Session improv
why do we need session improvement?
tell me what session is favorable for out-of-body travel or osoznannogo of snovidenija?
once I had an out of body experience after a session of deep sleep.
Re: Session improve
TSL
This name applies to the sessions, not their results. That is, these session all the time randomized...
Re: Session improve
Good day to all!I would like to know what exactly podnimaetsa the word improvement?That is, if I understand CORRECTLY after listening to these sessions, the BRAIN becomes most prepared for this kind of SOSTOJANIEM that is, as it remembers them or what is better or these sessions have a different effect?I would very much like to hear from people who owns this issue.Thanks in advance!
Re: Session improve
Passer-by
Bit.
Improv (not improve) is short for improvisation, that is, each session is improvised (each time relative to a random set of parameters in a given range) in order to avoid habituation.
Bit.
Re: Session improv
Good day Andrew!That is how I understand it to those sessions which are already included in MM let and not at once but still over time gradually evolve ADDICTIVE that is, the effect of working with them becomes gradually lower,as the brain already KNOWS what it is!But to IMPROVISE to develop addictive can not in principle for the reason that IT gives ALWAYS something NEW and as a result TEMPORARY restrictions on her ALMOST(because nothing is eternal under the moon)are not rasprostranyayutsya!And hence is then created for each type of waves has its own SEPARATE program.If I understood you CORRECTLY or made a mistake somewhere
Re: Session improv
Passer-by
You are absolutely right.
Re: Session improv
Good time of day.Andrew, IF I understand correctly then, in principle, sessions of the alpha frequency it is POSSIBLE to listen in the first 21 day mm?And again, because those SPECIFIC alpha session are charged under the number,each have their kakoeto appointment,ONE RELAXING in the MAIN body and the mind,the OTHER is MAINLY for relaxation of body and EMOTIONS,and the third just as a GENERAL relaxation at the sound of the surf,and SO to say INHERENT in IMPROV,or so they say PURELY and ONLY give the effect SPECIFICALLY for entry into the brain at a given purity and all that is NO additional burden.Thanks in advance for the answer!
Re: Session improv
Yes, I almost forgot:if these sessions are REGULAR without any leaven and podtekste whether they listen to the newcomers,or they rekomenduetsa only to those who charged with clear data frequency is already weaker function?
Re: Session improv
Passer-by
Anecdote:
The patient comes to wrcu.
- What are the symptoms?
- Yes here, the head and well...na hurt...
The doctor walks behind the screen, takes great tablet breaks apart and delivers it at half the patient.
it's from the head, and it's from W...NN - look, do not confuse!
Anecdote:
Re: Session improv
Good day!Well, in General I so understood that it is POSSIBLE!
Re: Session improv
Passer-by
Re: Session improv
This joke is the credo of the medical unit now defunct but the Novocherkassk school of communication - there are all diseases(skin rashes, headache, indigestion...) cadets gave the message of pills askapena and sent back to barracks))) And most importantly, the pills helped)))Андрей Патрушев wrote:Passer-by
Anecdote:
