RAD-2000 - eng
Generators of bio-energy (orgone)
Has thanked: 125 times
Been thanked: 263 times
RAD-2000 - eng
Post by Шалтай Балтай » Tue Feb 16, 2010 19:21
To administrators: This topic: http://www.mindmachine.ru/viewtopic.php?t=3043 seems to be quite over-loaded with chat already
My suggestion is to create a new one (ones) for each particular device in order to ask the questions to Karl
Karl
Looking here: http://www.hscti.net/c_radionics_2000.html
and here: http://www.akor.cc/manuals/english/manual.pdf
It is possible to pickup some useful information regardin the device, yet some questions remain:
1. Do I understand correctly that the "blinking lamp" reflects the frequency of the device? It looks a little bit odd, since approximately 3/4 of the scale take the frequency of approximately 3 Hertz. Why low frequencies are so highly detailed, but higher ones are not? Is this some intent? Moreover, the scale of the blinking does not seem to be liner, but the scale on the device is liner (0-100), for instance I would like to use the 7 Hertz freq, what should I do?
2. Why there are three dials for the trends? Does it mean that the device operates with three trends?
3. Looking through the manuals I can not find the detailed explanations of how to use these three dials to make a link to the trend. Would you mind to put down some comments here?
4. Is there any way to switch on the frequency meter to the device?
Thank you
Post by Шалтай Балтай » Thu Feb 18, 2010 11:21
Шалтай Балтай wrote:1. Do I understand correctly that the "blinking lamp" reflects the frequency of the device? It looks a little odd t, since approximately 3/4 of the scale take the frequency of approximately 3 Hertz
It would appear I have got the clue. The "blinking LED" does NOT reflect to the REAL frequency of the device. The frequency is set by the dial with scale 0-100 - this is the freq in Hz. Is this correct?
The one confusing part though is the "scale" of the blinking LED. It is definitely not linear, like the scale of the dial, it is rather exponential.
Post by Шалтай Балтай » Mon Mar 01, 2010 14:05
Шалтай Балтай wrote:It would appear I have got the clue. The "blinking LED" does NOT reflect to the REAL frequency of the device. The frequency is set by the dial with scale 0-100 - this is the freq in Hz. Is this correct?
No, the blinking LED is the real freq.
http://www.mindmachine.ru/viewtopic.php?p=41150#41150
Post by Шалтай Балтай » Mon Mar 01, 2010 14:32
Шалтай Балтай wrote:2. Why there are three dials for the trends? Does it mean that the device operates with three trends?
2. Well, generally speaking NO, though...
http://www.mindmachine.ru/viewtopic.php?p=41245#41245
Post by Шалтай Балтай » Mon Mar 01, 2010 14:37
Шалтай Балтай wrote:4. Is there any way to switch on the frequency meter to the device?
According to Karl that would make the devices more expensive. What he is not going to do right now.
http://www.mindmachine.ru/viewtopic.php?p=41249#41249
Практик
Post by Практик » Tue May 03, 2011 15:51
Owners РАД2000!
Please advise how you measure nastraevaemye frequency РАД2000?
Karl writes not "zamarachivatsya"(not think like a German) on them...trust your gut
Although personal feelings a couple of times tuned not NAT frequency and had to go home to cut down a device(the head was cast iron)
Actually primarily interested in the Schumann resonance
Шломо
Been thanked: 3 times
Re: RAD-2000 - eng
Post by Шломо » Mon Nov 07, 2011 22:04
[quote=Praktik]Owners РАД2000!
in music drive Angier Satori "Healing rhythm of the earth"-7,83 Hz
