Radionic devices
All kind time of day !!!
Anyone picking devices such as the RAD 2400HD ?
Picking the ' net and have not found any schemes or methods of manufacture.
Partially electric part clear(the N-tion number of generators-it's not difficult), but as it all comes together
in the common system, but still not until the end understand the design of the ring.
I'm afraid that the cost of these units is overstated mereno cool because.
The history is traced in the 90s went overseas in place of the transistor(integrated circuit) tube amplifiers at exorbitant prices.
Russian want cool freebies made with your own hands
the toad smothers to spend such amounts.
I propose to share opinions and links here, and on (ua3pkmСАБАКАrambler.ru.).
About me: on topic: Radionics-a beginner;
on topic: to do with your hands, use your loaf and not poor knowledge of electronics can much.
Photo "inside" is the branch of Radionics (one of the first pages). The scheme has been placed repeatedly by Humpty by Baltay et Forum. Radionic - mental machine. Wire and materials in the Radionics is important, but secondary. Mental formula (firmware) Radionics distinguishes one manufacturer from another, in point. In the Assembly to repeat everything, except the firmware (I guess here it is money and costs...) - organizing and administering the operation of the device.
Success in mastering!
Sincerely, MAG.no
Sincerely, MAG.no
MAG.no
Thanks for the reply.
I agree that a piece of iron not the problem, they are highly repeatable.
The firmware was created by one uncle to polzovania small circle of people, and the question is maybe it's GOD or even so when working with the instrument GOD is in the operator which creates the firmware for your device?
Just saying, no one, didn't mean to offend.
The answer can sometimes on occasion, don't take offense.
No, not GOD, only this man a relatively stable output. You can try to repeat, only "results" you need somewhere to take. In fact, the algorithms in the firmware a little bit, "catch", "to bind" and "to combine", so the filter to "improve" the structure of water, the interaction between the elements of the device. Others have not noticed... There are still differences on the materials used for orgonite. "Organizing" interface - version Manifest-programs, too, not just visual, but associated with a device process controlling it, as well organized, with the various thought forms, the understanding and need can be used.Руслан920 wrote:Firmware created one uncle to polzovania small circle of people, and the question is maybe it's GOD or even so when working with the instrument GOD is in the operator which creates the firmware for your device?
Do this until you get a stable result, Consumers think there is, and there already and the price to choose not choking toad:)
Success to Your endeavors! The stability of the result:)
Sincerely, MAG.no
Николай Гор
Simple 9 Dial
The circuit below is a bit more complex, it incorporates 3 mobius coils around a common quartz core. In very simple terms, the output is a 3 channel scalar interferometer. 2 channels are used to modulate information and 1 channel (center) is used as a carrier. The diagram should also give you an idea of how to mount the mobius on the crystal. If you are making the simple circuit above, you can just use one mobius coil instead of the 3 shown below.
Top of the circuits is a 'target' circuit. This decides where to send the energy. It is the one with 3 dials, and it drives the uppermost mobius coil on the xtal. The coil is in the outgoing stream of energy. You could make it with six dials also.
Next is a basic zapper circuit (see thumb at top of page marked 1a), a square wave generator. The zapper circuit drives the mobius center on the xtal. The coil is at the center of the energy field in & around the xtal. The center coil can be enclosed in a grounded shroud as shown, or a small ORAC. The shroud is an optional improvement. The circuit will work without it. It acts to reduce the EM emissions of the center coil so that the two tuning coils are influenced more by scalar / radionic data and less by the EM carrier signal.
The ground ballast is a cylinder of HD Ergonite inside of a short length of copper pipe. The ground ballast is an optional improvement, the circuit will work without it. It recovers some of the EM energy and converts it into Bioenergy which is injected back into the circuit. If you omit the ground ballast then connect the ground wire from the center coil shroud to the negative lead of the zapper output. If you bother to make the ballast ground wand as depicted above, it is important to ground the ballast point the wand directly at the output module from a location adjacent the tuning pots.
The Lower coil is connected to the 'trend' tuning circuit. This circuit decides what kind of energy it is that you are sending. The coil is positioned on the incoming stream of energy. The trend has 6 dials for finer tuning, and the target has 3 which imo is more than enough for accuracy.
The Crystal for this circuit does not have to be of exceptional quality - cracks / chips / inclusions are ok, but for a machine like this it should be at least 1" x 1" x 4" and preferably larger. It does not have to be a double terminated crystal like in the diagram. A cut quartz obelisk will work just as well.
The radionic circuits shown here are a very simple version, and variations on a basic wiring method used by many orgone & regarding manufacturers / researchers.
For more on regarding and Orgone, check out our Info and ebooks pages. For consulting ad custom output module or tuner design (a service for which there is a fee) contact me by email.
Jon Logan<
Jon Logan<
Николай Гор
[quote="Diameter"]This hour only realized that to make these devices easy. The main thing to understand a principle of work,properties, energy,relationship.
Here is a description of these relations as I understood is the "terrible secret"of all producers of Radionics. Current think it's not as scary as it seems))) Every manufacturer praises of a loved one ) a First device for reception of information then chain variable resistors or capacitors at the output of the transmission device ( starting from the crystal with a coil and ending with amplifiers and antennas) be the first device better to collect easy with the option of various upgrades or connect different output devices.Now also collect scheme almost like Demetra current 8 resistors just make the reverse (subtracting from 10)
- Has thanked: 1 time
- Been thanked: 10 times
Николай Гор
Link to article http://www.littlemountainsmudge.com/radionics.htm
The number of resistors here is based on several factors: the accuracy of the adjustment of the object( fine and coarse settings either,they are all equivalent), the second most important factor from the realm of magic( the device is essentially from the area the subject of magic) you are trying to obtain exact factors of its receipt( at the site of friction for me is the best or using a pendulum, etc.) and at this moment lay somehow his energy which will work(or rather reinforced energy stored in the crystal with ORGANICA or just crystal) By the way of the device and the crystal after the change program should be clear (one way or another, to erase its inherent power or otherwise to tell the program) psychologically than btle resistors you set up ( see Radionics with 38 resistors) the better focus and more accurate to tune the result)There are a few more factors but this is the jungle and, in principle, not important.
