SP. Stones
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Mon Sep 13, 2010 11:01
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Wed Sep 15, 2010 18:52
From Internet sources:
Since ancient times, healers of the people of the Zapotec and Olmec treated patients through direct contact of their fingers, and corresponding "rivers of light" on the body of the patient. What happened with this contact? Restored the speed of the "flow of light", he became more uniform and the man recovered. But this only works if we eliminate the disease is not too great. When one contact of hands to cure the patient seemed impossible, healers used as the carrier of the healing vibrations of the natural crystals.
In other words, they "charged" a required vibration crystals of a certain type, and then placed it in the appropriate place in the patient's body. The crystal for a long time disseminated by the respective energy channels of the patient's body vibrations with the desired characteristics. And thus fulfilled the function of a kind of tuning fork for restoration settings. In fact, this method of forced resonance. The result of such exposure could eliminate the more serious distortion of the vibration characteristics of the patient and the well healed.
The third tier is a little-known and poorly studied caves near the mountains of Oaxaca in Mexico shamans mined healing crystals used by modern healers of Mexico. These crystals are crystalline or cryptocrystalline varieties of different kinds of quartz:
● smoky quartz;
● Morion;
● citrine;
● prase;
● praseolite;
● rose quartz;
● agate;
● onyx;
● carnelian.
Sincerely, MAG.no
Post by Маг.нет » Wed Sep 15, 2010 18:55
you and lucky to live in an era of a developed experimental science, at a time when accumulated a lot of knowledge on Geology, Mineralogy, and physics of electromagnetic fields. Thus, modern man is available to use not only well known, but studied only through modern technology features crystalline media. And, despite the fact that official science is sometimes inclined to refer mineralotherapy to unconventional forms of treatment, supporters and followers is growing.
Experiments using the devices of high sensitivity have proved that the energy vibrations of the crystal lattice of minerals affect the natural vibration characteristics of the human body. Moreover, the vibrations of the minerals, entering into resonance with the vibrations of biofield of the person, can cause both positive and negative effect. It is therefore very important stage is the selection of the right suitable for you for certain uses of the mineral.
The effects of crystals on the body
For a long time medical scientists have argued about the possible effects on the human body electromagnetic fields of stones and minerals. However, a few decades ago, a number of researchers in this field working in different countries of the world, found that it caused such impacts.
We all have heard of homeopathy, the method of treatment in which small doses of an active substance capable of regular application to cure the complex disease. On the energy level, which works quantum medicine, the effects of electromagnetic fields of low power likewise entails tangible benefits.
The importance is not so much the intensity of the electromagnetic field (in the case of natural minerals it really is very small), but the nature of energy itself. And depending on the origin of energy is exerted the influence can either be negative or beneficial for the body. Natural stones have vibrational properties that are correlated with the initial harmonic radiation of the Universe. They are able to radiate vibrations of the frequencies that are perceived by other oscillatory systems such as "reference".
Currently researchers have proved that these energy mineral activity and specificity of the vibration of crystal lattice, which are aligned with the oscillations of organs and systems of the person, is the reason for the healing effects of minerals on the human body. And the identity of the energetic vibrations of stones and vibrations of the human body, ability to stimulate and guide the work of the energy flows in our body in the right direction as time and explain the healing properties of stones.
Our diseases are the result of the accumulation and sticking of such negative energies in the energy channels of the body. Natural stones are, in fact, is energetically the most stable formations on the planet. They have for many centuries retain a favorable energy. If the right way to choose the stone with the appropriate vibration characteristics and to transmit his energy to the affected organ, it is possible by the generated resonance to release clogged energy channels and nodes of the human bio-field, to cure a diseased organ and set it on a healthy work.
Crystals, based in crystal lattice with harmonically oscillating nuclei and electrons, are themselves the generators of electromagnetic fields of low intensity. Coming into resonance with the vibrations of cells and organs of the human body, they are able to influence their condition.
If the effect of the minerals will be favourable, thanks to the inherent reliability of the stones, "inertia" they can be used for quite a long time. But we should not forget that any source of energy requires support. Stones for their best work you need to be regularly cleaned as well as possible to let them be before the "eyes" of the Sun or other space objects. Because the minerals are able to accumulate emitted from stars, energy, and fueled so you can give it to the man.
