The goal of the algorithm based on the schema of the subconscious
the goal of the algorithm based on the schema of the subconscious.
1. To create the image of the target (it is desirable that all the details). (And that WAY, because more and more researchers agree that our brain, the subconscious, neural networks are holographic (and maybe psychic) principle).
2. Prioritize it (the Goal) for the subconscious, to make it Dominant.
(Here you can try to use visualization of goals, affirmations goals by rewriting goals, self hypnosis, Arbekovskiy "octave", etc. will Need to monitor and choose what "works" from You)
3. Create a base of positive experience in your memory / subconscious on the subject in the area of life in which the Goal / Desired Result.
(Here you can try to use visualization, positive experience in the past, affirmation of the positive experience Arbekovskiy "octave" technique TMO, Reimprint, etc. will Need to monitor and choose what "works" from You)
4. To work / to Recycle unwanted, unconscious, "blocking", conflicting priorities / dominant in your subconscious counter-dominant "blocks" (they manifest themselves as fears, complexes, losing automatisms, patterns, inability, etc., etc.).
(Here you can try to use a "working" technology Study, Processing, NLP, and maybe even Explorer A. Patrushev)
5. When the Goal is prioritised, the Bank experience created, "Block" worked, then --> to Remove the mind and trust "automatic", "autopilot" / the subconscious. To do what you are compelled by "internal impulse" / "automatic", "autopilot" / "inner itch" / the subconscious mind. (Here and the result is effective "castigators", Wu-Wei, life stream, etc.)
Continued: http://psy-online.info/dostizhenie-tseley
Re: a way to achieve this goal based on schemes of work podsosa
40 days, 40 nights.
From earlier esoteric sources, and now from research it is known that a new skill, ability, ability, etc., a new neural network in the brain (and maybe somewhere in the virtual mind, the soul) grown for approximately 40 - 45 days. Therefore, when studies, when working with the purpose of prioritizing goals, etc., it is crucial to continuously hold 40 - 45 days. Every day!
in order that was a big motivation, patience and dedication, you can consider the process as "training brain muscles" )). After starting to do some kind of sport the person is not counting on the fact that after one or two training, he will be able to go to participate in the Olympic games. This requires a fairly long, hard and continuous work on myself.
Here, by the way, you can still add with Malcolm Gladwell's "10,000 hours Rule".
" ... the idea that achieving a high level of skill in complex activities is impossible without a certain amount of practice time was expressed in studies on professional competence. Scientists even deduced the magic number that leads to mastery: 10,000 hours.
Neurologist Daniel Levitin writes: "numerous studies, the following picture emerges: on the field no question, to achieve a level of skill commensurate with the status of a world-class expert requires 10,000 hours of practice."
Good luck in your studies! ))
Additional info.: Of course, in the process of life, events, actions, etc. is constantly monitored feedback from actions from the results from the study, etc., and adjust and "elaboration" of neophilology, negative experiences, etc., until you reach (or changed or repealed) the result, which is installed in Purpose and completely satisfies you.
Interesting video on this topic from Dmitry Shamenkova.
To this topic to see it better from the standpoint of "it's about the subconscious and how it operates, how to reach goals, what motivates, etc.". See it from this perspective.
It is desirable to view two videos (carefully, deliberately).
The truth in them, Dmitry says that deliberately to change the priorities of the subconscious mind, memory Bank, etc. we can not. Practice shows that we have the power to make and to change your life.
Lecture by Dmitry Shamenkova at the XVII world Transpersonal Congress:
http://vimeo.com/21364632
Presentation of the system of informed health management (Dmitry Shamenkov):
http://vimeo.com/17497752
Scheme to this video:
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
Юрий555very interesting, thank you)
Normal Wikipedia with useful information, supported by unobtrusive ads(have not watched the video). Everything would be so PR)))
Method in the first post work - he constantly enjoyed, however, not the points...
- Шалтай Балтай
Стэллари wrote:of Stellari
Unread coordinatable: Wed Sep 07, 2011 12:48 pm
Юрий555, very interesting, thank you)
Юрий555 wrote:Юрий555
Coordinatable: Wed Sep 07, 2011 2:02 am
it's funny, the number of messages is the same....
this is the same
The subconscious (automatic system) will perform any realized priority/dominant - how destruction and creation. What in him lay, then will perform. Therefore, it is desirable to set such a Goal (such priorities)that is consistent with all parts of a person's identity, appealing to all parts of the human personality and, very preferably, for the highest good for yourself and all involved. This is a description of the desired Goal / Desired Result as the perfect moment / episode / day of his life.
