Svetlitsa eyes of the user. Equipment use and description
Дмитрий В.
Post by Дмитрий В. » Mon Apr 26, 2010 9:56
the parlor with the eyes of the user.
Mental and Svetlichny levels.
It is believed that for the solution of any problems, just connect to the "world consciousness" and a certain way to visualize the end result. These techniques are done with the help of meditation (entering into an altered state / trance), the formation of the final result in the form of phrases (affirmations or affirmatsii) or in the form of an image, image or action. These techniques are very common, such as eating – self hypnosis (subconscious focus on results). One of the hypotheses why it works is that people in a state of trance emits information and this information gets in the global energy field and come true.
Independent from each other processes can somehow be crossed and Your goal is achieved.
In General, many people know about that, as it happens, so we will not go into the process of mental communication. We can only say that any such movement toward the target is a structure (a sequence of actions that will happen), far-fetched events are also distinct structures. Any movement toward this goal forms some order, this is the structure (one of the structures). Movement You to Your goal, is nothing but the interaction of Your inner world with the Outer world, i.e., the interaction of Your structure to other structures.
Svetlichnaya level is the level of interaction between You and "global consciousness" through the Parlor. The projection of "structure your actions" on the "structure of peace", a creative process. You can draw an analogy with the mental level. In basic hypnosis is a correct statement of purpose (an affirmation) and a trance state in svitlychne level, instead of affirmations is a plan of our actions (which is a structure), and instead of TRANS, the front room, which transfers this information to other structures (in external world).
Techniques of forming structures.
If mental technique all clear where we need to establish the result in svitlychne technology, we can form a path to the result, i.e. we can form its structure the necessary actions to achieve the goal and pass it the "universe". What kind of structure?
For example. How do you solve the task of buying bread? This task is trivial for many, but I'll write how I solved in understanding one of the tech structures. So, I'll turn left, go forward, turn right, forward, left.....buy bread, unfold, right, forward, left. That's it, I'm in the same place where he was, but with a resolved task, a loaf of bread. This movement technique. To move in space we move in a certain way. At the structural level, such a movement reflects the movement between the events, because we know perfectly well that something would come true, what would have happened sudden or accidental events that our result is natural.
I.e. for the solution to some problem need to definitely move, to create movement structure and front room will transfer this structure (the higher mind), on other structures. This technique - moving in reality. You plan your way between events that are needed to achieve the goal (which would have never happened).
Another example.
We often don't see the solution to the problem, although this task is next to us, so we need to rise above himself (a Technique of pulling out his hair). We represent this movement and move the structure through the front room of the Supreme mind (to other structures) and observed. At some point do you depart from the problem aside and will see her decision or she solved.
In General, for the decision of tasks there are many techniques. Either of these techniques can be applied together with the parlor. You need to take only the structure of this technique, to reproduce, to migrate to interacting with your institution (via a chamber)
The workshops developed by Avdeev Sergey Dinovich teaches these techniques. They are derived from existing techniques of personal growth and knowledge of their world. Many of the techniques developed for a long time, Sergei Dinovitz and his wife Galina have mastered them a long time ago, 20 years ago at the seminars and very willing to teach them other time in their own workshops. Indeed, on paper many of the techniques with their seminars will not describe, but nevertheless, we can use any technique of personal growth technique or movement to the target. The main thing is to highlight the structure of this movement and pass through the Parlor to the outside world.
The effectiveness of the workshops is much higher, as the leading pass on their experience not only visually, but also emotionally, mentally. So if You are at a seminar, always behave differently in direct contact with the leading. The transfer of knowledge will be the maximum.
the Technique of pulling out his hair.
Description of equipment.
Turn up the music. Music can be calm.
