The difference between the versions 2.7 and 2.8
Post by Михаил_ » Sun Aug 22, 2010 17:42
Браслет жизни 2.71 (чёрное дерево)
Браслет жизни 2.81 (чёрное дерево)
For questions received in private mail, I came to the conclusion, that there is full understanding of the differences in these versions of the bracelet.
1. The bracelets of the older versions allow people is long and steadily in a certain mental state, is not peculiar to it initially. This allows you to develop skills working with these States and no BJ as its own ability and quality.
2. BJ 2.7 is associated with the concept of harmony and vitality. This is a harmonious combination of the qualities of variability and maintaining continuity (stability), i.e. hetero and Homo of the inherent qualities of 2.5 and 2.6. In some cases a good is working with 2.5 or 2.6. For example starting something new that requires innovative and creative solutions, good and useful to use 2.5. version 2.7 is more suitable for the movement of the established course and also as a source of vitality. Will undoubtedly be evident and the quality of maintaining harmony, but in contrast to the tidal forces is the quality maybe not all earn full immediately (experience in the use of new state comes gradually).
3. BJ 2.8 is associated with high frequency operation mode of a person. Ie, it's additionally a "power" of consciousness, the higher frequency energy centres (Vishuddha, ajna chakra in the classical terminology). Do NOT use 2.8 to 2.7, or without fully understanding what it is.
For possible idiosyncratic effects of imbalance in the body, if standing lower chakras are not "full" to the brim. The simplest effect of 2.8 - activation energy at the top at the expense of the lower floors - possibly a drop in immunity, weakness. Another possible effect - the decline of sexual activity (lack of energy at the level of svadhisthana), all this is possible ONLY if 2.8 is wearing prematurely. Under normal use and in the healthy body these effects will, on the contrary, it will feel more recharge and saturation of the body as a whole.
For this reason, we recommend the use of 2.8 after or together with the 2.7. If the text above is not clear, you should not need to be discussed with the 2.8.... save it for later.
2.7 is suitable in General to all.
4. When working with order 2.7 gives the energy of a pulse that implements the intention, and 2.8 allows for a more accurate "pointing" at the target, and adjustment of the probabilities in their favor.
I.e. it's two completely different instruments, although each of them can partially perform the functions of the other.
5. Starting to work with 2.8 - batch time with him on the hand. This is a very powerful thing.
In General, I hope that the main principle of selection, BJ is associated with the understanding of why a particular type of BJ You need, and not because "it's cool" or "let me be the humor of the situation" :) ie this is not a toy that can be layered according to the principle of strengthening effect for their own purposes. Work with older versions requires time and a certain caution, as their influence begins to affect all aspects of life.<
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Mon Aug 23, 2010 21:59
Very good and clear explanation. Thank you!
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Sat Aug 28, 2010 15:46
Michael_
And if the sensitivity is tight, how to determine the full lower chakras or not?
Post by Михаил_ » Sat Aug 28, 2010 20:30
But if bad, then NO. How to get energy to anahata, there will be a minimum sensitivity at the level of sensations (tactile, etc.).
2.8 in this case, anyway, from going to work, but if only short portions to use literally by the hour.
But why....
Post by Воффка » Sun Aug 29, 2010 0:40
Michael_
Yes, at least in General, I have a saying tight I mean a good sensitivity :wiz don't know how to explain :) But what is low sensitivity is, I'm sure. But how to determine the fullness to the brim don't know...
Post by Михаил_ » Mon Aug 30, 2010 21:28
the fullness to the brim with ... well, don't know :) some personal feeling that lack of energy and health and active
Post by Михаил_ » Mon Aug 30, 2010 21:30
the fullness to the brim with ... well, don't know :) some personal feeling that lack of energy and health and active lifestyle and all that....
ie first physics body and sense of self needs to be able to "enough". This does not mean perfect health, it has many=the artifacts of long-standing character from the past, but the overall situation needs to be very consistently good.
Post by Воффка » Thu Oct 21, 2010 10:27
Michael_
And the difference between 2.8 wood from the stone? How much less power? Is there any difference besides power?
Post by Михаил_ » Thu Oct 21, 2010 12:38
did someone say that last less power?
I'll try again.
dealing system 2.x for a material, we get energy active object (BJ), which adjusts human consciousness under the human condition.
in the case 2.5-2.6-2.7-2.8 the situation is somewhat different. The material is processed in a way that captures a condition or place in the coordinate system of the world without human intervention and when wearing such a BJ, he starts to reconstruct man in a new position in the world, with new qualities of consciousness and behavior.
This fixation in the world end up stuck on the material of the bracelet and its partial destruction (e.g. destruction of the coating) there is little that changes the bracelet pulls a person in a particular state.
2.8 different design variants for different material.
2.8 on the stone is closer to 2.6 when the manifestation of bright properties 2.8, and on the tree a more "centered".
By the way, due to the unification process of production 2.8 on the stone, not anymore... don't know yet.
Post by Воффка » Thu Oct 21, 2010 22:31
Михаил_ wrote:did someone say that last less power?
Михаил_ wrote:as already wrote, the office went 3pcs. 2.8, the two - tree-like 2.7, one stone.
They are a little different, but the wood is slightly more powerful...
Михаил_ wrote:2.8 3 pieces left in the office in a few hours will be there.
two wooden and more powerful and one stone and more than 2.6 th, in the sense of their situation, to push better, and the wood itself to push...
