Well, okay.
1. I described the technique of manipulating the visibility of the cloud cell and the technique of regulating its own "tweak" or of alignment with the world in a thread about the modulator, for validating the Merkaba.
The point is, TO not losing the saturation may withdraw from interaction with us and the world,staying as it is, but not here (not in this phase). Can you imagine it as a kind of regulator of manifestation and some time with him to practice to turn it from the "fully manifested" to "never seen".
2. In fact this setting of manifestation is associated with the setting in place and time "here and now" and for the parallel branches of reality, it will be another option. Actually for our branches and at least another place - is different.
Ie then you can begin to play with the same parameter, call it conditionally "phase shift" signal its cocoon relatively of this world," but for himself and not for KO. First, just on the subject of "I manifest and I'm not shown". You should track both "presses" the world is manifested and not manifested person.
It's funny, but most of the population of the planet is only partially "there" because her attention is much taken from reality all sorts of virtualhostname.
3. after playing with changing their manifestation in the world, you can learn how to optimize it for the tasks (although generally it is usually better to keep it on a high and this, incidentally, makes 2.6 and the "mirror of ISIS".
4. Then you can try to shift yourself to another place (e.g. to another city, at least for a few hundred km) is not on the "I submit, I see", i.e. not etheric-astral output, namely the parameter phase. In another point of the planet at the same time, this is different, since it depends on a superposition of internal energies (vnutriplitnykh) and external (let say the zodiacal and solar), and both of them are in their cycles and these cycles depends on the place too. Ie if you shift your attention to another place and prove himself there that is tuned to the phase parameter of this place, the effect will be completely different from the one just astral or partially astral projection there. And realism and consequences in the physical location of the body after the return of attention.
a little play around with this, you can find these techniques useful application
but of course the experience you first need to dial.<