Sit in the Parlor or Super Good. Imagine the problem or task, you will find yourself surrounded by this task. Then fly over this environment, grab your hair and pull up harder! Break free from your problems, give soul, body and mind to separate from this environment. Soar over a problem, high high, what would you opened another horizon, the horizon is much wider for this problem. Now you see that the problem is small, it is small to such an extent that turned into a dot and disappeared. And you opened all that was, and is, for this problem, and its solution or no problem.
If You are working with a Good Room, then this technique is continued. You soar higher and higher. You take the window and start waving. The chamber produces a spark, very bright sparks. These sparks are the seeds of a Chamber Benefit. Seeds fly and fall to the ground. You watered those seeds. Seeds germinate from these seeds trees grow up Good. Large trees. These trees blossom with flowers, very beautiful flowers. Flowers produce fruit Good. The fruits grow and ripen. You go back to him and gather fruits. These Benefits You hand out to all your friends, acquaintances, random people and not accidental. You give Good everything these Benefits returned to You in the form of a solution to your problem (Your Good).
How it works?
You have just modeled the process of solving the problem on a more General level. A similar principle (the principle of the ascension of problem) is described in many books on personal growth and management. Often, that would solve the problem, you need to look at it from the outside, we often bury it themselves, but all clearly visible.
"I think that my problem is very heavy, but, for example, Paul McCartney that would be very simple." So there is nothing easier to solve than to stand on the spot on the Floor to take a seat from the side.
Our model is the structure: the structure of action, the structure of events in space and in time. The parlor moved to this structure on the surrounding structure, i.e., is the model of our future behavior is displayed in the "global consciousness".
Start some processes, some events will occur later, some events are already being generated, to be attracted to you for solving your problem.
So we can solve any problem and very heavy. Because involved many (or maybe few) of simultaneous events.
the Technique of movement to the target.
How it works?
Sergey Dinovich gives an example from the book "Princes of amber", but this technique "pure Seeland", or rather the structure of the equipment Zeland. Zeland in their model of the world as the space of options is considering the move to the target, as the movement between variations of his life. Ie, at some point people soulevait of the way of his destiny on another path, a little different from the previous one. Constant movement in the search space significantly moves You between realities. And so eventually You no longer like before.
To achieve the goal, we need to draw this path, the path of movement in space and transmit it to the universe: building the structure and using a chamber to provide interaction with other structures.
Turn on upbeat music. Set a goal that we must achieve. Take Svetlitsa Super in hand.
Stand up, feel the music, move, and feel when to change direction, turn. You can turn sharply, smoothly, a little bit or turn around, walk straight, sideways, backwards. In General, as you wish. The main thing that you, through intuition felt the inner wind of the soul, which controls your movement and turns. This feeling is acquired at seminars, but I think You can start trying to catch these feelings inside you. Catch, fix sensations. Turn yourself and your destiny in the right direction. Move from event to event, enjoy, catch up and have emotions. It is important that there was a rhythm in the movement and the feeling of happiness. If Your gait is dull, and in life you'll go dull.
As an option, to turn the walk into a dance. Then Your traffic turns into body movement, the dance of the body (sausage). After the end of the dance You should have the feeling that this was enough to solve the problem. But if You still have the feeling that we need to move on, dance following the music.
Alternatively, you can dance in front of an audience and Parlor Goods. Imagine the audience, for example, for solving problems at work, imagine employees, boss, clients, new customers. Imagine how Your audience likes Your dance, as they at the end they clap, and You bow down and Thank (required). At the seminars we actually watched the dance of the soul. An unforgettable experience from the outside.
lastly.
Sergei Dinovich with the teacher Galina held in Krasnoyarsk for 2 days. During this time, close communication, I received a specific set of information which reveals the essence, power and action of the Parlor. It is not just information transfer was more subtle. If it was possible to hear on TV or the Internet, I absolutely wouldn't have understood. And it's not in the entanglement of technology (technology that is very simple), and the path through which Sergey Dinovich reached these developments. And the Seminar is not, some divorce, psychological pressure or oppression, seminars a lot of scientific information and a lot of mental, transferable only with the joint participation (development of the expert operator relationships; behave differently to participate, not just watch, the transfer will be 100%).
