What player to listen on the computer? Please give ready, pliz
Dear friends help no result
. Listen to the brain Massage 1 times a day, 7 times. Player Aimp3. It might be something more(all sorts of plug-ins). If you can tell special-tuned player. Thank you for your attention.
Re: What player to listen on the computer? Please give ready
A. Jordan
About the results we can say after three weeks...
Thank you. Answers happy.
there was such question : for the first lesson with a mm for 3 weeks is recommended to listen to (forgot what exactly) nekii low frequency (actually a question) program "massage brain" can be replaced with these "initial" session ? the fact that mm already ordered , but delivery times have changed (not in my favor) dedicated a couple of days wanted to devote to the study of mm and everything connected with it , but now as some other time , but that really was not to lose time in vain may be you can start with audio "massage brain" or "Explorer" ? players really very primitive cell phone, мп3плеер, SOFTWARE ,music center or all the same, these programs are designed only for mm ?Андрей Патрушев wrote:A. Jordan
Tomsk
You can start with the Explorer (on anything).
and will be listening to "Explorer" , that part of the required "program" which recommended for the first 21 th day to use mm ? and all is possible more in detail about these first sessions , what to listen to ? and most importantly why or what's the point ? (just a little annoying to me this moment! what if I found something in mm "your" will be into it, etc., etc., and then the result: the side effects because I didn't start with what is necessary)Андрей Патрушев wrote:Tomsk
Thank you.
To mm, the Conductor has very little to do with, but I would recommend to start with him.Томск wrote:and will be listening to "Explorer" , that part of the required "program" which recommended for the first 21 th day to use mm ?
On mm you have to start with relaxation (in Pathfinder, even a special Sabarmati to do).
No side effects, except as specified herenot.
I agreeВоффка wrote:By the way foobar2000 is a good player, of course all settings to "default". You can download it on foobar2000.com