It is not clear :roll:
Post by Михаил_ » Thu Oct 21, 2010 22:56
wooden signal power of 2.8 more
but just for power, they are identical.
generally speaking in wooden 10 units of the zoom 2.8
and in the stone 8 units signal 2.8 and 2 units of signal 2.6 the total is still 10, but differently distributed.
Post by Воффка » Fri Oct 22, 2010 9:21
Thank you! Clear full :)
оуаакун
Post by оуаакун » Sun Oct 24, 2010 13:54
Михаил_ wrote:BJ 2.8 is associated with high frequency operation mode of a person. Ie, it's additionally a "power" of consciousness, the higher frequency energy centres (Vishuddha, ajna chakra in the classical terminology). Do NOT use 2.8 to 2.7, or without fully understanding what it is.
For possible effects a kind of imbalance in the bodyif standing lower chakras are not "full" to the brim. The simplest effect of 2.8 - activation energy at the top due to the lower floors - may fall in immunity, weakness.
And what's the 2.8 differs from the drive SHEMA RF mode?
I understand that BJ is feeding RF energy from the outside, but not at the expense of lower floors as in the case of configuration using disk.
Post by Михаил_ » Sun Oct 24, 2010 14:33
so, it is different. The problem is that despite the external support, if the cocoon does not pull this mode of operation, still produces some distorted and strange state.
I.e. HF from a bracelet just don't eat the cocoon (nowhere) but the redeployment is still happening.
A simple example. I wear a lot more powerful than a 2.8 without removing long.
After this, a friend said that he was having problems with lower level (elementary on the personal front, activity is greatly decreased), and I have even with monthly nepreryvnoi wear rather :) and similar observations are not just me - when the time comes to feed. It requires a relatively clean cocoon that he could do these frequencies from the outside directly to consume.
Ie 2.8 nourishes energy and improves the immune system, if the cocoon is able to perceive it.
оуаакун
Post by оуаакун » Sun Oct 24, 2010 14:53
And fullness of power from the 3.0 L is from the outside or through the lower floors?
Or is it just over time it will be possible to find out?
Post by Михаил_ » Sun Oct 24, 2010 15:20
from the outside, like the description stated.
But the above bias, when the cocoon does not maybe RF could still be wrong, not very useful.
Here, read the reviews from the office about 3.0 MM - see Dimas pulled all day three bracelets in the evening, something somewhere broke and he had a headache, but the bracelets apparently turned off (tripped the security system in them).
Further, he had neither the fever nor other manifestations of HF the next day
From Malvina was so"I wrote that she wore the bracelet 3.0 hour and a half and felt the cold symptoms.
In the morning, not gone from this condition, as not used.Didn't do anything in terms of treatment and did not include their BJ."
Ie a skewed and colds from HF arose, but at the same time 3.0 is a great regenerator.
I.e. HF from it, which is helpful for the body.
In addition, again, the cold itself is dissolved, aftereffect -no.
оуаакун
Post by оуаакун » Sun Oct 24, 2010 17:02
I was the opposite. The head was a little sick before I put on 3.0. And health was not. Put energy...
But from the 3.0 L, when intoxication (hooked hard enough with the glitches :) ) ended after 3 hours, the condition improved significantly.
It started such a blissful state.
The bracelets took off in the late evening to sleep.
Today the fever is not... and some as "enlightenment". :?
_Алекс_
Post by _Алекс_ » Sat Nov 27, 2010 4:09
Michael, can something similar as here but for 2.6 description get? More detailed. I do not know maybe a separate topic to create :)
Post by Михаил_ » Sat Nov 27, 2010 4:33
Details of the topic of the difference of the versions touched on in the video. What you need 2.6 to describe-to tell? ask the head of the subject and will try to answer in detail.
_Алекс_
Post by _Алекс_ » Tue Nov 30, 2010 3:38
Michael_
I don't even know) Just before you wrote that there is a difference for example stone and wood 2.6. Maybe something more about the functionality. What are the pros, advantages before younger versions. You're good at to explain, I think a lot of things you can write about them. I'm less familiar with them.
Thanks in advance)
Post by Михаил_ » Tue Nov 30, 2010 4:40
OK, I'll make a separate topic about 2.6, but a little later, I have "Abraham".
_Алекс_
Post by _Алекс_ » Tue Nov 30, 2010 5:21
Michael_
OK) Thanks) :)
_Алекс_
Post by _Алекс_ » Mon Jan 31, 2011 2:45
Михаил_ wrote:OK, I'll make a separate topic about 2.6, but a little later, I have "Abraham".
Hello Michael!)
Could you tell me the difference BJ +, for example I'm interested in BJ 2.6 and the difference with the BJ 2.6+ that adds this plus? How much stronger and the difference in price)
Thank you.
Post by Воффка » Tue Feb 08, 2011 0:00
Michael_
Hello Michael!)
Thank you.
I also wonder. Here, for example, if SK+HF mode is the gain of the bracelets and I for example one regular 2.6. Then with the mode of amplification it will be like two (three, four?) bracelets 2.6 or what?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Wed Feb 09, 2011 16:38
:oops: 2.6 so hard and uncompromising as a bulldozer-they want and not care about a quick solution to the situation. But if to strengthen the SK and HF that's a great bulldozer, which will pave the way to resolve the situation. (The main thing that no one was crushed :o on your way .Joke) But there was a moment when I put just 3 or 4 ,can't remember , -2.6 I just tied in a bow. Whether this is appropriate in your case? Maybe slowly but surely?
