How not to fall asleep?
к0рн
Post by к0рн » Mon May 03, 2010 18:36
When using MM fairly quickly relax and begin effects of falling asleep with short dreams. What a despicable mind slips away in these moments and when switched on - then this is literally on the physical level, as the lights in the room turned on - there seems to be a sense of fresh pictures, that was just in front of your eyes, and sounds. And then of the effects remains the only relaxation of the body, any amusing hallucinations anymore (like it happens at night, if you Wake up during a BS - you can watch the images in front of the eyes while conscious). Complacency seems right, because after the session when you decide to activate, the body comes alive, with a shiver.
Can you advise how to combine both state that consciousness is present all the time? (I hope this is something they should aspire for when using the alpha sessions MM).
Re: How not to fall asleep?
Post by Андрей Патрушев » Mon May 03, 2010 19:12
к0рн wrote:When using MM fairly quickly relax and begin effects of falling asleep with short dreams. What a despicable mind slips away in these moments and when switched on - then this is literally on the physical level, as the lights in the room turned on - there seems to be a sense of fresh pictures, that was just in front of your eyes, and sounds. And then of the effects remains the only relaxation of the body, any amusing hallucinations anymore (like it happens at night, if you Wake up during a BS - you can watch the images in front of the eyes while conscious). Complacency seems right, because after the session when you decide to activate, the body comes alive, with a shiver.
This topic has about five, probably... :?
Eat the elephant piece by piece. First three weeks don't do anything - just detachment observe the natural course of events. Let the tried and tested reliable alpha state. And then you start experimenting with it (sitting, or even standing, for example).
к0рн
Post by к0рн » Tue May 04, 2010 1:46
Andrei Patrushev
And what to do with lapses in sleep: try to make it more or less? Or this is the natural course of events? :?
