Svetlitsy and Meditation
АК
Post by АК » Wed Mar 17, 2010 21:01
I would like to hear the feelings/opinions/impressions/comments/assumptions about the impact of the Parlor and meditation.
Use of the Svetlitsa-With less than a month. There is a feeling that the presence of the Chamber does not take on the usual depth. Source it felt like some itching in my body... he's gone now, but there is a feeling that something does not allow you to take... Strictly speaking, I can't say that it is connected with the Parlor. There is a coincidence in time of the beginning of use, but maybe it's just a coincidence. Plan to keep the Room at meditatii, and see what happens.
Anyway, I see that some people wrote about similar feelings from a Chamber at the first time of use, when talking about sleep. With sleep I, by the way, no problem.
Of course it would be very interesting to measure the distribution of brainwave frequencies with the Room and no... to see if there was some influence.
Anyone have similar experience or any thoughts on this?
Post by Guest » Wed Mar 17, 2010 21:12
You need to remove the Window. Because it will block everything that is not the norm. For example, the opening of the third eye is not the norm. With the Parlor will not work.
But if we imagine the inept practices will make the imbalance of energy - the parlor quickly restore everything - will lead to normal.
МерКаБа
Post by МерКаБа » Wed Mar 17, 2010 21:19
After yoga, lie down in Shavasana and Ajna box SS. After 20 minutes sit down to meditate (SS is already at the breast). In my opinion, garmonizacija Agni, positively affects concentration.
АСД
Post by АСД » Thu Mar 18, 2010 3:21
Гость wrote:you need to Remove the Window. Because it will block everything that is not the norm. For example, the opening of the third eye is not the norm. With the Parlor will not work.
Wrong. The effect of normalizing the Chamber appears as a consequence restore the connectivity and integrity of the person. The opening of the third eye - the process of increasing and manifestations of the quantity and quality of links. Therefore, the chamber will facilitate the opening of the third eye.
I have one friend hold the Window in the hands of a few minutes, began to see the aura of people. It is clear that the quality of the vision she had, but manifested this quality when using a Chamber recovered some connections.
Гость wrote:But if we imagine the inept practices will make the imbalance of energy - the parlor quickly restore everything - will lead to normal.
This thesis is correct. Put another way: the chamber will contribute to practices became a skilful and correct.
Александр79
Post by Александр79 » Thu Mar 25, 2010 11:07
I Have one friend hold the Window in the hands of a few minutes, began to see the aura of people. It is clear that the quality of the vision she had, but manifested this quality when using a Chamber recovered some connections.
:( bc In the East, even in ideal conditions, not everyone is given this gift from above, and then... Magic.
Quite confused. So it creates a process of normalizing or increasing?
АСД
Post by АСД » Thu Mar 25, 2010 14:15
Александр79 wrote:quite Confused. So it creates a process of normalizing or increasing?
Svetlitsy and other products lik increase the connectivity of the system - improve the quality of structural bonds, resulting in implementing a normalization process (movement to normal). Due to the improvement of the relations reduces the influence poliobraces factors on certain systems and those systems being established (normalized). That is, if the parameters of the system were below normal, they will grow, if overweight, decrease. The farther from the norm, the brighter effects. If everything was normal, the effect is not noticeable.
АСД
Post by АСД » Thu Mar 25, 2010 14:22
Александр79 wrote: In the East, even in ideal conditions, not everyone is given this gift from above, and then... Magic.
Not only in the East. Any gift can show the person alone with his labor. Svetlitsy only help him in this not easy work to become more efficient, spend less time fighting with various interference. And it happens that the person lacks only a trifle, to get the result. Then using the front Room seems a miracle, although the main result has been prepared by the human activities.
Димитрий
Post by Димитрий » Tue Mar 30, 2010 1:19
Now, with a month practicing yoga and Svetlitsa - the difference did not seem to feel... That with it that without it...... However, with the parlor faster and sharper throws in the heat - as needed after work :) ...
Post by Guest » Tue Mar 30, 2010 2:06
I can feel the difference. Perform a few simple exercises of qigong, Lana Anatole. With the front Room felt a burst of energy after 15-20 minutes of exercise. Especially after exercise "fireball".