My tip, just as a way to explain to everyone how this tool can work for You. The principle is simple, take any equipment, select it from the structure and transfer this structure to the universe, and let now the event allows them to adapt to the structure, shape this technique, i.e., true to achieve Your goal.
In my opinion many people do not understand what structure, and what are they and where are :)
And if my tip goes to someone good, then I'll be happy to continue to describe the experiences I've gained and to convey information in my language.
Sincerely, Dmitry, Krasnoyarsk.<
Смелый
Re: window eyes user. Application techniques and description:
Post by Смелый » Tue Apr 27, 2010 6:47
Дмитрий В. wrote:the parlor with the eyes of the user.
Good afternoon, Dmitry!
Thank you for filing a technician working with products.
About those techniques is a lot of talk, but not everyone has the opportunity to attend seminars. Moreover, nothing complicated. On the other hand, are items like normal items. And just note what changes occur. That is, the technique of use is absolutely passive. But the situation that we are all very different, have a different level of development and condition of body, soul and spirit. And therefore, someone looking for positive change, someone negative changes, or semilivedj as if nothing happens.
So for those who do not have the opportunity to attend seminars, but wanting to use every opportunity for its development, including using the aforesaid products, it would be very nice if You continued your descriptions of techniques. Especially because everything is written in simple and accessible language. Personally, I thank you in advance.
Others too.
Good luck to everyone!
дельфин
Post by дельфин » Tue Apr 27, 2010 19:54
Смелый wrote:Svetlitsa eyes of the user.
Join us! :ay
Thank You Dmitry!
Post by Guest » Wed Apr 28, 2010 13:58
Dmitry thank you!
Дмитрий В.
Post by Дмитрий В. » Wed Apr 28, 2010 17:30
avoiding problems
For this technique requires two people who will have the Svetlitsa Super. The technique works without the parlor, because it affects the perception of the problem in the subconscious. Svetlitsa increases the effect due to the relatedness of structures You and the World, i.e. in this technique, the front room as an amplifier for your intuition.
Step 1. Remember about the problem. What item do you associate this problem?
Our brain can always associate something with something. Pop-up the Association must be sudden, without hesitation. This involved intuition.
For example, in my case, I remembered about the problem: "sick baby daughter". My Association with this problem - the "carrot".
Step 2. The second person (the operator) performs the function of diverting you from the problem. He thinks and expects from the 2 way and asks what You choose. For example "carrot pilaf or Vovka-carrot". Then You without hesitation, choose what you like, for example, say "carrot risotto", the Operator asks "plov Tajik or Georgian on horseback". Etc. Through 5-10 times, you can go further.
Repeat step 1. What associations do? Have another? Wonderful!
Repeat Step1-Step2 until then, while the Association will not be positive and yet the problem will cease to mean something to You. In the end You got? Do you like it? Give this thing yourself and members of Your former problems.
How it works?
Our life, the existing event (including problem) structure. Our brain structure. These structures interact. Every event in Your life, there is their "representation" inside of You. So You and the Association on any situation. Diverting to another Association takes you away from the above problems. It is important that the new Association was positive for You.
Good luck running! :)<
Дмитрий В.
Post by Дмитрий В. » Thu Apr 29, 2010 20:16
If anyone can, formulate other techniques for the Parlor here. All will be grateful.
MVN
Post by MVN » Fri Apr 30, 2010 7:08
:o
Дмитрий В.
Post by Дмитрий В. » Fri Apr 30, 2010 14:17
Vladimir Mokrushin
All equipment from them.
The description of "mental" and "Svetlichny" the levels are mine, as the text is a comparison of the princes of amber and Zeland (listed from my face). Everything else I tried to give 100% without any loss (including how to operate equipment).
