Panacea. Additional modes of operation,load status
Post by Михаил_ » Wed Aug 17, 2011 23:28
Here will be published describing additional modes BJ Panacea (not to be confused with the modules, it all the same as in the rest of BJ 1.0-2.x there are but modes -other).
The Panacea provide "increased" the power of programmability.
In this regard, this type BJ can switch to different States and could financially support or automatically triggered modes, the setpoint software unlike the basic state bzh-a Panacea.
Re: A Panacea. Additional modes of operation,load status
Post by Михаил_ » Wed Aug 17, 2011 23:31
In the "main firmware" BJ Panacea made a small upgrade. It is similar to the modules affected simultaneously all previously issued BJ a Panacea. Ie is automatically installed on all the Panacea will continue to be present on both old and new (newly issued).
Upgrade called the state of the pulsar.
Can be called the subconscious or the operator. When you call this regime aggravated the symptoms of the actual condition of a Panacea.
This mode does not require special tools to include (any matrix for it is not provided). When you force a manual activation command is called "pulsar".
Post by Михаил_ » Fri Nov 04, 2011 21:35
In the main firmware BJ the panacea to make the upgrade. Added plug-in mode "resonance". It creates a more powerful sobludenie (Association) with holo-stickers used by the operator to clad the bracelets pendant. In particular this allows the use of the mass, which are the objects to which the operator is applied to the stickers. Increases event weight. Increases the effectiveness of the regime 2.6.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Nov 04, 2011 21:45
But if the sticker on the rock? (with skillful use)
Sincerely, MAG.no
Post by Михаил_ » Fri Nov 04, 2011 21:48
some are already about and did....
Post by Маг.нет » Fri Nov 04, 2011 22:00
:) Hmm, prikolnenkaya option, only for the rocks to go away.......
If on the wall in the high-rise apartment, as distributed W "infection" :)
Yes, the same heating system with hundreds of tons of iron and water, there is a kind of "icebreaker"....
Sincerely, MAG.no
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Fri Nov 04, 2011 23:15
But if not saying a word two of the same lot of labels will saleout, what will happen? Any "conflict of interest", "you half and me half," or a virtual doubling of the mass?
(Sorry, used as a programmer to debug-test-programs stavinga on the boundary, extreme conditions. From every crap of this type comes to mind)
Post by Маг.нет » Fri Nov 04, 2011 23:30
Well cover, well it's only a physical anchor for KO, I think "sharing" will not, but unauthorized access by different Operators may be, but each to his KO. Yes, and this mass is not for permanent use, you need to know when and where it is effective to add, and when to split off. "Icebreaker" is good in the Arctic ocean, but dreary and superfluous, where you can do easier means, this is the kind of "skillful use". To correctly assess the situation and the desired trend. I ground 2.6 used strictly as directed....
Sincerely, MAG.no
Post by bofara » Fri Nov 04, 2011 23:44
Михаил_ wrote:...Added plug-in mode "resonance". It creates a more powerful sobludenie (Association) with holo-stickers used by the operator to clad the bracelets pendant...
Маг.нет wrote::) Hmm, prikolnenkaya option, only for the rocks to go away.......
Sincerely, MAG.no
The car has a good ground... And if the person is to be around more time /taxi driver for example/, it's IMHO a successful solution.
Post by Маг.нет » Sat Nov 05, 2011 0:00
For your car there is a special program coming soon description.
And here the question is not that close, and the fact that you can use remotely.
Sincerely, MAG.no
Post by bofara » Sat Nov 05, 2011 0:01
Yes, it's described in detail that there is a special program, seen. But the car is not possible to use remotely? If the rock is not in proximity? :) Especially if the car perkiraan in nature - there will be a good Istochnik power ... Why do You rock?
Post by bofara » Sat Nov 05, 2011 0:06
Yes, you can say that a rock can have better composition for energy in relation to the car, but this is only an idea. :?
Post by Маг.нет » Sat Nov 05, 2011 0:10
This example is important not so much form, how much weight. When the mental control TO their products the distance is not so great a value TO and so integrated into the system, just an extra integration to increase the mass.
