IC 1M or Radionic
Good day! Decided to buy SK 1M or Radionic RAD 2400HD (5 RAD).
Of course I understand that prices are not commensurate, so I think to wait another week and buy radionic or starting to buy SK 1M
Share your experience please or Council!
Thanks in advance!
Thanks in advance!
These devices are different. If You have knowledge and understanding of Magic (and some tools) of Astrology, perhaps closer Radionic (explore the Manifest of the programs will be more aware of the possibilities of Radionics). If the "magical way" of You is not fully understood, it is better to entrust the UK. He's less pretentious and fitness of Operator, and more harmonious ways of implementation intentions.
He and the other devices - energy sources with the included algorithms.
If there is a more specific question or understanding why, you can extend the answer.
Sincerely, MAG.no
Sincerely, MAG.no
Appeal to those who are in the subject.
As I understand it, the IC contains protection against the fool, and how this in radionica? And if or how, it turns out that someone can hurt not only themselves(by accident), but someone(deliberately)? I'm interested in to the fact that nobody(well most people
) are not immune from the negative emotions. In the case of strong connection with radionica, can be realized in negative order(even if momentary)? Or any Intrusive thought forms that are not intended for the conscious realization?
Thank you.
Thank you.
What is negative emotion? It's an emotion at the bottom of its range, for whom it is certainly negative, but if the sending - HF-object (initially, or at this point in the upper part of this range), for many it will be felt and bear positive, the signal will pass through the upper part of their range.
Negative order - just a question of the same order.
As for the "someone" may hurt deliberately - perhaps, if he will have enough forces, means, and motives, by accident - is difficult, "ecological safety" of the subconscious to nil. As for the "protection against the Fool", just I just wrote.
Whether deliberately to take something negative? There is more a question of responsibility before the world and before itself. I will say this that with devices of the likelihood of success increases, and if a person sows a negative (although in an earlier post I mentioned about the difficulty of judgment, if not to touch philosophy and morality, and devices with these factors do not work, this man comes up with a different doctrine and restrictions that there was at least some sort of stability) while still using device - responsibility increases.
Sincerely, MAG.no
Sincerely, MAG.no
By the way, this is confirmed, however other words, but with sufficient understanding - in a similar context, some religious movements. Not being a follower of some religious sects, it is difficult to ottiliavej in the original, but for many well-known cliches in the same Bible. Where on the same page, "hit the brother you on the left cheek - turn right" and the other "an eye for an eye", with sufficient study of the question, the exact factors of context, you can just find the answer of coexistence at first glance, the two mutual contradictions which really are not contradictions, but rather is complementarity, fit within the single range is actually wider than it takes the average person in normal condition.
Sincerely, MAG.no
Sincerely, MAG.no
MAG.no thank you for the reply.
I agree. The dichotomy good-evil is very conditional and subjective, besides not full. I don't about it a little. Here is an example. Someone using SP or radionic(standing on a recharge of energy), in a big emotional explosion and wished a very specific situation against a specific person(I hope you choke... that you were dead.. to live on one salary
) and forgot about it five minutes( by the way, wanted then do not seriously, even though emotions were strong). Here we have nourishment from Radionics+strong emotions of the person+visualization at the time of "order"+no waiting the execution of this "order." Likelihood of execution is significantly higher than when just an evil wish. Whether there were at whom similar problems? Is it even possible such a situation?
Of course, subconscious filters, but at the time of "righteous anger", I think it will take everything at face value. And most likely, it is not in the subconscious, and in attitudes, there have been superseded. That is, kill and not worried on this subject (men at war, maniac, etc.)-and all good, no conflict and no filter( there is, but the other one). We can consider a situation that once happened, then so be it(fate,etc etc). It regards morality. But the responsibility, in my understanding, is that the channel opens on both sides. And here at once the question arises, the same stoppage, as I understand it, works like a nipple,-the operator does not preclude, but on the contrary-very even. And the question is: if the operator had the impact that aroused opposition, and stoppage opposition neutralized, it turns out that she takes responsibility
and do what you want??? It seems to me that in the case of feedback of the world to the actions of the operator, stoppage sees this as the continuation of the situation created by the operator and miss it. Likely I that do not understand or with stoppage, or liability.
I will be glad to explanation.
So that's about responsibility is precisely the issue.
Responsibility - readiness to go that way to solve their life problems. If you do not believe or consider inadequate or fear the consequences, the more likely the subconscious will turn on the filter and will not let pass this way. In principle, this is "foolproof".
Just a "bad idea" may be such as to damage - lowering the frequency in the range of the opponent, but this is not enough to run the current process-the algorithm. To understand "bad idea" (instant, point), which with the necessary factors may run a "destructive" algorithm (process), but may not run... in itself initiating the idea may not be for many different reasons, including "security filtering" of the subconscious mind of the Operator, based on the degree of responsibility taken.
