[html]<div id="goforum"><strong>Dr. Jeffrey Thompson</strong><br>
<p>People for thousands of years used sound to access deeper layers of the subconsciousness, consciousness expansion and healing of the body. Songs, different sounds, Tibetan singing bowls, Chinese meditation gongs, and mantras are just a few examples of using sound for this purpose. </p>
<p>Today, using the most precise equipment, we not only have an unprecedented opportunity to observe in detail the functioning of the brain and body as a whole, but also to track changes that occur in the brain and in the body in different States of consciousness and health of the body.</p>
<p> Research projects in major universities across the country aimed to study the neurophysiology of the body in a state of meditation, deep relaxation, and the interaction of body/consciousness in the process of healing. In one study, used a simple technique of meditation 20 minutes a day, which caused positive changes in blood pressure, increase stress tolerance, enhance immune system and General improvement of health – even without use of a high-tech approach, giving the opportunity to bring consciousness into a state of deep relaxation. </p>
<p>Using this technology as a daily tool for integrating the body/mind and stress reduction, we achieve mass positive results.</p>
<p> Modern technology allows us to simultaneously affect the body/mind:<br>
1. The body's healing through physical resonance using sound frequency vibrations.<br>
2. The change of state of consciousness by the method of sympathetic resonance of brain waves with sound – Sync brain waves.</p>
<p> the Process of physical resonance like vibrates a glass of wine when exposed to certain audio frequencies. In this case we can achieve the vibration of certain parts of his body with the help of sounds, designed to healing. </p>
<p>My first experience in this direction was the chiropractic correction of the spine. Each vertebra has a size, density, and mass, and may, as well as the glass to resonate under the influence of a properly sized sound. With the help of sound waves can cause the vertebra to vibrate and return to a natural position. In parallel, the vibration affects the bones of the skull and the cerebrospinal fluid. Each body, each person has a different size, density and mass, and has a fundamental frequency that regulate cellular function. These changes can be observed in the blood.</p>
<p> the Brain is an organ. This organ has a unique size, density and mass. What will happen to the brain if it is to provide the vibrations at the fundamental frequency? The brain, like the body, normalizes its function, as will any other body. Because the function of the brain, coordinating all the other body systems, we will see a global balancing of all systems at the moment of impact the brain to its own single fundamental sound frequency.</p>
<p>Using the sound, you can achieve dramatic changes of patterns of brain waves and States of consciousness, what is observed in equipment for EEG, as well as the positive changes that can be monitored through blood tests, equipment for biofeedback and other, more complex techniques.</p>
<p> <strong>Bio-</strong><strong>Tuning® - uses the sound of your own voice to speed up healing</strong><br>
This process, which I call "Bio-Tuning®" (bio settings), became the object of my research after I left my United Health Center in Virginia and was organized by the Center Neuroacoustic Research in San Diego, CA, 1988</p>
<p> With the modern electronic sound equipment, we can distinguish frequencies up to one-hundredth of a sharp or flat between two notes on the piano. To improve the accuracy and influence on higher levels we must use the voice of a man humming base note. This singing plays a unique blend of harmonics and the overtons that you can recreate only your own vocal cords – your own "writing" voice vibrations.</p>
<p>This exact pattern matches your vibrational pattern that is used by your "Biological organic intelligence" in the first place, for the formation of your body from two cells, and to further its development, step by step. There is also a sense of recognizing vibrational frequencies of your voice in the deeper levels of the subconscious.</p>
<p> we will Then use this voice - tone frequency is used for balancing the body in the healing process, in a special table for sound therapy. This table has built-in speakers, so during the session, you would become that sound. It becomes difficult to distinguish where the body ends and begins the sound. You feel like you are melting into the vibration of your own sound and vibration of your own voice.</p>
<p> This is what actually is a mantra. You go to the great master who sees that the whole world is a set of vibratory patterns. He sees you as a unique vibratory pattern in the universe. He sings you the sound of a certain octave, you repeat after him until then, until you learn to know and yet not remember this sound, then you go and meditate, and sing to myself the sound themselves – resonate your own body from the inside, balancing, thus, your being to the very core of the subconscious.</p>
