New product of isn-1 is a modification of the BZ.
Post by Михаил_ » Sun Aug 22, 2010 17:56
When looking at the different capabilities of the BZ, we made a new product that implements the basic features BJ 2.6, 2.7 and 2.8 (quality) in the table object.
IIM-1 = a source of strength table, version1.
A small table object in the model performance for different gift-table articles, candlesticks, etc.
It is made specifically to the subject could be located on the desktop or the hand without attracting the attention of others (SK-1 the negotiations will not twist in hand, and the "glass" easily....)
The subject has great potential for recharging the person is still in his hands and can also serve for order within the qualities BJ 2.6, 2.7 and 2.8 (i.e. mass and energy) that allows you to use it during target operation, as a means of rapid self-regeneration, as the power of his BJ as the protection of the workplace and so on.
Isn-1 is made in the standard containers of small size, which is flooded with link 2.x stone (laser engraved) filling compounds 2.6, 2.7 and 2.8.
In view of the availability of the standard firmware versions 2 BJ.x, IIM-1 integrates with other BZ and IC in a single working complex.
In other words, while working with ISS, all of your BJ 2.x get capacity strengthening of versions 2.6, 2.7 and 2.8, work with the ISB continues and then when You released it from his hands., similarly, the connection with SK, if any, operated by You.
The cost 5T. p.
the office will appear after about a week (currently in stock 1pcs).
At the moment it is the most affordable way to get the setting to the quality of the older versions of BZ at a more affordable price, although the main purpose of the isn-1 is a source of energy in the workplace (optional). Including for "heavy" situations when you need to dramatically increase our energy resources, for example during a conversation, without attracting attention. Man torque during a call, something from the table, it usually just doesn't attract attention, it is considered absolutely all organic.<
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sun Aug 22, 2010 18:44
Buy! (please wrap...)
Sincerely, MAG.no
Post by Маг.нет » Sun Aug 22, 2010 19:12
Preferences the "first Purchaser" provision?
Sincerely, MAG.no
Post by Михаил_ » Sun Aug 22, 2010 19:40
pre-where? :) in the form of what? :)
Post by Маг.нет » Sun Aug 22, 2010 19:44
:o Clear
Post by Маг.нет » Sun Aug 22, 2010 20:19
Neat appearance? :wink:
Sincerely, MAG.no :o
Post by Михаил_ » Sun Aug 22, 2010 20:26
Andrew promised to take pictures :) poured into a glass vessel, placed conveniently in the hand (almost round shape, to the Transfiguration of the vessel was a candlestick). So that's kind of neat because the brain people are unaware that addresses it to the nearest analogy, are likely to perceive this item as a decorative candle in glass or something similar.
Been thanked: 182 times
Post by Андрей Кабанков » Sun Aug 22, 2010 21:20
Новик
Post by Новик » Mon Aug 23, 2010 0:52
Mmmm like that a little clear in the photo what it is :(
Like banatsko that goes on the back))))
Post by Михаил_ » Mon Aug 23, 2010 0:56
probably need a photo with a 3D object for size comparison next.
This is a glass candle holder under the candle round, which is internally filled with a filling. Chosen form for two reasons:
1. the thin walls do not interfere with the operation of the device
2. fits well in the hand.
the size of the photo - tennis ball (approximately), i.e. small.
_Алекс_
Re: a New product of isn-1 is a modification of the BZ.
Post by _Алекс_ » Mon Aug 23, 2010 1:34
I take!))
And more detailed info about it)
Михаил_ wrote:the main purpose of the isn-1 is a source of energy in the workplace (optional).
Michael why only more?
including for "heavy" situations when you need to dramatically increase our energy resources, for example during a conversation, without attracting attention. Man torque during a call, something from the table, it usually just doesn't attract attention, it is considered absolutely all organic.
That is, take it in your hand, but having read their work?
And if he just stands on the table or say next to the bed?
How they respond to his surrounding, which means that the instrument affects people at the next table if they're close or sq for example behind a wall? we know that wall is not a barrier)
From here one more question how the device detects the host if there are a lot of people and he is not the owner of the hand say.
What about in sq busting the energy is for example in the bedroom you can put, to sleep and sleep will not be difficult?
The issues are simple but they are relevant)
And a journey it can take or it is tied to one's house, for example...? And what is the action area?
Post by Михаил_ » Mon Aug 23, 2010 1:54
Range (active) a few meters. The room need a SK, this is rather weak, although prolonged exposure is probably enough.
