manufacturer BJ 3.0 N
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jan 04, 2011 17:00
Михаил_ wrote:charging version done
in file three of the mandala.
4 hours or more (up to 2 days) first is a base, the base state, instead of cleaning.
same - the second is actually 3.0
then again the same third - there is a matrix describing 3.0
then all 3 but in this order - inside second, then a third, outside - the first.
all 4 stages to wrap up the mandala which wrapped bracelet with foil.
additional reinforcement - the use of audio or audio through the Amp.*
We will consider it my Christmas gift :)
mandala http://openmagic.org/gene3.0/g30_pre.pdf
audio http://mikesh.users.ru/audio/g3.0/g3.mp3
__________________________________________
*run track at the final 4 stage
Мирта
Post by Мирта » Tue Jan 04, 2011 19:31
Headphones on bag of mandalas and all of this will turn a foil-like screen from the outside world? Yes or no?
Post by Маг.нет » Tue Jan 04, 2011 19:48
Headphones in a bundle, preferably close to the charged object and all this in foil as a shield from the outside world.
Sincerely, MAG.no
Роман Н
Post by Роман Н » Tue Jan 04, 2011 20:07
Is it possible to charge the 3.0 L?
Post by Маг.нет » Tue Jan 04, 2011 20:33
anything that does not interfere...
Sincerely, MAG.no
Post by Маг.нет » Wed Jan 05, 2011 12:24
Михаил_ wrote:cell cloud 3.0 - clusters is different TO different from that TO 2.0 and it works a little differently. Both TO exist independently and do not interfere with each other.Cellular cloud 3.0 does not quite belong to this world, being phase-rozsynhronizuvalys with him, consists of some large entities, which aim at the provision of energy, protection, information gathering and other support functions. Reset version due to reset TO 3.0 is not possible, TO can be reset when removing 3.0 to consciously or the operator has access to the data structures(cellular).
Post by Маг.нет » Sat Jan 08, 2011 10:54
Who else besides me tried to use MM with 3арядке 3.0, adding to the audio channel you have the initiation of resonance on "light and color" channel (ColorTrack glasses)? The use of "glow in the dark paints-coatings"?
Interesting reviews...
Sincerely, MAG.no
Post by Маг.нет » Sat Jan 08, 2011 14:35
I thought "the best copy of" mandalas to charge - print on the laser color printer. For these purposes, refer to printing the salons, where the quality and choice of paper (choose to the touch, which is "not broken") and the possibility of increasing the format (A1, A2, A3, etc. according to need, depending on the size of the object charging), as well as "multiple reduction" of mandalas, placement of the "table" of several (perhaps tens or hundreds:)) on one sheet, for the application of-"implantation" in-charged 3.0-an object etc.
What ways and methods do You use for an efficient charging?
Sincerely, MAG.no
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Sat Jan 08, 2011 15:38
MAG no, you must be the only one decided to charge extra to use a MM. IMHO, I thinkis completely, unnecessary. Notice I said - I think. I do everything exactly according to instructions, have free access to a color laser printer, so at least on this account, do not bother, what I need and what size should I print. The only thing I copy the drawing multiple times on the sheet, increasing the density of the overall image, as well as you do, if I understand correctly.
Post by Маг.нет » Sat Jan 08, 2011 16:28
рыжая wrote:the Only thing I copy the drawing multiple times on the sheet, increasing the density of the overall image, as well as you do, if I understand correctly.
Multiple copying? The number of copies affects the "communication channel" of the mandala charger (at least connected to one "outlet" within the locality, premises). Think so, few (?) not essential, but at the same time a lot of WORKING COPIES of the same mandala, perhaps critically reduces the efficiency of the charging process (structural shift of the object with "active links"-mandala).
The copy is always different from the original, increasing the total number of copies, substantially without affecting the original, weakens the "charge" of each copy is directly proportional to their number. Copy this structural difference, the increase in the number of copies increases structural differences from the original due to their (differences) manifestations. It's like very well to see and... "find 1O differences".
More important is not the drawing of the mandala and its "binding" property of the power system (energy and structure shift = energy-vibrations of certain qualities). Mandala - "translators" of vibrations in a particular range to excite the resonance.
MM experimenting with at the moment, previously connected a "light channel" but in a different way. The effect was observed malopriyatnye. Compare with MM...
Sincerely, MAG.no
рыжая
Post by рыжая » Sat Jan 08, 2011 18:41
Маг.нет wrote: , etc. according to need, depending on the size of the object charging), as well as "multiple reduction" of mandalas, placement of the "table" of several (perhaps tens or hundreds:)) on one sheet, for the application of-"implantation" in-charged 3.0-an object etc.