<p> for Example, an imbalance that can experience the person – physical, spiritual or mental – is the external projection of the only real imbalance – imbalance in the human consciousness. To reach the hearth of this imbalance and bring it back to normal is to achieve the harmony of oneself with its own I – the only way I can eliminate the cause of your pain and suffering.</p>
<p><strong>Patterns of sound frequencies built into music for positive changes in the functioning of the brain waves</strong>.</p>
<p> In a series of recordings based on these principles I have used sound frequency patterns built into musical fragments, whose influence on positive changes in the consciousness and functioning of the brain waves has been proven by the clinical method.</p>
<p> Accurate variation of audio signals in right and left ear, "modulated vibration frequency" affects the sympathetic reaction of the brain. This leads to the coordination of the activity of the right/left hemispheres of the brain and slowing brain wave activity in General, resulting in deep relaxation, reduces stress, increases creativity, enhances insight, inspiration and ability to solve various problems. This phenomenon is called "synchronization of brain waves."</p>
<p>the Lion's share of stress in our century we receive by the mercy of developing technology. These technologies, coupled with traditional techniques of healing and harmony, is able to deliver us from stress, which they themselves had provoked.</p>
<p> In this series of recordings we used three coordinated methods for bringing the body/consciousness in a state of deep relaxation and balance: "Basic sounds", "Sync brainwave entrainment" and "multi-Layered music" recorded in 3D.</p>
<p> Many sounds that are present in these records, we don't even notice. Certain sounds can awaken deep levels of recognition in the subconscious. We call these sounds "Basic sounds" – ie, sounds that are initially available to recognize our subconscious, regardless of race, gender and nationality.</p>
<p> <strong>"Basic sounds" awaken our organic/biological intelligence</strong><br>
Our first experience of sensations in life we receive in the status of the fetus in the womb. We swim in the womb in a state of temperature of the body weightless. The liquid fills the mouth and nose, suppressing sensations of taste and smell. Eyes are closed and we are in the dark – no sense of vision. The fluid is in the ear until the ear drum, but water conducts sound five times more efficient than air; thus, the sense of hearing is enhanced. </p>
<p>the Symphony of sound patterns, which we listen to in this period, cuts deeply into our subconscious for the rest of my life – the sound of bursts of water, sound of pulsation in the arteries, and the sound of voices. This is our first experience of "Basic sounds".</p>
<p> In the records of "Basic sounds" we hear these sounds. Each of these sounds is separated from the others and "masked" slow or speed up. Changing the speed of sound, we suppress rational thinking, which is no longer able to recognize them, and plunge into the subconscious, which detects these sounds and react to them. With just one feeling organic/biological intelligence, the same intelligence that nurtured our whole body of the two original cells, will be awakened with sounds of the same body.</p>
<p> <strong>Experiments with sound have led to stunning discoveries</strong><br>
When recording human speech slows down or speeds up, interesting things happen. If these records are accelerated three times (the pitch is increased by three octaves), human speech patterns begin to resemble a bird chirping. Acceleration on eight octaves makes the human voice like the creaking of a cricket. Delayed for three octaves of human speech resembles the sounds of dolphins and at eight octaves – the sound of the ebb and flow of the ocean.</p>
<p> Interestingly, records the human voice resemble the nature sounds. What happens if we slow down the sound tresana cricket? Then it sounds like a bird chirping. Slow the bird sounds sound like the sounds made by dolphins, and the slow sounds of dolphins – like a human singing.<br>
Renowned psychiatrist Carl Jung (Carl Jung) would be happy – it fits his theory of the "collective unconscious". </p>
<p>the level of the subconscious that we all share, deeper than our personal unconscious mind filled with universal primary image ("primary recognizable" images, like the "primary recognizable" sounds). In this sense, the collective subconscious is a greater access to my body/consciousness to the planetary level of my collective unconscious, which knows how to "grow" a planetary ecosystem, which is part of my personal body. It's like if you imagine the entire universe as a single organism, consisting of many separate parts built on the same model, but with individual variations.</p>
<p> <strong>Revival</strong><strong> miscellaneous</strong><strong> levels</strong><strong> subconscious mind</strong><br>