Sincerely, MAG.no
Post by bofara » Sat Nov 05, 2011 0:15
Then at least GIPP. If no engine... az
stom
Post by stom » Tue Nov 29, 2011 13:49
Маг.нет wrote:But if P-a sticker on the rock? (with skillful use)
Sincerely, MAG.no
Can technical details?
Post by Маг.нет » Tue Nov 29, 2011 17:35
Remove the backing and stick to the rock.
Rock charged is included in the system a Panacea of the Operator one element whose mass can be used.
Sincerely, MAG.no
stom
Post by stom » Tue Nov 29, 2011 17:58
Module Power stone or the Source of energy structures called?
Post by Маг.нет » Tue Nov 29, 2011 18:15
...not necessarily. You for example, you have 2 bracelets Panacea - standard and massive, one of them may be home, but it is possible to use remotely because it is combined with other your TO TO Your as Operator products a Panacea that allows him to always be "very close".
Sincerely, MAG.no
Post by Михаил_ » Fri Dec 23, 2011 13:58
Added the status of "General stabilization". Useful for those who are the "panacea" strongly enters into the bounce, reduces the degree of bounce is a relatively common condition "panacea", but leaves the depth of the processes as close to a "panacea" without switching to 2.9.
The condition is called the mental command "stabilization".
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Dec 23, 2011 15:25
1. Michael, working on the situation with Panacea may have a strong bounce, stabilizer No. 1 or module "Stabilization "will not slow down the processes already promoted situations that are in the process of elaboration?
2. At the same time can operate and be opened and rattling a few programs, whether it is possible to stabilize
the specific situation ,and the rest is left to "rattle"?
3. Can work in parallel and subconscious programs ,not opened and not brought to the conscious level,how can we support them?
Post by Михаил_ » Fri Dec 23, 2011 17:17
1.
N1 is a completely independent product is far from great product just the Stabilizer, although N1 (N is the letter of this and not the room) is also the stabilizer essentially their properties.
2.
I wrote that added CONDITION. It's not a module, and a modifier of the substantive work BJ Panacea in all its aspects. Naturally in this all the process will go a little differently, sweep slower, perhaps some will rise, in favour of stability was more.
3. This is not an absolute stability, and relative, in relation to a regime of "cure".
4. what if you use the panacea is seen by many as the chatter, rather to the concerns of the cocoon, which held the patch. But the endurance and the rating system all different, therefore added such a regime.
Post by bofara » Sun Mar 04, 2012 23:00
On the forum openmagic.org in section "Panacea" and reports on its use Michael_wrote:
attention. there is a program for miracle cure which is available in the "library" programs to.
is called T1. write the matrix, or take the sticker and give it the command to copy water T1.
drink
watching sensations in the body (can drink a little, from a teaspoon from).
well, to copy give часа4
...really increases energosaving and really an adaptogen...
...the above water T1 is not natural and cellular water. Before it was stored in the memory of the panacea (for which I used the holo-stickers for the accuracy of the copy, not the matrix), this water was artificially synthesized and has a number of unique properties, as far as I know does not occur in water in springs and sources.
This can be useful for someone. :)
Post by bofara » Sun Mar 04, 2012 23:02
Ibid Constantine. wrote:
Made a Copy of the Water. Called "RG" is the Stream Hot. This is the name of the people, in fact runs from the mountains of ice. Does not freeze in winter.
Of the ball the opportunity to drink water and to brew her tea. After two weeks of drinking all of a sudden stopped drinking everything except water. A mug of tea brought to her mouth and paused to Drink more tea could not.
Maybe someone like who is experimenting with water.
to Put on a pot of water matrix, panacea or sticker, and to instruct that the Cure was moved to the water RG.
СтАвР
Post by СтАвР » Mon Mar 26, 2012 1:02
bofara wrote:attention. there is a program for miracle cure which is available in the "library" programs to.
drink
but if the Bank is on the KV and on it write the matrix and to switch T1, they will complement each other or one will overwrite another?
Post by Михаил_ » Mon Mar 26, 2012 1:33
I dunno about difficult, but it is better to shoot with kV :)
Ie better to use separately IMHO.
Although I could be wrong. Ie in this case up to the end not sure there is the corner points which are not taken accurately into account.
Separately it just works fine.
What will happen when combining - need to check.
