Nova 100 + audiostrobe
Грея
Post by Грея » Sun Mar 14, 2010 2:55
I have a strange problem with the disks:
If you turn on the player via EXT (line-in) that sound is normal, but the points work poorly and sometimes blinks one eye, if you turn through the MIC(microphone) the volume is too high, but the glasses flicker like it should.
Question, it turns out I need to buy other headphones with a separate volume control to get a normal audiostrobe and acceptable to the ears of the volume?
(All regulators are unscrewed on a maximum and on the glasses (multicolor) is too high.
Грея
Post by Грея » Sun Mar 14, 2010 3:08
by the way, the group lilies of the valley very good audiostrobe :)
Грея
Post by Грея » Sun Mar 14, 2010 3:12
tweak the volume everywhere in the maximum, now using line-in plow points, sound did not seem distorted, but the volume is still not to stay. normal for me - almost no scintillation.
and how are you?
Эмиль
Post by Эмиль » Wed Mar 17, 2010 19:55
Грея wrote:jacked up the volume everywhere in the maximum, now using line-in plow points, sound did not seem distorted, but the volume is still not to stay. normal for me - almost no scintillation.
and how are you?
All you need is headphones with a volume control, turn the volume comfortable, correspondingly to the input MM signal strong to the glasses flickering. Something like that :)
