Presets
Has thanked: 125 times
Been thanked: 263 times
Presets
Post by Шалтай Балтай » Mon Jan 11, 2010 19:16
Andrew
Maybe it is a big chutzpah
But do You think it would be appropriate to ask You just to put "presets" for sessions (at least Zvukovye not convinced that we need the light).
Then everyone could decompiling session by itself, but the same thing is to listen to tedious
Or is it hard to copyright?
With Respect
Saved
Post by Андрей Патрушев » Tue Jan 12, 2010 14:50
Humpty Baltay
Sorry for the stupidity :oops: and what do You mean?
Open up any session in the editor sessions and make it what you want... :?
Post by Шалтай Балтай » Tue Jan 12, 2010 17:54
Not
I want approx this format:
Code: Select all
## Please note: These tone-sets are based on data from a document
## received from an anonymous source. See "focus.txt" for details.
## The data is almost identical to the USENET-released data that
## appears in the *-a.sbg files. It is included here though
## because in a few tone-sets, extra tones were included, which may
## be interesting or useful to certain experimenters. Also
## although the frequencies were measured, again the relative
## amplitudes of the tones were not, so the results are not likely
## to be exactly the same as the Monroe Institute tapes. Also I
## believe that the Monroe Institute uses a guiding voice that
## leads the subject through the experience.
## F10 100[1.5] 200[4.0] 250[4.0] 300[4.0]
## "Brain awake, body asleep"
ts: 100+1.5/10 200+4.0/10 250+4.0/10 300+4.0/10
0:00 ts
here
everything is green and white it is written
what frequency, what bits
and what "noise" I think it's up to me :-)
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Tue Jan 12, 2010 20:01
Well, use sessions SBAGEN, they are complete enough. For sessions Fotosnimki machines have a program MindExplorer SW 3.7, it can translate to the audio format(for later mixing with other sounds and tunes) or play on the computer(with a track for audiostrobe decoder). Description of the sessions in the attached list, frequency can look to tweak in the editor... What more do you need then?
Post by Шалтай Балтай » Wed Jan 13, 2010 11:58
к-13 wrote:so, and use sessions SBAGEN, they are complete enough. For sessions Fotosnimki machines have a program MindExplorer SW 3.7, it can translate to the audio format(for later mixing with other sounds and tunes) or play on the computer(with a track for audiostrobe decoder). Description of the sessions in the attached list, frequency can look to tweak in the editor... What more do you need then?
- MindExplorer SW 3.7 is Shaw?
For sessions Potashnikova,,, - where to take the session?
- they read anything other than MindExplorer SW 3.7?
- tweak editor - MindExplorer SW 3.7??
- What else you need then? - do you want Schaub, everything was transparent, not black box.
PS
and generally at home I have Linux and Windows I are not friends
Post by Андрей Патрушев » Wed May 05, 2010 18:23
Шалтай Балтай wrote:Not
Code: Select all
0:00 ts
here
Any *.LSS can be opened in a regular text editor and get exactly the same.
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Wed Jun 09, 2010 8:47
For the sessions Fotosnimki machines have a program MindExplorer SW 3.7
And how much it imports and to replicate the session?
I compared what gives MindExplorer built-in editor and editor for InnerPuls for the same session LSS: in the same Tone sometimes written in different ways, or maybe just one and the same type of sound called differently?
