EEG after sitetemplate
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Fri Feb 19, 2010 9:22
having a small CNS disorders, periodically pass examinations, and now decided to see what the EEG after the alpha session. Using homemade goggles connected to usiku and BWGen, took its alpha session before the session (+ about 1-2 hours to get to the place): 16 Hz to 12 Hz - 10 minutes, then stable 12 Hz, only 30 min.
the EEG results clearly demonstrate the efficiency of technology of AVS.
results:
