Moods Sytina and drives Andrei Patrushev.
САМОЛЕТ
Post by САМОЛЕТ » Tue Aug 24, 2010 15:22
Hi Andrew!
1.Please tell me which of your CDs better to listen moods Sytina? I think it is better suited to the "Music for hypnosis and self-hypnosis" or "Hypnotic trance" from the Theta meditation.How, in your opinion?
2.Found online moods Sytina that begins to your music from disc "Conductor" or "Music for hypnosis and self-hypnosis".Question,there is music, just regular music, or as in "file Explorer" contains the whole set of frequencies which transforms brain in a special the suggestible state?
Re: Moods Sytina and drives Andrei Patrushev.
Post by Андрей Патрушев » Tue Aug 24, 2010 21:53
САМОЛЕТ wrote:Hello Andrey!
1. Yeah. :)
2. I do not know. :?
САМОЛЕТ
Post by САМОЛЕТ » Tue Aug 24, 2010 23:38
Why don't know? Your music was taken without the consent of you?
КАА1970
Post by КАА1970 » Thu Aug 26, 2010 17:16
Then maybe You can tell me how to make this mix one of these frequencies?
Post by Андрей Патрушев » Thu Aug 26, 2010 19:51
КАА1970 wrote:well, can You tell me how to make this mix one of these frequencies?
In any multitrack editor.
КВАЗАР
Post by КВАЗАР » Sun Oct 20, 2013 22:53
Hello! Everyone listening to this mix you need to prepare again? Save its probably not worth it - will be a loss of quality?
Post by Андрей Патрушев » Mon Oct 21, 2013 7:19
QUASAR
Saving does not give any loss of quality. 8)
КВАЗАР
Post by КВАЗАР » Wed Oct 23, 2013 20:04
Adobe autdition 1.5 (multitrack editor) does not open your drive :roll: What to do? bc
Алекс78
Post by Алекс78 » Tue Jan 07, 2014 0:16
For moods Sytina, no Conductor, no Music for hypnosis and self-hypnosis are not suitable. They generally have assimilated(!) in a state of mental starters. Method SOEVUS - verbal-shaped emotional-volitional state management. You should not just listen to relaxed - this is hypnosis (what Sytin said repeatedly, it then has changed everything). You have to FEEL what they say in the mood. Need to make the effort..and connect emotions... by the Way, before he Sytin not engaged in the sale of their moods in autovariance and was strictly against such an extension. But I want to eat everything.. :?
Post by Андрей Патрушев » Wed Jan 08, 2014 10:42
QUASAR
Teach materiel. :?
What do you do to "open" the disk?
Новенький
Been thanked: 13 times
Post by Новенький » Wed Jul 16, 2014 20:01
Алекс78 wrote:Need to make the effort..and connect emotions...
Can simply be read aloud at a leisurely pace...the performance will be if the mood to reread PO2-3 times in a row...
Новенький
Post by Новенький » Wed Jul 16, 2014 20:16
You can just record mood through the microphone with his voice, but confident, and energetic voice !!! and then listen..the same result will be... you can still try to write in the inaudible range with use. binaural beats are about as audiotechnik. from Sviyash...
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Jul 18, 2014 13:57
And yet we must not forget about the semantics, which is very important to record even my voice.
Новенький
Post by Новенький » Fri Jul 18, 2014 23:04
Read Sytin experimented some.. read His moods and openly laughed at these sentiments, writhing over them..But then began to notice that they have to go through some changes for the better...those that They did not believe..I think it is possible though how to read the result will be..