Sincerely, MAG.no
Sincerely, MAG.no
Yes, I agree. And here it is appropriate to talk about the positive and the negative, but just a random thought. And even if the operator has the power of a single thought, then a control of your thoughts must have. And in this case, random thoughtforms will not, or they are modulated life strategy so that automatically fall into the area of responsibility.
MAG.no, thank you for your answers.
Of course without the control anywhere:) and that idea should have thought...Димонъ wrote:much control of my thoughts must have. And in this case, random thoughtforms will not, or they are modulated life strategy so that automatically fall into the area of responsibility.
Another point, not all thoughtforms are accepted by the mechanism Operator for execution, there are still some other factors. Let me put it another way, a thought form is subject to the fulfillment, when there is a certain state (position), the necessary energy and momentum of the decision. Other thought-forms in most of the dreams...
Sincerely, MAG.no
- Мастер ДАО
All the good time. I wanted to answer some questions-the wishes of the distinguished Mr. Dimon,but did not work. Helped a Friend to mount the front Room window in her office....
"I appeal to those who are in the subject.
As I understand it, the IC contains protection against the fool, and how this in radionica? And if or how, it turns out that someone can hurt not only themselves(by accident), but someone(deliberately)? I'm interested in to the fact that nobody(well most people ) are not immune from the negative emotions. In the case of strong connection with radionica, can be realized in negative order(even if momentary)? Or any Intrusive thought forms that are not intended for the conscious realization?
Thanks."-
... And that is how I understood it, about some of the Possible negative manifestations of a certain personality in terms of Negative mental nature, and possible Enhanced and accelerated implementation thereof through BZ and so on down the line some devices. I have already plenty of observations for your friends and clients. They basically through me became owners as a makeshift 1.0 and 2.0 Standard, and even a few 2.5 and 2.6. Well. The most recent case of succession of all the others. Addressed as it is to me, my Client,a certain Ms. N, 09.03.2011 of the year 18.34, for divination and advice-help in understanding what issue here with an observation. She BJ 2.0 purchased through me and with my help,plus all preliminary explanations and advice,as well as printouts from the Website about the Technique of use and Security were received. So after the start of wearing,over a month, she began to notice some negative qualities and circumstances in your existence. The fact of the delay to work,then some small issues with finances and so on. Like not much,and a handful to all the other problems, spoils her blood and life. I hasten to mention that I'm her long enough and because I know the very delicate circumstances in life. Well. She's not a complaint ,but the task. Began to talk and converse.And Clearly came to the conclusion, after an hour of conversation that this is not the BJ was guilty,and in itself as that's too many negatives, first and foremost, ON the LEVEL of THOUGHT. And ambushes there any well 5 people accurately enough.She then began to think about all this Kut ' current more constructive with my help. Here in the Caucasus the local mentality
very interesting so to say
. Realizing and accepting this fact, We asked the office of Heaven here is the question: "What can She Ms. N, their efforts,actions or other conscious activity available to her plan, make to do exercise and so on to CHANGE Your NEGATIVE MILAFON To change Themselves and to change the of her Life(as a result of its thinking activity) to Helpful her way?"..Like this.
Received the following response:
"the lake and the sea /customize/ in a very melancholic mood. Cast your bait on the misty shore. If /you/ meet together of the dragon and the rabbit /your/ glory and /your/ wealth will be limitless."
For me as specialist in this thread, the answer is immediately given a full Understanding of almost all problems and most importantly, leaving it to a new level of Thinking and Living... Here I will try to explain you some points. The first is the phrase: the lake and the sea /customize/ in a very melancholic mood. What it means in the context of this Situtsii and specifically this man. The fact that She is so at that time mired in the Narcissism of their own created Problems that Only the Appeal of His attention on Some objects of natural plan(clean and clear) it would help to Change and redirect the focus of attention and the more clear your mind from all soemething level. And the second layer was a hint that in past prophecies for her("I Have all the moves written down"
), the recommendation was given in the summer, and having gone to the sea,she still could afford something to change not only in consciousness but in life. To this checked on her and for her way again and was advised to go. But the third layer there is a primitive character. Because she is a woman,the state of MELANCHOLY the last time,15 years have become simply habitual. And in the most NEGATIVE way.
- "Melancholia (from al-Greek. μελαγχολία "melancholy", from μέλας "black, dark" + χολή "bile; anger") — in the Russian terminology "dark insanity" is a term that denotes the beginning of the XX century one of the types of mental disorders. The concept close to the modern concept of depressionand remotely with a melancholic temperament.
According to the Encyclopedic dictionary Brockhaus and Efron:
The essence of the mental changes in melancholia lies in the fact that the subject is sad, depressed, not motivated, or not sufficiently motivated by external circumstances, and that mental activity, it generally is accompanied by unpleasant, painful torment.
