The scope of products LIK.
If Sergei Dinovich will provide the required number of bright-rooms cloak - cloak will do. And Dmitry borrow, I do not mind.Владимир Мокрушин wrote:In some of the videos on the page http://www.mindmachine.ru/infokonstruktor/seminar/ is the answer of Sergey Dinovich Dmitry the same question. Only Dimitri offered his cloak from the parlor.
- ГОРОДСКОЙ СУМАСШЕДШИЙ
theoretically possible unexpected side effects - in particular the pond may start to grow faster greens myself(?if we assume that strukturirovana water stimulates growth) that is not always good. If it is running or have the ability to effectively clean once a year - no problem....
I'd start with the barrel and the volume is real and the pond is not overgrown. Although maybe I'm wrong, some do not understand the point. What will be promoted in priority. From the point of view of harmony, probably the pond just should not grow. And, in terms of the properties of water.... I guess until you try you'll never know.
I have seen many ponds that are not overgrown. And have some special. But the riot of life usually has a reverse effect. Where is the fine line - I don't know. The problem is that our impact is limited by something (power modulator). The pond is part of a larger system, which in theory should allow it to function correctly.
Maybe similar experiments were conducted, in terms of impact is not on one culture or a garden, and in complex biological systems like a pond?
In General, an interesting topic.
в процессе размышления
Михаил_ wrote:I would start with the barrel and the volume is real and the pond is not overgrown.
if the water and one in the barrel and in the pond (extra binding), changing the properties of one manifestation - change the properties of all manifestations, if "binding" is reliable.Владимир Мокрушин wrote:don't know if one will pull Svetlitsa super? I have a pond approximately 50m3. Whether on this account the recommendations?
From the comments ASD:
not worth it until the end of the barrel empty, and pebbles what "memory" does not hurt, and then they were in the pond and in the water, in the water, LET STAND STRUCTURE (while in memory).АСД wrote:Александр79 wrote(a):
ASD wrote(a):
Александр86 wrote(a):
And how much time to the Svetlitsa super structure water carafe 1 liter ?
At least an hour, if it is done the first time. Then, if you constantly use the Parlor for restructuring water, this process is accelerated and takes about 15-20 minutes.
The second time I see this response all wanted to ask, and thereby less time in subsequent times need water to charge it? The water is drained, the carafe is charging something?
Structure carries over to the decanter, and he begins to participate in the structural transfer. Additionally, residual water from Svetlichnaya structure in the decanter is mixed with new water and transfer the structure on a new portion of water.
Not all, of the garden in the ground, in the ground to dig (optional).в процессе размышления wrote:them in the pond and in the water, in the water, LET STAND STRUCTURE (while in memory).
LET THE TRANSFER STRUCTURE! (while in memory).
You can also try most of the expert-operator interaction: initially "tied" to a garden-like surroundings, and work with him. Yes, and frequent visits to the garden product from the User (distribution structure) will have an impact. And if the "bind" to imagine every blade of grass, every kolosochok, every root in the garden and work... expert operators...в процессе размышления wrote:if the water and one in the barrel and in the pond (extra binding), changing the properties of one manifestation - change the properties of all manifestations, if "binding" reliable
Our products can be used always and everywhere. The ideology of normalization, which is inherent in the structure of the products movement is the norm, and from it never. So they can't hurt. In tumors, the use of SS and SB will contribute to abrasion on a structural distortion from the factors that cause the swelling. However, the use of our products does not negate the recommendations of doctors. If treatment is assigned, it must be fulfilled. With our products it will be more successful and faster. By the way the latest version of SS in the form of a card works well with tumors. Checked in the Krasnodar regional hospital.Воффка wrote:Hello! Tell me please, is it possible to use a parlor and a super good person with a tumor (not sure what nature)?
If the same man(with tumors) works in a factory with high levels of radiation and high-power equipment (don't know exactly, but can be much more powerful than 10kW) if he could wear a LAD and will this make sense?
Thank you!
The use of FRET also can't hurt. But what is meant by the word good? With a strong external factors may be that the power of the product on the harmonization of electromagnetic fields is not enough to turn the negative trends around. However, the product still works and slow down a possible negative trend. Perhaps the body is already strong enough to handle yourself.
In General, it should be noted that the action of our products is much broader than the fight for health. Their main quality is the increase in the dimension of information processes. Due to this change the quality of decisions and the person begins to rebuild the environment, reducing its harmful influence (such as the option of Transferring). Note that the execution of desires when using our products begin to be solved on another level.
Remember the movie about the old Man Hotabycha. There was a problem to talk on the phone. Once and the phone materialized, but to talk on it. Materialized the visibility of the phone. Its outer part. But the essence of the communication system was not played. So many people try to realize their desires. System materialization of desires exists, it is polwatta. But receive often the visibility of the implementation. Disappears deep essence. Hence the constant dissatisfaction with his condition and inability to follow his path.
Our products, increasing the dimensionality of ties of a person, creates the prerequisite for the reception of qualitatively new solutions. What is called innovative thinking. And where does the decision of the people doesn't even know. Suddenly dawned (the idea came to mind). Many this process is not even associated with the availability of our products. How would just come to me. But in order that the thought came to mind, it is necessary that the head could be perceived. To perceive the meaning that was not previously perceived due to the fact that not passed on dimensions. Ie, an opportunity otherwise to summarize available information, to go beyond stereotypes.
Therefore, one of the possible consequences of the use of the product can be transfer to another job, change of business (SB it was created), or will have solutions and suggestions about the change itself and the environment. Then the health problem will be decided on an entirely different level.
Our products do not stick wand and tool change action. To this we should strive.<
