Barefoot
Экко
Has thanked: 2 times
Been thanked: 4 times
Barefoot
Post by Экко » Sun Jun 27, 2010 7:52
Offer you your circuit design. it is a portable biofeedback showing a state after the frequency change of the sound. Scheme for the lazy :D
B1 - nizkoomnyj small speaker power 0.5 - 2 W
V1, V2 - almost any p-n-p transistor
f = C / R
it turns out the lower the resistance, the more the frequency of
if not satisfied with the frequency change, the capacitance c1.
question: the more resistance the more relaxation? I have so turned out, though I multimeter Meryl
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Jun 28, 2010 12:17
5+
R1 - resistor (preferably, but not necessarily);
S1 - variable capacitor (preferably, but not necessarily);
between the R1 - SP, you can add a light bulb.
These changes to the "settings" for themselves (initially different resistances in different people) and calibration conditions.
Sincerely yours, MAG.no
Экко
Post by Экко » Mon Jun 28, 2010 15:07
between R1 - IP, you can add a light bulb.
a light bulb why?
p.s. tried the device in action, works well
Post by Маг.нет » Mon Jun 28, 2010 15:17
Экко wrote:and the light bulb why?
For "control" frequency.
Somebody better "hear" someone to "see"...
Have experience use.
Sincerely, MAG.no
Экко
Post by Экко » Mon Jun 28, 2010 15:26
I Have the experience to use.
then I repeat the question posed in the first post: how changes resistance depending on the state?
and here's something else: how badly interfere with the measurements, the sweating of the hands and the degree of pressure sensors on the skin? and if not a secret what the device is biofeedback used?
Post by Маг.нет » Mon Jun 28, 2010 17:42
Экко wrote:then I repeat the question posed in the first post: how changes resistance depending on the state?
In reverse order:
1. Barefoot on a similar scheme.
2. To account for sweating of the hands and other factors and replaced the resistor-a rheostat, conder-postroeniem.
3. To mark as, and the need for this "calibration state".
This experiment was conducted at a young age, all you will not describe, only definitely works. (not only as BOS)
With respect the Magician.no
Post by Маг.нет » Mon Jun 28, 2010 17:46
ГОРОДСКОЙ СУМАСШЕДШИЙ wrote:ELECTRIC SKIN RESISTANCE AS an INDICATOR
PSYCHOPHYSIOLOGICAL STATE OF A PERSON
Kalashnikov V. N. Ph. D.
Electrophysiological methods of research of psyche are based on registration of biopotentials occurring in the tissue of a living organism spontaneously or in response to external stimulation. Changing psycho-physiological state is reflected in electrophysiological indicators; high emotional tension – increase of wave amplitude; unstable attention – decrease the amplitude of the wave (the so-called "Wave of expectations"). Proven that the electric skin resistance is very sensitive to the physical and psychological changes in the human body. Any local changes and processes in the human body have an impact on the electric skin resistance. It is proved that the norm of the electric skin resistance of a person in a state of relaxation increases and the activation state decreases. That is, the skin resistance increases when the person calms down and falls asleep, and decreases the mental agitation and mobilization.
It's here: http://www.mindmachine.ru/viewtopic.php?t=3233&start=25
Sincerely, MAG.no
Post by Маг.нет » Mon Jun 28, 2010 17:52
Маг.нет wrote:Like (exaggerating maybe) the device produced in grade 5, without the scheme, on a whim. More precisely, it was evening, there was nothing - no charge, wires twisted simple NCH generator rolling on one (or two, don't remember, transistors) in the right side - light bulb in the left speaker from the payphone, the power cord broke two plates, added a capacitor. Resistors (2 pieces) replaced with potentiometers. What you wanted? Wanted the sound of "sirens" and "flasher". What happened? Generator rolling, one of the "resistors" which was my body (closed finger two plates). Adjusting the potentiometers to the desired amplitude of rolling, noted an interesting effect, at a certain frequency and the blinking of the lamp, received the "noise" in the head (not the speaker) - an interesting sensation. And settings had at each new inclusion to change (different mood, different body resistance). The feeling can be compared to MM. Cool and very surprising. Such properties I did not expect to. Rolling - alternating voltage is applied to one of the "monitors" (speaker, lamp). Knew that any speaker and microphone. Began to experience to tell on him, first was crap, wanted to see a change in the amplitude of the flashing, after you have expressed one of her desires. To my surprise - the desire, after 2-3 days came true... he Became a joke to show tricks to friends, comrades. I cleaned for about a month while foolishly not announced (jokingly) "notice of death", which also came true the next day, a man was killed. Me it is not that scared, just AMAZED! I threw the device out the window and he promised nothing like that to do! How did it work? Installation of auto-suggestion, transferred to the device. And no matter what there was radio. I believed that I was "someone" hears and executes my requests and it worked.
It's here: http://www.mindmachine.ru/viewtopic.php?p=48391#48391
Sincerely, MAG.no<
Post by Маг.нет » Thu Jul 22, 2010 10:28
Экко wrote:pietistically, connected to usiku 16w when I take in my hand, my finger feel painful tingling
ECCO try to top the scheme to enable the piezo and above: light bulb (led), variable resistor, trimmer conder, "the gap" to replace the key... That you can get to the exit? audio-visual-tactile stimulation...
Device for anchoring conditions. Why? For example, listen to the CD Andrei Patrushev (rate) while exhibiting "efficient" status, press the button now, the led blinks, speaker whistles, the piezo tingling. With sufficient time, without the drive, the resistor/conder put in the right position (previously set for each anchor), the button click - the status of the called...