However, the consciousness is dominated by submission, corresponding to a sad mood; fantasy and memories of the sick is aimed solely at bad things and events, he sees everything in a dark color, nothing pleases him life becomes painful, incentives for activities weaken or absolutely disappear, he is inactive, indifferent to its vital interests, says the best outcome is death, often by suicide. In many other cases, on the basis of this oppressed state of mind emerge an absurd delusions and deceptions of the senses.
As for the former, they mostly have the character of self-blame: patients accuse themselves of any offence or crime against religion or morality, is often attributed to himself absolutely fantastic, horrible actions, waiting for them such a monstrous punishment. Also delusions of self-accusation, there is also delusions of persecution or so-called delusions of negation: nothing, the people disappear, the world and life end, etc.
A special kind of melancholy are those cases in which delirium is predominantly hypochondriacal in nature, such as patients feel that they have all the holes of the body the overgrowth, gut rot, stomach failed, they turned to wood, glass, turned into an animal and so on. Deception of the senses for the most part, on the contents of his stand in accordance with the ideas of delusions: patients hear the curse, the groan of the children, the rattling of chains, see the preparations for the execution, the bodies of their loved ones, smelling of carrion and sulphur, crawling snakes through the body.
In cases where melancholy takes place exclusively in the form of causeless depression, and when the consciousness is filled with the above ideas of delusions and hallucinations, at times patients are subject to attacks of severe melancholy with fear and motor excitation, and under the influence of these attacks sometimes fall into a frenzy (raptus melancholicus). Regardless of melancholia is generally accompanied by a decrease of the total power due to lack of appetite and refusal of food, and because of the painful changes of the processes of digestion, metabolism and circulation. Mostly, furthermore, persistent insomnia.
When one of the varieties of melancholy (the so-called melancholia attonita) is observed for a long time, the stillness, the numbness of the muscles. Quite often melancholy is not independent of mental illness, but only episode one of the stages of complex mental disorders, such as circular, periodic insanity, mania, etc.; then it does not last long and is replaced by other symptoms.
In those cases, when melancholy is a mental, an independent disease, it always lasts at least 8-10 months, and then the patient can completely recover. If recovery does not occur, the melancholy, or becomes chronic, or is converted into secondary dementia, and the disease has become incurable. In any case, in the long melancholy intensity sad affect, mental pain is gradually decreasing. A significant portion of patients with melancholia die from suicide or from General exhaustion, due to inadequate nutrition. When protracted course melancholia predisposes to the development of pulmonary tuberculosis. Causes of melancholy coincide with the reasons of mental diseases in General. Treatment is best performed in specialized institutions.-WIKI"
Almost 60% of all mentioned above in the excerpt from WIKI, it was in the so to say "the Best
"form. And the WATER,in the most simple and primitive Symbolic manifestation of this is FEELINGS. The ones in the right and true individual performance and generacii make a woman WOMAN WITH a capital Letterand all the rest of them as themselves, Women and killed. And slowly and brutally,with the stretching so to speak. First and foremost, avoid immersion in YOURSELF and YOUR CURRENT self-generated FEELINGS AND she Was provided at the level of Targeting. The first two layers the values were also brought to her mind during the second hour of the conversation.
The next half hour-hour was devoted to analysing the Other part of the message: "Throw your rod on the misty shore."As it turned out,under the influence of the amount emocionalnij States under the term Melancholia, the mistress just stopped and ceased any movement of thought in the planning level as the present and the future. Bearing in mind the Rule (briefly) "Knock and ye shall Find,"it so to speak has ceased in this way, even to think,not what to think, and to Want ITSELF in the course of the analysis did not assume in principle. It was brought to her mind that if SHE doesn'T That there Yourself Plan or just STUPID to ASK(God,Heaven, or is there some Third Power,By faith, everyone should understand this),THEN HER LIFE WILL be NOTHING. He said that at least Seeing prospects now, "Misty Shore", Do at least some kind of Request to the top, "Drop your line". Or, as in the famous Joke, "Well at least you buy a lottery ticket"...
Here are some such interesting Answers and Discoveries I had while working with her on the Topic of "Negative thoughts and work with them". Of course this applies primarily to only herself. Because many people have many and not only of Opinion but just Situations. I think as a General way nobody will use. I'm Strictly for the individual approach to every person and to all its questions and situatsiyam. But the principle I have tried to convey. After her work, I only a couple of times with her called up,and the description of its situations,it seems there are some positive things and changes in her life. But I stress. Here we have to consider Everything from the Inertia of Matter purely Personal to the individuality of Each. So a Quick result, I never wait. Especially in the Very severe cases. The other part of the Divination only indirectly related to the topic of the conversation given here and I was not there to decipher them. it will be interesting if will continue then. Sincerely Your Master TAO...<
Thanks."-
), the recommendation was given in the summer, and having gone to the sea,she still could afford something to change not only in consciousness but in life. To this checked on her and for her way again and was advised to go. But the third layer there is a primitive character. Because she is a woman,the state of MELANCHOLY the last time,15 years have become simply habitual. And in the most NEGATIVE way. ------------------------
