disks for the alpha theta and Delta States
Зерванадья
Hello.
is there any special disks for entry into the alpha theta and Delta state( Delta about another question or is it possible).but without any installations and tselenapravlenno such as mind machines, relaxation, and osoznanno dreams, etc.
as far as I understand the theta state, you can use set(or selectively from it) "Theta meditation "Patrushev?
I want briefly to alpha to theta and do the rhythm to record my voice mantras and listen to(or set at night).
zapisati on the recorder the whole thing--does it make sense in terms of how to survive if the rhythms and frequencies needed
Зерванадья
suitability of the author--how the disks fit zvezdy wanderer
massage of the brain.and ultramesh.-owned for writing mantras on them with your voice?.I autogo otlicials that they work with the brain and the mantra is also to some extent affect the mind in pewww turn
if these claims some suggestion, and voice?
Does not fit.Зерванадья wrote:how suitable the author drives--how fit zvezdy wanderer
Зерванадья
Зерванадья
otvette more please on this issue-
zapisati on the recorder music center the whole thing--does it make sense?-in terms of fact remain whether the rhythms and frequency needed? the cassette recorder is not
In WAV format everything is saved.Зерванадья wrote:otvette more please on this issue-
Re: disks for the alpha theta and Delta States
and the Delta rhythm be like? for him, what music is(cat Yb it is called), or only in the mind machines is the fact that ETS
saw article where they write that muzyaka cat in the clubs causes the Delta rhythm--but pontano-if the Delta rhythm usually in a deep sleep-that is why picucci all this disco music is a river Delta?
I usually did not cause state changes
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
Andrei Patrushev as I have already asked about the night proslushivaniya disk and/or something else (I think exactly was it about the Guide to listen to all night in a dream) - the answer was a CATEGORICAL NO! Night need to sleep, to replace normal sleep effects, even potentially benefiting - not! link to quote can not give, unfortunately, for laziness to searchЗерванадья wrote:record ... and listen to(or set at night).
magic
No, the Delta rhythm from the periphery is not induced, only the electrodes.
Vladimir S.
and I mean electric shock??
those.e do not do so to enter into it? or what can you do?
I ctala about breathing choen often 60 times per minute, but it can be dangerous
To go to sleep.магия wrote:and what they can do?
Rostislav
I have no idea.
I have no idea.