PS If this material was helpful to you and/or you want somewhere to place it, specify, please, the link on my page: http://yuriy-pyatak.livejournal.com/
Thank you!
Thank you!
and it happensШалтай Балтай wrote:it's funny, the number of messages is the same....
this is the same
- Шалтай Балтай
Yes, it is necessary to think, that if SP to compare, again, a coincidence get?
will not work)) because it does not always work out the way we would like, Yes?))
Lancelot, Humpty Baltay
What are You so annoying?
The message on the site, in the appropriate thread made by a person and not a robot.
Piartes You to health, if you have something to say...
As for the lack of reviews, it seems, Einstein once said: "Thoughts, like fleas, - jump from person to person, but not all bite..."
I was not annoying. I just don't like neither the coaching nor cookingstove.
A PR for me.
And Юрий555 well done, attention to us is not paying.
A PR for me.
Well, I don't like, but so what?...Ланцелот wrote:I Just don't like neither the coaching nor cookingstove.
For the theme, as animated.Well, I don't like, but so what?...
PS Any irritation or negative emotions I have. Just not often you see a coach employed-not removing attendants with office plankton and unemployed couch, busy with self-promotion.
ZZY
Thursday, Jan. 1, 2015, 12:01 am
Symbolic simulation Reimprinting Study of the Processing, achieving the goal of improving the life +
About the dangers of the plan / "ideal scenario" achieve personal goals.
All that write here, this is only my IMHO based on my speculation on my experiences and results, and the experience and the results of many people's lives, which I had and have to watch.
Do you believe that "automatic system" / the subconscious mind in addition, that controls the functioning of the whole organism, but also has a huge computational capacity several times exceeding possibilities of mind / consciousness, and directs all our actions, behavior, automatisms, reactions, regulates emotional state, etc., etc.?
Do you believe that having a predominant dominant in his "system", the subconscious mind finds the easiest, best and fastest way to satisfy this dominant / implement the goal (no matter how useful or wrecking as it may be), and it scans the internal and external world for available opportunities to do so, and if such paths can not find, then creates and builds a new one?
Do you take into account the fact that the outside world and its opportunities are in constant change, and we need to very quickly do a lot of analytical work to not only find suitable opportunities to implement external and internal purposes, but also to build a sequence of actions, behavior, reactions, etc., and that will lead to the desired result.
Did you know that consciously do all this work is absolutely unreal?
Whether you really believe that being in a state of problems, accumulated negative experiences, their existing at the moment of tunnel reality, etc. you can consciously do to make a "working" plan / scenario realization? Really? ))
Do you know what effect it happens when the person made a plan / scenario ("perfect scenario") implement the plan and struggling to follow it? He ceases to see and respond to other available opportunity. Kept to the last for the case, which has long been giving losses and trying to "steer" situation (or Vice versa, goes from stable operation (because it is written in the plan is "start new case") when his "system"/the subconscious mind is not ready for this - not ripe, not enough experience, there is no dominant appropriate, not Mature the way internal and external, etc., etc.). While a person's attention is constantly rigidly stuck on the "how to" and not as it IS, as "rushing", etc.
The non-optimal situation is obtained and with the natural powers of man. As clearing "blocks", the mental stuff, etc., a person begin to manifest his nature of these abilities. But what happens if that person is bound by attention to some plan, the "ideal scenario", which he took himself or someone he helpfully advised (including society, clever books, the trolls on the forum)? Mm? Persistence in not noticing the natural possibilities (which are right under the nose are), not following the optimal path of life, not ... not ... not...
Well, this topic can describe the long and varied, but having ears to hear (especially if you understand "the Algorithm of achieving the goal based on the schema of the subconscious). And this little article is quite enough for some reflections and findings (whatever they were).
Good luck to all!
If this article like you, give her or me the link please (including when placed somewhere). Thank you! livejournal.com/">http://yuriy-pyatak.livejournal.com/<
Good luck to all!
- Шалтай Балтай
why do You write?Андрей Патрушев wrote:Lancelot, Humpty Baltay
What annoys You?
