www.rrr.bz
Write your name in English.
After you receive a response letter, print and Verite map.
An identical card will be the one of the orgone generators.
Now you can check the output of orgone energy
hold the center of the palm over the map. Make sure your hand is relaxed!
Then with the card you can make living water and charge it with life energy.
Take a glass of water of good quality.
Try a SIP,to compare it later.
Place a glass under the map for half a minute or more.
Taste again!
What happened:
1. Negative information from the water has been removed, it has changed its flavor and became like water from a spring or deep well.
2. She was filled with vitality.
You can charge the card a large container of water,put it under the map for 10 minutes or more.
The card is valid for two hours.
