy and then immediately the session on solving problems?
Or mandatory what is the time span between sessions?
-Principle 2 glasses of water is saved as when working with disks On? Actually, I drink water before and after otherwise it is simply impossible, thirsty and a glass of water.
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 26, 2012 13:21
Irina-K
Break between sessions - not less than 3 hours.
Water is better to drink than not to drink... :?
Сканер
Re: a Few questions
Post by Сканер » Thu Jan 26, 2012 20:53
How to connect GPS external source vosproizvedeniya CD or flash player?
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 26, 2012 21:03
Сканер wrote:how to connect to an external GPS source vosproizvedeniya CD or flash player?
At the top of the plug with the arrow inside the circle.
Сканер
Re: a Few questions
Post by Сканер » Thu Jan 26, 2012 21:39
Well that was easy )))))))))))))))) Only wish that the sound and strobe worked. that is the question))))))))
Re: a Few questions
Post by Андрей Патрушев » Thu Jan 26, 2012 21:47
Сканер wrote:Well that was easy )))))))))))))))) Only wish that the sound and strobe worked. that is the question))))))))
Ah Yes, by default this feature is disabled. :? Activated via settings - see the user manual.
Сканер
Re: a Few questions
Post by Сканер » Mon Jan 30, 2012 21:33
Kind of hooked. Please advise what seciu use it to listen to CDs, because CDs and sesii mixing is not recommended like.
Димас
Re: a Few questions
Post by Димас » Mon Jan 30, 2012 21:43
Scanner
The discs if the discs or audiostrobe Andrew P., tapped separately from the sessions.