The human body is a large bioenergy system, all component parts which are in constant and continuous motion. It is not only the pulsations of the heart, muscle contractions and other physiological manifestations. If "move" on a deeper electromagnetic level, we "see" that certain organs oscillate at its own specific frequencies. Because individual cells, connective tissue, intercellular fluid – they, too, consist of tiny particles of matter that have their own fluctuations.
Sincerely, MAG.no<
Post by Шалтай Балтай » Wed Sep 15, 2010 19:00
Post by Маг.нет » Wed Sep 15, 2010 19:00
Returning to the question "on monopolistic crystals", considering the principle "ALL the TIME".
All minerals have a great power in a certain peculiar power of the planet the day of the week, month, year, hour of day, a certain day of the lunar day corresponding to the lunar calendar.
Stones day for each lunar day:
1 - diamond, rhinestone
2 - jade, chalcedony, agate iridescent
3 - ruby, pyrite, aventurine
4 - onyx, amazonite, green jade
5 - turquoise, pink chalcedony, marble
6 - hyacinth, zircon
7 - sapphire, heliotrope, coral
8 red granite, beryl, Morion
9 - black pearl, alexandrite, rauchtopaz, serpentine
10 - amber, olivin-peridot, sardonyx
11 - fire opal, hematite, carnelian
12 - lazurite, yellow coral, mother of pearl, pink pearl
13 - noble opal
14 - hyacinth
15 - agate, jet, Morion
16 - spinel, tourmaline, caret, emerald, pearl (black)
17 - transparent amethyst, crows and Hawkeye, zircon
18 - white agate, opal, purple amethyst, spinel
19 - Labrador, jet. Morion, Bloodstone, peridot, green garnet
20 red Jasper, jaspilite
21 - pyrite, zircon, aventurine, obsidian
22 - blue agate, blue sapphire, blue Jasper, blue jade, amber
23 - Topaz, black jade, crocodilia, sarder
24 black Jasper, air obsidian, malachite, blue jade, grossular
25 - porcelain, tiger's eye, hawk's eye, heliotrope, pink marble
26 - yellow jade, jadeite, chrysoprase
27 - emerald, adular, Selenite, amethyst purple transparent
28 - aragonite, chrysoprase, milky opal, jadeite, aquamarine, amethyst
29 - black pearls, mother of pearl, obsidian, white opal, Labrador, colored Jasper
30 - white coral, rock crystal, tourmaline
Sincerely, MAG.no
ЛВ
Post by ЛВ » Wed Oct 20, 2010 14:12
There is another curious stone lapislazuli
http://en.wikipedia.org/wiki/Lapis_lazuli
ЛВ
Post by ЛВ » Wed Oct 20, 2010 14:24
He lazurite, is added to many organity in the West
http://ru.wikipedia.org/wiki/%D0%9B%D0% ... 0%B8%D1%82
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Wed Oct 20, 2010 14:28
A curious stone - Hermajesty diamond. This quartz crystal. Its properties compared with diamond. There is only one place on earth, formed at very high temperatures and a pressure of about 500 million years ago. For magical purposes, they were used for the realization of intentions.
Post by Шалтай Балтай » Wed Oct 20, 2010 14:51
МерКаБа wrote:Curious stone - Hermajesty diamond.
cool, even Yandex did not know about it.
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:08
Herkimer diamond ("herkimers diamonds") is a unique natural crystal quartz cut: both ends
each crystal is crowned by a hexagonal pyramid. Thus, the boundaries represent a closed
form indicating that the crystal to grow without any substrate, increasing not one but two
directions at the same time.
They occur in cavities of crystalline rocks as a result of very slow growth, and rising, almost
not in contact with the host rock. Such crystals are very rare. Each of them has 18
crystallographic faces: six faces of the prism frame laterally in a circle, and crowned with 6 each
the tip in the form of a hexagonal pyramid. Crystals may contain inclusions of gas bubbles and
liquids, impurities, as well as "phantoms". Sometimes they form the so-called "clusters" -
intergrowths of two or more individuals. This differs from the Druze, where the crystals grow on the same substrate, here
on the contrary, as if each grows from the other, from the side or from the top. The origin of this quartz,
obviously, hydrothermal.
They are very much appreciated by collectors and lovers of original jewelry – after all, the crystals do not require
cut and each is a miniature work of art, though of natural origin.