In 1989, I spoke with an engineer in the aerospace industry concerning sound recordings from the Voyager. The records were obtained when Voyager passed by the outer planets of the Solar system – Jupiter, Saturn, Uranus and Neptune. These NASA recordings from outer space received in the form of charged electromagnetic particles (ions) in magnetic fields of planets vibrating at the level of human hearing, sounding very similar to ocean sounds, Dolphin sounds, sounds of the choir singing voices, the sounds of crickets and birds. </p>
<p>There were also other sounds too strange to identify, but seemingly very familiar. I wonder what the rings of Uranus produce sounds similar to the recording of the sound of Tibetan bowls, delayed to receive their subtle harmonics. So maybe this is deeper and more extensive the level of the collective subconscious, which knows how to "grow" a planetary Solar system, which is part of our Land – and from which came forth of my own body?</p>
<p> <strong>Can we consider these sounds deeper level of "collective subconscious"</strong><br>
These three classes of sounds ("Basic sound", "Sync brainwave entrainment" and "multi-Layered music") included in the sound track, some of the records, intended to evoke the deep layers of the subconscious.</p>
<p> it is at this deep level, our body will of the two cells of the same internal system, which daily directs our body and coordinates its functions. Here is the info about our issues and how to address them.<br / >
That's what we mean when we talk about "Basic sounds" and use them to access the deeper levels of the subconscious with the aim of healing, relaxation, balance.</p>
<p> These sounds are mixed into the sound tracks so that they could be recognized not only by rational thinking. Some of the natural sounds on these records are indeed the sounds of the human body or the cosmic sounds.</p>
<p> Synchronization of brain waves can be monitored using a technique called "Synchronization of brain waves". This technique includes the special pulsation, causing a sympathetic reaction in the brain.</p>
<p> Synchronization of brain waves is part of a larger brain function called "biological sympathetic oscillation". Our biological "clock" is configured on the external for space: full cycle, a full lunar cycle and seasonal cycles are just some of these settings. The body is adjusted to the powerful pulsing cycle, whose influence he undergoes. In this case we can create powerful sound frequencies pulsing at exactly the speed of brain waves and causes brain waves to change to meet these sound frequencies – i.e., to synchronize with sound pulses, changing the state of consciousness.<br>
From many studies we know that certain deep relaxed state of consciousness creates specific patterns of brain waves, which is reflected in the EEG monitors.</p>
<p> We also know that by synchronizing brain waves we can cause brain waves simpaticski "capture" an external pulsating sounds at their own speed. This gives us a tool for soft regulation of the functions of brainwaves and consciousness in order to bring it into a more relaxed and balanced state.</p>
<p> all of these sound tracks pulsating frequencies built into every sound you hear, including the sound of an instrument, voice, nature and the cosmos. Used frequency – is often the alpha and theta frequency brain waves. The condition of the brain caused by these frequencies, this state of peace and relaxation, bright visualization/imagery, enhance the ability to solve problems, a state of insight and intense creativity.</p>
<p> When we are creating these sound tracks, ripple synchronization of brain waves is inserted in the instrument sounds, sinhroniziruete my own brain waves and results in my own state of consciousness into a state of creative activity – that which is the origin of the music that you listen to.<br>
Certain types of sounds and music clearly reproduce the state of relaxation, inner balance, healing and visualization. In General, it is certain types of lyrical, flowing melodies and certain combinations of chords. Certain combinations of chords to create an atmosphere of peace, of mystery, of reverence, of sincerity and openness to new experiences.</p>
<p> To all the fullness of the use of sound effects and information, brain pulse waves recorded in 3D, it is best to listen to these recordings with headphones, because the images of the left/right sound must be completely separated from one another. You should also lie down and close my eyes. You will hear how the sound floats around you in three-dimensional space. A similar effect can be obtained, and with speakers if you place them clearly on the left and on your right. This way you will always feel like certain parts of your body resonate with certain sound tones of music.</p>
<p>Source: <a href="html</a">http://www.neuroacoustic.com/newmil.html">neuroacoustic.com/newmil.html</a>
Translation: Vladimir Nikonov</p></div>[/html]<
Sound medicine for the new Millennium (article)
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
Александр С
- Has thanked: 13 times
- Been thanked: 2 times
Re: Sound medicine for the new Millennium (article)
Vladimir, good evening.
Is there any song (text) to set up your own pattern?
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
he smiled to think of it, just some: 5 years, 7 months, 30 days, 21 hours and three minutes
deloff-the
deloff-the
