Can't keep your eyes closed. What to do?!
Ойген
Post by Ойген » Sun Dec 13, 2009 22:47
Hello!
The fact that I have one problem... I can't keep my eyes closed. Close them, trying to relax, and they (especially the left eye) on springs - open. So they did not open, I have to constantly monitor them. As a consequence, can't relax either physically or mentally (because I focused on the eyes). I say let it be as it is, i.e. let open, do not pay attention, etc. But it is EVEN WORSE! When they open, I start to get distracted, distracts me what I see, I begin to move my eyes to focus on something, etc. in Short, only worse. When I went to therapy, my doctor gave a bandage on the eye (such as give the aircraft), and it does not help much. What do I do? Every visualization, like: "My eyes are poured lead" almost does not help.
Someone else is there? Maybe it is at all, and I'm here is this problem done? What do I do if that is the problem? Bandage, close eyes, etc. is good, but what will happen when I buy a mind machine?
:cry:
Post by Андрей Патрушев » Mon Dec 14, 2009 17:27
You need sunglasses to open the eyes PVstim plus patch. Or buy machine where only those points are included: DAVID, Laxmn, Procion.
Жека3000
Post by Жека3000 » Mon Dec 14, 2009 18:25
Eugen
But You also sleep with open eyes? :shock:
Ойген
Post by Ойген » Mon Dec 14, 2009 23:45
2 Жека3000:
I sleep because I antipsychotics siteroot, so late in the evening I get tired and sleep well (and before sleeping was a big problem, but it is not so much due to the fact that the eye is "not closed", but because of other reasons). And so either fall to one side, so one eye on the pillow or bed of the person bent at the elbow. To sleep during the day I can very rarely, when very tired, or have a long lie for this. So :( ...
2 Andrei Patrushev:
Thank you very much, but...
glasses open eyes PVstim plus headband
What patch? And how it can be combined with the glasses, even if they are for open eyes? Anyway, what kind of relaxation with your eyes open?
MM while not planning to buy (talk to doctor), but I'm interested in is just "Photosonix".
In General, what is it? This may be the result of some neurotic disorders? Such a thing happens in people, or it's just me being "original"?
Post by Андрей Патрушев » Tue Dec 15, 2009 15:49
Ойген wrote:What patch? And how it can be combined with the glasses, even if they are for open eyes? Anyway, what kind of relaxation with your eyes open?
Plain black wide headband. How hard could see myself in a bandage, and glasses blink.
You can stand with your eyes open have a great otredaktirovat (see, for example, the "Key" of hasaya Magomedovicha Aliyev), and even lying, as they say, God himself commanded. There are still ganzfeld effect...
Most likely, in the childhood there was some kind of psychological trauma - it is possible to work with the Guide (but probably will not be easy...). I met a girl with a similar problem...
Ойген
Post by Ойген » Tue Dec 15, 2009 17:42
how hard could see myself in a bandage, and glasses blink.
But those bandages are specially made so that they did not miss the light! Or do You mean that the bandage should be worn over the glasses?
And you can somehow on the glasses Standard to put the weak brightness and watch them with open eyes (and over the glasses to put on a bandage or put on the face of some t-shirt)? Just if I enjoy MM, it is likely the cheapest - the Luma 10 with standard glasses for another glasses money just is not enough.
Post by Андрей Патрушев » Tue Dec 15, 2009 17:53
Yes, knechno - over points.
You can, for example, take the clear plastic strip (cut out from a large bottle of water) and carefully zamarinovat it with fine emery cloth... And glasses so the light does not flow almost.
Ойген
Post by Ойген » Tue Dec 15, 2009 18:24
you Can, for example, take the clear plastic tape
But if this tape can wear them over your glasses, and under your glasses? Then the tape will be silent to transmit light simultaneously with the "effect of closed-eye" - ie this matte tape I replace the skin on the eyes. Is this possible? :)
Жека3000
Post by Жека3000 » Tue Dec 15, 2009 18:30
Ойген wrote:But if this tape can wear them over your glasses, and under your glasses?
So on it goes! Matte tape under the glasses.
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Tue Dec 15, 2009 18:37
most likely,the inability to close the eye,it is too large, the brightness of the diodes in the glasses.maybe just reduce it?I have here ,sometimes,during long sessions of MM the perception of brightness changes quite dramatically.maybe a bright light in the room interferes
Post by Андрей Патрушев » Tue Dec 15, 2009 19:00
Yes, of course! :) But above I wrote about the black patch. :?
Post by Андрей Патрушев » Tue Dec 15, 2009 19:01
старец Вольдемар wrote:most likely,the inability to close the eye,it is too large, the brightness of the diodes in the glasses.maybe just reduce it?I have here ,sometimes,during long sessions of MM the perception of brightness changes quite dramatically.maybe a bright light in the room interferes
No, he and machine doesn't. This is for life so...
Post by Нетрезвый Сурдопереводчик » Wed Dec 16, 2009 18:49
Андрей Патрушев wrote: No, he and machine doesn't. This is for life so...
I have the 2nd evening in a row when listening to "Healing ",somewhere in the 2/3 of the total disk kind of like the brightness in the glasses increases significantly.the day before yesterday it was really bad,I wanted to open my eyes.until I "woke up" and did not diminish the brightness :(