Herkimers diamond named place of occurrence – region Herkimer in the state of new York in sedimentary
dolomite rocks. These stones were known to the Indians long ago – they found them in river alluvium, in
ploughed fields, admired them and used as talismans. But the industry developed stones
were only in our days, when was seen in the extraction of dolomite. Today in new York
is developed by two shafts. When the popularity of rock began to grow, it began to look in other places and found
the neighboring areas of the state, and then in other countries – Afghanistan, Tibet, Arizona, Norway, Ukraine and
China. In Russia, they are little known.
Crystals from new York known for its purity and ascribe to them such magical properties, as an aid in
the realization of enterprises, plans, fulfillment of hopes, the realization of any dream.
ЛВ
Post by ЛВ » Wed Oct 20, 2010 15:08
[quote="MerKaBah"]Curious stone - Hermajesty diamond.
And where about it to esteem and how much this is worth? :)
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:09
Written and chermyanskiy and herkimers and hermajesty and diamond gerkmayer. but disk imaging in Runet is still not enough, copied from one of the two books.
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:10
I'm in the States ordered a small pebble 70$
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:14
HERKIMERS DIAMONDS
How bright the sunshine! What a perfectly shaped angles which glare. Herkimers diamonds reflect light in all its converging at one point faces, having the most perfect in the nature of natural vertices. They are a special quartz crystals found only in Herkimer, the state of new York. Often they are reminiscent of the bimodal quartz crystals, and in fact have two, sometimes even three or four vertices. Often their faces are the same crystals, only smaller, and they almost never unfinished edges. This mnogovershinnoe gives them an additional charge of dynamic power.
Herkimers diamonds are some of the best stones used in the various schemes of imposition, to clear and dissipate emotional stress or stagnation that has accumulated in any area. If you place them between the chakras, they contribute to the cleansing of the channels for the free flow of energy. That is why they are very well cast together with malachite on the solar plexus. Malachite will output suppressed emotions to the surface, and these quartz-diamonds is to dissolve and dissipate them.
Herkimers diamonds are very useful to carry if you feel the need for additional energy. Often they are very nice in jewelry, and is able to make any place in which they are placed, lovely. It is known that they are very good to put under the pillow during sleep, because they can cause conscious experience, the experience of being outside the body, or to contribute to the accurate reconstruction of the memory of what was happening in the dream. Herkimers diamonds are truly a delight. They are happy. They will make you happy too!
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:20
If much one will have to next time to order.
Been thanked: 182 times
Post by Андрей Кабанков » Wed Oct 20, 2010 15:42
Merkaba
Got pictures?
I probably have :)
But in new York there is a place where we can see and touch?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Wed Oct 20, 2010 15:47
Андрей Кабанков wrote:And in new York there is a place where we can see and touch?
Google and ye shall find.
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 15:51
Andrey Kabanov
On Amazon there are a lot of different things, they still differ in purity. Here's a little for 47$.
http://www.amazon.com/Herkimer-Diamonds ... 66&sr=8-11
Post by Шалтай Балтай » Wed Oct 20, 2010 15:58
interesting thing
Merkaba
how to get accomplish your goal.
for SP IMHO - a little expensive, but mendalami can most it.
МерКаБа
Post by МерКаБа » Wed Oct 20, 2010 16:10
Humpty Baltay
in in, I to write to you about it wanted. I have a book about pendulums bourgeois, here is a quote about the pendulum:
"The pendulum of herkimers diamond
Such a pendulum is an exceptional rarity. When we talk about herkimers diamonds, we are talking about quartz crystals that have a structure similar to that of diamond. Herkimers diamond - a powerful healing stone. The role of the pendulum it when used correctly will produce a therapeutic effect at the stage of research of the disease."
Post by Андрей Кабанков » Wed Oct 20, 2010 16:18
In new York proposed to find the stone,$ 10 per day :)
http://www.herkimerdiamond.com/mining.html#rates
Post by Логик » Wed Oct 20, 2010 16:23
Андрей Кабанков wrote:In new York proposed to find the stone,$ 10 per day
Reminded me of that Tom Sawyer gave to the neighbor kid paint the fence for money. Still the work of Mark TWAIN someone perceived as a business plan.
In America, it is also possible to seek gold...
Post by Dimas » Wed Oct 20, 2010 16:25
Logik
What are You all criticize that? All You someone is trying to cheat to make money on You eheh-heh-heh...