Идущая вперед
Post by Идущая вперед » Fri Apr 30, 2010 15:49
The technique of temporary factors
Got the mirror sticker... put in the following order
1. sticker mirror 2. Svetlitsa super 3. sticker from the mirror at a distance of 5 cm under the pillow.
steel dream time dreams i.e. dreams in which there is time...
for example, today I dream I'm late for the train departure time in the ticket 19-93, but it is impossible? the cashier said that the error... was issued a ticket for 20-33
now feel the day some kind of structure...
a small mirror rear 2 stickers front parlor...worn in the bag... the results are ambiguous...
Дмитрий В.
Post by Дмитрий В. » Fri Apr 30, 2010 17:10
the Technique of the return of her true face.
On our face says all! It read who we are and what we do. So our face must be as neat and clean as were the pants with the shoes. Unfortunately, over time we lose my own face and wear someone else's mask. Mask work, mask for home, for guests, hiding from people their own "I".But there is when you honestly can not believe and accept the right decision.
How do we get the mask? We're just looking at the other, the emotion associated with the person and formed the addiction settles in the subconscious as a mask. It should be noted that this is not the face of Your Association and not to Your face.
Turn up the music politichna, under which it would be possible to dance. Sit down, take the Mirror of ISIS. Dance a face in the mirror.
Let twitch of one muscle, then another, never fear grimace, turning his head to stick out his tongue. Let all the accumulated crap will be poured and formed understanding you with You by using a cleansing beam from Your eyes.
Post by Guest » Fri Apr 30, 2010 18:03
Дмитрий В. wrote:Turn up the music politichna, under which it would be possible to dance. Sit down, take the Mirror of ISIS. Dance a face in the mirror.
"There are many old meditations which use korzenie birth. You can do this meditation in Tibet is one of the oldest traditions.
Take a large mirror. Stand in front of him naked, make faces, do funny things and watch. Just doing this and watching for 15-20-30 minutes, you will be surprised. You will begin to feel that you are separated from it. If you are separated, then how do you all do? Then the body is in your hands, it's just something in your hands. You can play with it this way and that.
Looking for new ways to make faces, do funny hand gestures, do all you can do, and it will give you a great release and you will begin to see yourself not as a body, not as a person but as a consciousness. This will help."
Osho
АСД
Post by АСД » Mon May 10, 2010 0:07
Finally managed to stay in the space and begin to answer the questions of the forum.
Many thanks to Dmitry that he took the trouble on the wording of techniques and practices that are given at seminars.
However, I want to make some adjustments in this process.
Владимир Мокрушин wrote:Dmitry V.
Everything written above is from Sergei and Galina Denovich? Or is it your vision for interacting with the system adapters?
There is clearly a mixture of both. On the one hand there is the presentation of seminar techniques, but keep in mind that Dmitry is his perception (and indeed any participant). This perception is overlaid on the presentation and this should be considered. However, the view of Dmitry on Seminary equipment us valuable and interesting. His vision gives us the opportunity to understand that we were not able to adequately convey and requires adjustment. So I will not make a critical analysis of the material presented by Dmitry. Not to say that it is something wrong or something not understood. For example, this creative recycling Dmitry seminar techniques. For what it huge gratitude.
For the author's presentation of techniques for working with products LIK I soon plan to create a separate topic.
АСД
Post by АСД » Mon May 10, 2010 0:31
Osho
This is just an example, not accurate perception of technology gives rise to inaccurate comments and incorrect analogy.
The basis of all our tech - expert - operator relationship. The same applies to all techniques for working with mirror. In this particular technique it is important not korzenie rye for release or outpouring of dope.
