Sell your front room
Sell your chamber - Svetlitsa-super the Svetlitsa-Blaga, the mirror of ISIS. For everything about everything - 12500р.
I can't feel big effect from wearing them, and to go to seminars and be engaged in special exercises, I do not intend, there is no time nor desires.
Will be sent by mail to everyone in Russia.
Александр 78
!Энди
Well, from chamber effects were. In the first month of wear become Dating friends-acquaintances-classmates which I had forgotten. To placebo is irrelevant.
There was physical feel of the room. Now they're gone. I have an explanation. But I will not sound. And then the ASD will then repeat it, and for others it will look as if it is he knows and understands everything.
it is human nature to learn some experience. When the experience becomes part of the cocoon (part of man), the influencer is no longer valid. The action is just as there is potential difference. When the cocoon acquires the information (the person assimilates the experience), the battery is disconnected(but not always sparse, since it is often only a part of possible experience). (if it contains a static structure). However, it is very likely that learned experience is different from contained. In this case, impact will resume (or periodically renewed) when a man falls in the zone of a buffer, where assimilation is not enough and the exposure is resumed.
Similarly with any static (permanent structure) influencing factor.
Another thing is that if You're used to, it does not mean that the experience acquired so that the cocoon itself can conduct the same action. Including the fact that the solid (mechanical) structure is usually a number of parameters surpasses the information (not all).
what am I?
I would recommend that you postpone for a long time in the side and then see is there any effect from new entry in the field (both not fast, and not range a few weeks) to make it clear that the action is not premature.
Because I like working with the principles laid down in close to the mirror, not sure how many years you need to work out everything I need.... Although not all of course the mirror can be, much still need to.
Just a tip - take your time. Sorry if not in cash. I understand that You probably weighed the pros and cons, before writing the ad, but still.
what am I?
Of course, had its day, that there for them to pay attention. And then suddenly you'll live longer.Anonymous wrote:Elderly Mirror is not necessary - definitely.
Well, if only for the seminars to go to grandchildren and future shaping.
We experiment with a mirror on a test system for determining biological age of a person in the Krasnodar medical University http://www.***/othety/12.htm was mostly elderly people (source biological age test the average for the study group 50). After 45 days, the average biological age of the test group for 38 years. People didn't go to seminars, but only three times a day looked in the mirror for 10 minutes. Although purely subjective, only a small part of them during this time felt positive changes.
People don't always notice these or other factors, and the change from these factors. If the factor is constant, the body ceases to perceive it. If the variability factor is less than the perception threshold, the factor is also not perceived. For the FACE increased sensitivity to the action of different factors by reducing the structural distortions. Some people (usually 10-15 percent of the total) sensitivity to the different factors starts in the result to exceed the threshold of perception. Even if the person does not notice the impact of our products FACE, this does not mean that they are useless for him. Products are always improving worth of any person. It will still begin to appear in his work, relationships with people, health.
But we should not forget about the influence of the external environment. She, too, is always and often not for the better. The influence of the external environment is unstable and may increase in different periods. When interacting with the products of the face of the person moves to a new equilibrium relationship with the environment. It is not constant and can vary, then improving, then whodas. With increasing pressure from the environment by others can begin to show negative processes that seemed to have appeared in the past. A chamber is not a panacea and cannot be considered as a deliverance from all problems forever. Products LIK create potential opportunities to improve the quality of decisions through improved quality of information and interactions.
To be active and try to change the nature of their relationship with the environment, exerting her control action(what, too, need to learn), the positive trends of improved quality of information interactions consolidate and become irreversible.
You can be a passive user and only passively use products. There are positive trends may not be noticed, even though they are. Increase the adaptive capacity and increasing resilience to environmental factors.
To expect that if a Chamber is, then they will do their job for a person, means the removal of responsibility for their actions and mistakes. But if to get rid of the Parlor, the negative trends in the external environment can start to get brighter as again increase the probability of making mistakes man. That however may not be noticed due to the above described reasons.
There is an anecdote: an old Lady called the technician repair the TV and says: "the TV doesn't work - all garbage shows".
We can assume that the Chamber are not working, if your "screen" all the time stuff. But Svetlitsy only help to realize that we have to switch the channel and switch it can only the man himself.<
The Succor Punchследующий wrote:I apologize for the incompetence that is SP ?
http://www.mindmachine.ru/viewtopic.php?t=3295