The owner determines is very simple - it's basically a BJ. Ie who last "had" (in the hands), and the host.
To carry can.
Working and just sitting on the table, when it interacts with other BJ, so an additional source, it is assumed that using it is BJ 2.0 at least one (so his work would be more efficient).
If you do not take it in hand, feeding constantly will go anyway, if you already have attunement, but if you pick up - will be much more efficient.
Surrounding also it will feel, but not super hard to interfere with sleep should not. The main orientation of the operator (someone who last held long-term, ie at least a few minutes or tens of minutes in the hands).
In General you should treat it as a great BJ.
Unlike the UK there are no specials.programs, functions exactly BJ, he provides the setting to master and work with other BJ, increasing their mass.
Of course this does not replace the bracelets of the older versions on hand, but can serve instead (not as convenient, is not always diarrhea, but the quality and energy is there, you can take them and send to target).
The main purpose of energy improvement of the workplace.
PS. So far only pre-order, you will have a few days in about a week, that is, as I understand it managed to book a Magician.no.
_Алекс_
Post by _Алекс_ » Mon Aug 23, 2010 2:54
Michael_
Clear) Thanks for the answer!)
Another question more specific. In the room two people are both BJ 2.0. If we don't touch him he distributes equal between two people energy and increased BJ?
Just for example, I am more often at home, and the second person is less because of the specifics. He's maybe more on me to focus both on the host or am I mistaken?
Or need 2 devices?
Post by Маг.нет » Mon Aug 23, 2010 9:29
Михаил_ wrote:managed to book a Magician.no.
Correction, to buy and to pay.
Sincerely, MAG.no
Фенечка
Post by Фенечка » Mon Aug 23, 2010 21:35
And if the bracelet is 2.0, too? and it turns out the energy protection! And front room Windows.
Post by Михаил_ » Mon Aug 23, 2010 21:48
Bracelet 2.0 itself provides protection only if the fatigue and other problems accumulated in abundance, in the sense of its effectiveness will take some time.
Yes, of isn-1 can work with 2.0 bracelet paired it for this and made.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue Aug 24, 2010 1:38
Yes, this "jar" I liked it. The field is large and soft around warm, even cozy. The post over it is also a decent and powerful. In General, soft works as I thought. And in the hands a pleasure to hold. Besides really like a candle can be kept on the desktop will not attract attention. If you still have to decorate all will be beautiful.
Идущая вперед
Post by Идущая вперед » Tue Aug 24, 2010 15:47
Michael_
if this is the first version of ISNA and it costs 5000
when you plan to release a version 2 enhanced and hopping it will cost?
Идущая вперед
Post by Идущая вперед » Tue Aug 24, 2010 15:53
but if the picture of this product to put into the workplace with him identity braslet-the impact will grow????
certainly smaller than this... it's like the paper version of the bracelets - free... :)
Идущая вперед
Post by Идущая вперед » Tue Aug 24, 2010 16:00
well... I made this hranicko photo screensaver to your desktop... at the hands of 2 bracelets 2.0.... immediately and specifically energy through the heels flooded...
Идущая вперед
Post by Идущая вперед » Tue Aug 24, 2010 16:19
this hranicka background-screensaver on your desktop.... after 10 minutes his hands were cotton.... falling into a
Post by Маг.нет » Tue Aug 24, 2010 16:25
Nice experiments :o
Sincerely, MAG.no
Post by Михаил_ » Tue Aug 24, 2010 23:22
Neeeee :) I'm crazy about people :)
1. What savvy :)
2. What daring experiments :)
Idumaea, of course a photo will work. However it will linkvana personal IIM-1 MAG.no, but it (ISB) do not lose anything, it is in principle also can work not only with the owner but also with the surrounding space, thus You are trapped in the surrounding space.....
Just do not overload yourself to arrange all too often, once in a while is fine. It gives opportunities for growth.
Theoretically you need to upload pictures of items which then remain "for Windows", but BJ this problem is not worth it, so I'm not really that bothered. There is correctly working algorithms settings on the host.
Идущая вперед
Post by Идущая вперед » Wed Aug 25, 2010 10:43
Yes... the photo really works... on the desktop background - very intense... printed on the printer of A4 format - smaller impact and effect...
if the photo to put under the pillow or hands to touch you in the night not to sleep...
generally I want this thing alive...
and on Saturday you can redeem in Albus already????
Идущая вперед
Post by Идущая вперед » Wed Aug 25, 2010 10:47
and the Magician.no. can send another thing, and that I'm not only one smart class :D :) :wiz