Николай Гор
All kind time of day! Today rode your device,the task was set on a positive and at random. The day was a great success! have been many unexpected coincidences, met a lot of nice people,and came quite unexpectedly to the concert gr. aquarium.!!!!even with the musicians communicated a positive hapnuli mountain!!!!!!!!!!!
at almost no cost.
Николай Гор
Graz! Then, a friend from England with whom I communicate only with great difficulty
(taught in English) expressed this idea : makeshift Radionics work for the better result of the industrial impact of the labor invested(spent energy) Only when the change of task don't forget to "reset" the device, some do it with the help of ultraviolet light, others only a few times wave a permanent magnet near the device, some signal "white noise" good Luck
Николай Гор
The first two Radionics collected at all the boxes from under the Shoe
Both options worked, worked out the scheme. There is a modest conclusion is that the resistors it is better to connect a rheostat and not potenziometro in a serial chain(also spied on some website) it is Better to take wire peremennikami with resistance from 4.7 K to 10K connect in series 12 pieces the result is excellent. Now looking for the crystals on "fancy" device.Body found solid plywood from the step measuring device, sorry, not enough time.
...I think the variable resistors not so much for settings, but for fixing of individualization.
...the more resistors set up, the more you show your personality fixing installation intentions.
...of three (per channel) a couple of peremennikami - sequentially, the third separately (picked up from Karl
...Radionic can work without psyleron and generator (no network), if living with the Manifest program (experience).
...improves the experience (and the sense of feedback) audio channel (like in SP), but can work without it.
Even a superficial study (well, just the fields in the table settings-settings) the program Manifest may clarify 1 note (there is the option automatic configuration "of peremennikami").
Sincerely, MAG.no
)....Radionic can work without psyleron and generator (no network), if living with the Manifest program (experience).
Sincerely, MAG.no
As for the "mental ties", will greatly help the understanding of their deployment
. The roller may suggest:). Excerpt: <embed src="http://img135.imageshack.us/flvplayer.swf?f=Pfsm"width="320" height="260" allowFullScreen="true" wmode="transparent" type="application/x-shockwave-flash">
Taken from: http://www.mindmachine.ru/viewtopic.php ... &&start=25 if you are interested in the full version of the video download link
Sincerely, MAG.no
. The roller may suggest:). Excerpt: <embed src="http://img135.imageshack.us/flvplayer.swf?f=Pfsm"width="320" height="260" allowFullScreen="true" wmode="transparent" type="application/x-shockwave-flash">Taken from: http://www.mindmachine.ru/viewtopic.php ... &&start=25 if you are interested in the full version of the video download link
Sincerely, MAG.no
Николай Гор
I fully agree with Mage.no I was trying to explain from a technical point of view ,you are magical(spiritual?) it is difficult to reconstruct the way of thinking. I want to ask You did you make it into something similar,homemade
Actually sometimes it seems that homemade must just like(both externally and internal sensations)and then everything will work.
Radionic not collected, but inside RAD2400HD watched:), and previously on the Forum wrote:
Sincerely, MAG.no<
Therefore the "don't solder", Karlowski use + a Manifesto-program to the last time (so probably a couple of months) without inclusion in the network - efficiency is not decreased.Маг.нет wrote:Like (exaggerating maybe) the device produced in grade 5, without the scheme, on a whim. More precisely, it was evening, there was nothing - no charge, wires twisted simple NCH generator rolling on one (or two, don't remember, transistors) in the right side - light bulb in the left speaker from the payphone, the power cord broke two plates, added a capacitor. Resistors (2 pieces) replaced with potentiometers. What you wanted? Wanted the sound of "sirens" and "flasher". What happened? Generator rolling, one of the "resistors" which was my body (closed finger two plates). Adjusting the potentiometers to the desired amplitude of rolling, noted an interesting effect, at a certain frequency and the blinking of the lamp, received the "noise" in the head (not the speaker) - an interesting sensation. And settings had at each new inclusion to change (different mood, different body resistance). The feeling can be compared to MM. Cool and very surprising. Such properties I did not expect to. Rolling - alternating voltage is applied to one of the "monitors" (speaker, lamp). Knew that any speaker and microphone. Began to experience to tell on him, first was crap, wanted to see a change in the amplitude of the flashing, after you have expressed one of her desires. To my surprise - the desire, after 2-3 days came true... he Became a joke to show tricks to friends, comrades. I cleaned for about a month while foolishly not announced (jokingly) "notice of death", which also came true the next day, a man was killed. Me it is not that scared, just AMAZED! I threw the device out the window and he promised nothing like that to do! How did it work? Installation of auto-suggestion, transferred to the device. And no matter what there was radio. I believed that I was "someone" hears and executes my requests and it worked.
Sincerely, MAG.no<
On Ineta found the design of Radionics. In English.
9 dial Rad Box construction
Dual Well Radionic Boxes
All kind time of day! walked around no and came here on one opinion: that the crystals have a reason, and the impact of the electromagnetic pulse destroys them.
in use ,the crystal can harm the host,this applies to active devices. so I think...maybe there's a specific meaning to explore this topic is there any options such as Radionics without pulse generator? but a reference to these views:
http://forum-2012.com/forum/viewtopic.p ... c&start=30