Sincerely, MAG.no
Okay, in that case, be so kind as to explain what you wrote above.
Post by Маг.нет » Sat Jan 08, 2011 19:42
:)information for a narrow circle:)
Sincerely, MAG.no
Post by Маг.нет » Sun Jan 09, 2011 17:44
рыжая wrote:IMHO, I think it's absolutely unnecessary. Notice I said - I think. I do everything exactly according to instructions
Totally agree with You, why is that wise? Can be satisfied (sorry, it seems harsh for a device is 3.0 N, more to enjoy:)) by the manufacturer according to the instructions, but... in my opinion the statement "free to fly", gives a choice, that's it and learn... it's my choice.
Sincerely, MAG.no
PS Before that wise, it is desirable to have a working "model" to compare, to understand the increase or the decrease of efficiency have produced "samudraya".
Алексей5
Post by Алексей5 » Sun Jan 09, 2011 18:39
Good afternoon.
Sorry, not quite in the subject, what kind of bracelet is it?
.....which wrapped bracelet.....
Where this bracelet has a description, maybe a link?
Post by Маг.нет » Sun Jan 09, 2011 19:21
We are talking about the bracelet BJ 3.0 self-production. It is worth noting there are limitations its use is described here:
Михаил_ wrote:3.0 quite "special" version based on things is not quite normal. This is not an extension or amplification of 1.0-2.0, it is a "side view".
Work with 3.0 requires:
- increased "environmental" intentions, there is spontaneous realization of easy flying in my head of the thoughts.
- quite recovered energy in General.
- fairly well-balanced character
- some, preferably long experience with бж1.0 (from six months or more) or 2.0-2.x (from one to three months or more). Without it it is NOT recommended for all options is 3.0, I would even say that it can be dangerous as overloading of the psyche and energy.
1.0-2.x make a person considerably calmer, even as the cocoon, in General, carry out significant repairs on different levels.
-requires the ability to soberly assess their condition and, if necessary, abort the use of 3.0, i.e., it is not for hour socks, although someone may wear, but it may be too high load.
- 3.0 can be dangerous due to its effects that may not immediately succumb to mind control, very carefully to use it, knowing the risks and responsibilities to themselves and others.
http://www.mindmachine.ru/viewtopic.php ... &start=600
Sincerely, MAG.no
Post by Маг.нет » Tue Jan 11, 2011 22:59
рыжая wrote:I copied the pattern many times in the sheet, increasing the density of the overall image
the repeated process, when intended, can't be a bad power connection to the charging system. You the highest quality, make a printout of the Mandal?
Sincerely, MAG.no
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Sat Jan 15, 2011 19:12
MAG.no
Hello, Roman! You don't know whether an audio file of less size to make? And then 568Mb too much to swing :(
Post by Маг.нет » Sat Jan 15, 2011 20:16
Воффка wrote:MAG.no
...you can never download and charge without audio, and reduce... I think not worth to try. Unless of course he Michael_ on the divisible sections of the "not cut".
To save money (if expensive Internet), and if threading of the Internet channel are low, you can visit the Internet café. One hour cases (by our standards 60-100 rubles).
Sincerely, MAG.no
Post by Маг.нет » Thu Jan 20, 2011 16:04
:wink:News from the field:
Михаил_ wrote: :)probably the more matrix the better:) but is there somewhere an optimum
...review to 1.0 L.
Sincerely, MAG.no
Post by Маг.нет » Thu Feb 03, 2011 22:25
The result of the independent production 3.0: Image
http://www.mindmachine.ru/viewtopic.php ... start=1050
Sincerely, MAG.no ☝
Малыш
Post by Малыш » Wed Feb 23, 2011 21:54
Magnet, and you what material make bracelets?
Post by Маг.нет » Wed Feb 23, 2011 22:05
Procurement of polymer.
Air-bubbly...
The bracelet looks like the real thing.
Sincerely, MAG.no
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Wed Mar 16, 2011 21:04
Маг.нет wrote:all 4 stages to wrap up the mandala which wrapped bracelet with foil.
additional reinforcement - the use of audio or audio through the Amplifier.
this is the part that is not understood. This is the fifth stage. What is the sequence of mandalas should be?
Post by Маг.нет » Wed Mar 16, 2011 23:26
If you read carefully, it says about extra insulation in all 4 stages. So this is clearly not the 5th stage, and one of the elements each of 4-H.
Sincerely, MAG.no
Петрос
Post by Петрос » Thu Mar 17, 2011 0:38
surprised :) , Russian language is so rich in meanings :) especially on the forums :ay . Thanks for the response. I just missed you :) . Wait, that will start the stabilizer to do :aa
