Турист
Shape pendant orgonite
Post
by Турист » Sun Apr 10, 2011 21:16
Good day to forum users. I want to ask You. Going to make a pendant or keychain from ORGANICA.All the components you need are already there, but I don't know what form to betray him, and most importantly, can the form affect the operation of the device? And is it possible pine resin (which I want to use instead of epoxy) cure using the curing agent for epoxy? Thanks in advance.
Турист
- Has thanked: 31 times
- Been thanked: 129 times
Post
by к-13 » Sun Apr 10, 2011 22:52
What like, this and go(here the main comfort while wearing).
Cure pine resin and hardener will not work - when heated from your body it will still swim and get dirty. Easier than ever to cover(ship paint, for example, a layer of a few millimeters to several approaches).
Турист
Post
by Турист » Mon Apr 11, 2011 16:02
K-13 is grateful for the advice,I will try) When do you post a photo of the device)
P. S And if the second layer of coating lacquer and the same epoxy?
Турист
Post
by к-13 » Mon Apr 11, 2011 20:05
Varnish is also organic and also a dielectric(special conductive if not caught). There could be(in Lac) powder metal sprinkle, but will organic high density, then you need inside an even higher density to do otherwise, efficiency falls dramatically... There is an option varnish/foil/lacquer/foil/lacquer thick layer(so it will be something like the orgone accumulator on top of orgonite), but may not be very aesthetically pleasing to get...
МерКаБа - Posts:844
- Has thanked: 7 times
- Been thanked: 25 times
Post
by МерКаБа » Tue Apr 12, 2011 0:48
Tourist
Program the crystal. For example for the aura, unconditional love, etc. in addition, it greatly increases the intensity of the radiation of the crystal in Bovey.
МерКаБа
Турист
Post
by Турист » Tue Apr 12, 2011 2:56
Can fill regular epoxy (without pine tar) and not to morochte the head) I understand resin tint than anything that she was not transparent.
Турист
Турист
Post
by Турист » Tue Apr 12, 2011 3:11
МерКаБа wrote:Program the crystal. For example for the aura, unconditional love, etc. in addition, it greatly increases the intensity of the radiation of the crystal in Bovey.
The Merkaba and how to do it? For this we need what devices?
Турист
Турист
Post
by Турист » Tue Apr 12, 2011 16:30
Thank you for the link. Now crystal of quartz for several days to be in the sea salt solution, but now before pouring ORGANICA will hold and mental programming.
Турист
димыч - Posts:480
- Been thanked: 16 times
Post
by димыч » Thu Apr 14, 2011 22:04
I used Indian prayer when casting
Let the beauty in front of me.
And behind me is beauty.
And me - beauty.
Beneath me - beauty.
Be around me a beauty!
from the film"the sunchaser"
when testing with the pendulum showed 100 thousand bovi, but there I still have a lot of other features
димыч
Турист
Post
by Турист » Tue Apr 19, 2011 1:02
Tell me how to add pictures to the message.[/url][/list]
Турист
Турист
Post
by Турист » Tue Apr 19, 2011 1:03
Турист
Турист
Post
by Турист » Tue Apr 19, 2011 2:57
That's what happened. For the first time I think it will come))
[img]D:\Р-Р°RSSR·Rre\New%20папка%20(2)[/img]
Турист
Турист
Post
by Турист » Tue Apr 19, 2011 3:10
The campaign photo you need to upload to file storage and include their link. Do I understand correctly? As usual directly from a computer failed([/url]
Турист
Post
by к-13 » Wed Apr 20, 2011 20:42
In reference to enlargement should be jpg, png or gif and no spaces between the tags...
Турист
Post
by Турист » Fri Apr 22, 2011 1:35
The effect of the pendant on my health which is incomprehensible. First time wearing it, after 15-20 minutes I felt cold in the chest, after which it was removed. Repeated experiments with him, the cold feeling is not caused but the feeling that the energy arrives and, on the contrary decreases, there is. What can be the reason? Maybe too great a density of metals in orgonite.
Share considerations.
With HC. Tourist
Турист
димыч - Posts:480
Post
by димыч » Fri Apr 22, 2011 20:30
but a pebble of some sort in there?
димыч
Турист
Post
by Турист » Fri Apr 22, 2011 22:45
The crystal had pointed form and from the Druze, (double-edged) length about 2.5 cm.
Турист