The main thing here is the expert's perception of the restored mirror of light coming from the eye and display it in the movement of the facial muscles. In this case, the operator begins to speak your soul that is trying through interaction with the mirror make the spiritual your body. Try to merge with your soul in this movement, to let go of all the muscles of the face to free movement. You can then feel the face movement is becoming more diverse and harmonious and turns into a real dance. And the soul begins to sing and to soar.<
АСД
Post by АСД » Mon May 10, 2010 14:14
Смелый wrote:on the other hand, are items like normal items. And just note what changes occur. That is, the technique of use is absolutely passive.
I would like to pay attention to the following paragraphs of the description to the Parlor -
Therefore, you must:
1. To Create Dream – Fantasy – Task - Goal.
2. To act for its realization. (Steps do not have to be straight. They can be indirect and absurd, but they should reflect the simulation model closer to the goal).
3. Be patient and positive moments (signs), showing movement in the right direction.
These points apply to all italiam FACE. If you try to run them, it is absolutely passive will not be able to stay.
The techniques that we give at the seminar, help in understanding, the feeling, the unfolding of these points of use of the Parlor. They help to understand how to increase their fantasy and develop goal-setting, how to build a simulation model of reality and to form a structure as to move wherever you need.
Of course for one or two workshops to deeply understand the expert-operator of the technology difficult. So for those who is not able to go to the seminar organize a seminar for yourself. You can propose the topic of the next seminar:
The practice of rejuvenating the body, soul, mind (bilateria modeling of the individual).
1.The gaming practices of interaction with them (find a way to itself in itself).
2.The development of interpersonal relationships and understanding (how to negotiate without words).
3.Practice game of attracting GRACE.
Дмитрий В.
Post by Дмитрий В. » Thu May 13, 2010 22:24
of Course, one or two seminars to deeply understand the expert-operator of the technology difficult. So for those who is not able to go to the seminar organize a seminar for yourself. You can propose the topic of the next seminar:
ie is a technology that can be remotely explored, or all of the presence of the operator(the instructor) sure?
АСД
Post by АСД » Fri May 14, 2010 0:29
In the presence of the operator are processed faster and more efficiently. For remote study will be published on the forum. Now preparing the material.
Идущая вперед
Post by Идущая вперед » Fri May 14, 2010 13:03
the strongest technique... everything else pales
http://www.koob.ru/twyman/sgibateli_lojek
МерКаБа
Post by МерКаБа » Fri May 14, 2010 15:25
Going forward if you manage to bend let :o
Дмитрий Никитин
Post by Дмитрий Никитин » Wed Sep 25, 2013 13:48
Дмитрий В. wrote:In my opinion many people do not understand what structure, and what are they and where are :)
Very interesting. Could you elaborate?
Ростислав
Post by Ростислав » Thu Nov 28, 2013 14:20
АСД wrote:In the presence of the operator are processed faster and more efficiently. For remote study will be published on the forum. Now preparing the material.
Sergei Dinovich there is progress in this direction?
Хеллен
Post by Хеллен » Mon Dec 29, 2014 2:30
Who knows, please give links to threads in the forum with more detailed descriptions of techniques for working with the parlor (from developers, not users) than specified in the instructions. Perhaps, the materials or any educational materials.
Thank you!
АСД
Post by АСД » Mon Dec 29, 2014 20:46
Хеллен wrote:Who knows, please give links to threads in the forum with more detailed descriptions of techniques for working with the parlor (from developers, not users) than specified in the instructions. Perhaps, the materials or any educational materials.
Thank you!
Equipment of this topic: viewtopic.php?f=17&t=3480
Techniques that are given at seminars, it is difficult to describe in words, as they must feel. The external similarity of the action does not disclose the essence of the technique. Most of the information on the workshop light is transmitted through the expert-operator relationship. Verbal lecture is basically a set of information flow. The main effect is realized through the expert movement of the body-soul-mind.
Хеллен
Post by Хеллен » Tue Dec 30, 2014 0:27
Thank you. I will be studying. I just needed to configure on the flow of information, as feelings and actions a lot, but want of knowledge of the theory in a popular science level.
