Interested in buying portable option MM.
Previously purchased from You, NovaPro 100, frankly, unhappy with the obsolescence of the device (connected to a PC only plug-SOM), a primitive interface with navigation, and technically there is background noise from the internal amplifier/preamplifier of the device.
Everything else seems to work as it should, but the effect of the device was only after listening to depressi created by A. V. Patrushev, the built-in session, in comparison, are much worse (IMHO)
Light same effects from the points (kaleidoscopes), and generally ceased to impress, compared to what it was at initial use of the device. Was once beautiful rich colors with interesting images, and now muddy, drab color highlights (maybe it's a result of habituation).
Now I need a portable (field) version MM.
Because of the limited Finance I want to choose between the MindSpa InnerPulse and.
As I understand InnerPulse is a lightweight portable form NovaPro 100, also connects to upgrade to a PC via the com port, etc.
While MindSpa is a more modern version of portable MM, but another manufacturer.
That's just not found a complete description of the technical capabilities MindSpa,
interested in whether the MindSpa additional memory for reload sessions what are and how many there are built-in session (on site at the MindSpa, there is only a General description of the sessions, and details, alas, no – how many of them, playing time, etc.).
Is there a program for creating, editing sessions for this MM?
In the delivery are both points or one to choose?
Kintos (if available) a link to this information.
And tell me, from the point of view of the quality of the sessions and additional features to these MM (for example, the additional loading depressi, the amount of internal memory, features glasses, headphones, the ability to play AS or connect an external player to play AS), it is better to take - or MindSpa InnerPulse?
Alas, the link to the FAQ at MindSpa
http://www.avstim.ru/articles/index.htm
infected HTML/Iframe.B.Gen -> virus -> connection interrupted -> isolated
PS.: If similar questions have been asked, kintos link to a topic in the forum.
Thank you in advance.<