Something like that.
Sincerely, MAG.no
Карапуз
Post by Карапуз » Sun Aug 29, 2010 23:54
Guys, nobody is going here's a diagram of the device barefoot?
Full description here
http://everest-meter.chat.ru/Shema.htm
Gathered, are not yet set up - while not responding to the resistance change.
Image[/img]
Экко
Post by Экко » Mon Aug 30, 2010 6:57
DA1 - DA6 = where is the marking?
for me so much a complicated scheme to measure the resistance. It is possible to make sensitive DC amplifier, the circuit will be much easier
Карапуз
Post by Карапуз » Mon Aug 30, 2010 9:23
DA1-DA6 LM324. In principle there are many details due to the fact that the author wanted to make a responsive arrow on the device.
Экко
Post by Экко » Fri Sep 24, 2010 19:48
Want to do MM, which selects the frequency using barefoot. That is, instead of sessions, the management will be in barefoot, about this method heard. That's just not clear how will change the frequency depending on the indications BOS?
here for example, the beginning of the session, bare shows the stress state is activated to a low frequency, then barefoot is starting to show a relaxed state, and that the frequency should be increased then? But then the status is again tight, and again in a circle. That I do not understand the meaning.
Наиль
Post by Наиль » Thu Dec 09, 2010 11:58
Экко wrote:I Want to do MM, which selects the frequency using barefoot. That is, instead of sessions, the management will be in barefoot, about this method heard. That's just not clear how will change the frequency depending on the indications BOS?
Increase or decrease the frequency of the controlling sound is important only to realize that the process is going in the right direction.
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Thu Dec 09, 2010 12:28
Also this one time I was into was the idea to use the control codes and control points - has reached the reference point at the barefoot, bare device produces a control code MM, MM switches to the next session with the following value of the reference point. Session should be simple and uniform. I wanted to create a session to achieve deep relaxation(not all the same effect at once), a trance state(to work with deep problems, coding of bad habits) and acceleration to vneshnepoliticheskogo trance... Then rested in the fact that sold a piece of iron such codes do not support, and software emulator didn't have enough time to write...
Post by Андрей Патрушев » Thu Dec 09, 2010 12:58
Proteus + ThoughtStream - it's already done. :?
http://www.mindplace.com/MindPlace-Prot ... und-System
Post by Андрей Патрушев » Thu Dec 09, 2010 13:01
Somewhere I translated the conceptual description of the sessions with the boss of this thing... Might even find. :)
Post by Маг.нет » Tue Jun 21, 2011 23:17
Scientists of SibADI developed the equipment, which can test a person's aptitude and environmental influences.
Scientists of the Siberian automobile and highway Academy (SibADI) have developed a set of unique equipment, which can test a person's aptitude and to investigate its reaction to environmental influences.
The official name of the product – "a system for the study of evoked potentials on the surface of the human head". It consists of a helmet, which is fixed transducers. The helmet is connected to the computer with special software of its own design. On the monitor a graphical model of the human brain, showing the reaction to certain emotions or external influence.
With this hardware-software complex is possible to explore the suitability of a person to act in extreme situations. Experts can draw a conclusion about the suitability of, for example, to serve in the special forces.
Developed mobile version of the computer system. In this embodiment, the subject is skiing-roller ski running cross country, participating in the summer version of army biathlon, and at this time, the equipment records the processes occurring in his brain.
According to the head of the research team NIOKB "ARPAs", teacher SibADI Paul samosudova, technology developed by scientists Omsk, does not involve galvanic contact of the probes with the scalp. So, no need to shave the head or attaching electrodes to the head.
A unique development of Omsk scientists will be presented at the exhibition "VTTV-Omsk – 2011", which will be held 6-9 July.
Accredited. I'll try to test it... the more "head shaving is not necessary" :lol:
Sincerely, MAG.no
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Wed Jun 22, 2011 19:52
of the circuit pattern do not see, give more time :)
Post by Маг.нет » Wed Jun 22, 2011 20:25
Бобер
Post by Бобер » Thu Aug 04, 2011 15:29
Экко wrote: Offer you your circuit design. it is a portable biofeedback showing a state after the frequency change of the sound. Scheme for the lazy
ECCO and you have not preserved your scheme? It was removed from the former place =( Not that I'm lazy but to me the simpler the better (I'm a new ham)
I understand that the meaning of the operation of the device is that in one hand take the wire plus and the second minus and if at this time shouting at me for example parents or teachers then the speaker starts beeping. I dvukhchastotnyi a tape recorder in the barn brokenness lies I'm unable to get the parts required?
I apologize in advance if that was a mistake...
Экко
Re: barefoot
Post by Экко » Tue Aug 16, 2011 6:06
beaver
Yes.
Бобер
Re: barefoot
Post by Бобер » Wed Aug 17, 2011 1:02
Thank you! :D
Экко
Re: barefoot
Post by Экко » Thu Sep 08, 2011 13:24
Mental games is a good thing, but would you be willing to make them yourself? is there a diagram of BOS with squeakers, but the computer interface more interesting. That's what I thought, can we make the generator, voltage-controlled or direct resistance, and on the COM port and the program will have to count pulses. I think it is a workable option!
Re: barefoot
Post by Андрей Патрушев » Thu Sep 08, 2011 15:06
ECCO
And you can think about how to make a full training program, for example, on the basis of threshold relaxation when the feedback will vote to go... :ay
