the question drives to Andrei Patrushev
What is audiostrobe drives and impressions about them
ангелов
Post by ангелов » Sat Oct 17, 2009 13:58
hi Andrew read the description to disk “Healing on the Magic river” is written there - the Healing music is superimposed on the sounds of nature, contains modulated high frequency sounds, plus exactly matched (with a unique modern electronic equipment) binaural beats
so the question arose what kind of unique equipment you used to record this disc will announce please
Re: question on wheels to Andrei Patrushev
Post by Андрей Патрушев » Sat Oct 17, 2009 17:04
ангелов wrote:hi Andrew read the description to disk “Healing on the Magic river” is written there - the Healing music is superimposed on the sounds of nature, contains modulated high frequency sounds, plus exactly matched (with a unique modern electronic equipment) binaural beats
Hello.
This LIRA-100 http://www.nmbt.web.ur.ru/index.html
Ири-на
Post by Ири-на » Sat Dec 12, 2009 21:53
Hello, Andrey! I have a question: my daughter is 12 years old, her mental retardation, is it possible to use your CDs as a Supplement to treatment and which disks would you positively?
Post by Андрей Патрушев » Sun Dec 13, 2009 12:09
Ири-на wrote:hi Andrea! I have a question: my daughter is 12 years old, her mental retardation, is it possible to use your CDs as a Supplement to treatment and which disks would you positively?
Yes, it is the 2nd track Star Wanderer (15 minutes) through the headphones at low volume, better in the morning.
Ири-на
Post by Ири-на » Tue Dec 15, 2009 8:38
Thanks for the advice, and drive "Ultramesh" you can use for it?
Post by Андрей Патрушев » Tue Dec 15, 2009 14:58
Ири-на wrote:Thanks for the advice, and drive "Ultramesh" you can use for it?
You - the last song (this is the same as 2 on the Star Wanderer).
Post by Guest » Tue Dec 15, 2009 20:56
THANK you!
Post by Guest » Tue Dec 22, 2009 20:21
Andrew,please advise which ROM is better to buy for the 11th grade student: "Ultramesh" or "Star traveler" given the fact that we have to pass the exam to continue uhabov University?
Post by Андрей Патрушев » Wed Dec 23, 2009 13:15
Anonymous wrote:Andrew,please tell me which drive is better to buy for the 11th grade student: "Ultramesh" or "Star traveler" given the fact that we have to pass the exam to continue uhabov University?
In this case it is better Ultramesh.
Сергей Ш
Post by Сергей Ш » Mon Mar 01, 2010 2:09
Good day Andrew!!! Is it possible after 21 days of listening to MM, just to listen to the disk Endorphins? In General, you need to take a break between courses of different discs?
Thank you!
Юджин
Post by Юджин » Sun Nov 21, 2010 2:57
Please tell me iDisk Endorphins how much time is* my ends on the 27 th minute..... And then when I heard that supposedly there's sort of 2 parts already...... or am I confusing you? rather someone utt said that there is a difference when listening to the first half of the disk, and when the second.
And Massage of the brain - the 74 minute... what is too much... If a certain part to stop listening to - nothing bad will happen?
Post by Андрей Патрушев » Sun Nov 21, 2010 12:33
Сергей Ш wrote:Hello Andrey!!! Is it possible after 21 days of listening to MM, just to listen to the disk Endorphins? In General, you need to take a break between courses of different discs?
Thank you!
Hello!
Can without interruption.
Post by Андрей Патрушев » Sun Nov 21, 2010 12:36
Юджин wrote:please Tell me iDisk Endorphins how much time is* my ends on the 27 th minute..... And then when I heard that supposedly there's sort of 2 parts already...... or am I confusing you? rather someone utt said that there is a difference when listening to the first half of the disk, and when the second.
Endorphins and Massages Brain for 45 minutes. Endorphins can at any minute to stop and Massage of the Brain - the whole program.
72 minutes is a Guide. :)
Мирта
Post by Мирта » Sun Nov 21, 2010 16:58
Question to A. Patrushev:
On the cover of the CD "solar wind" is the image of the star of vectors indicating the interaction of circulating chakra energy. Where was received, if not a secret, this information? And why is the organization of the tracks ( each in three parts, two of which correspond to the adjacent ( higher and lower chakras ) does not account for this scheme? And then, why was given this scheme and how You can advise her to use? :)
Post by Андрей Патрушев » Sun Nov 21, 2010 17:12
Мирта wrote:a Question to A. Patrushev:
On the cover is the image of the star of vectors indicating the interaction of circulating chakra energy. Where was received, if not a secret, this information? And why is the organization of the tracks ( each in three parts, two of which correspond to the adjacent ( higher and lower chakras ) does not account for this scheme? And then, why was given this scheme and how You can advise her to use? :)
The scheme has been obtained by means of an inner illumination :) after studying multiple sources on the subject, and matching the experimental data, using diagnostic complex Лира100.
It was assumed that any user may program the player at their own discretion. If the track was not in a row, then this operation would require some transcendent mental effort. :?
Post by Андрей Патрушев » Sun Nov 21, 2010 17:14
Мирта wrote:each of the three parts, two of which correspond to the adjacent ( higher and lower chakras)
You are wrong. Read the description. :?
Мирта
Post by Мирта » Mon Nov 22, 2010 5:07
Well, Yes, forgotten, I admit. But the essence of the issue from the relocation of the terms does not change. "Each chakra begins with pure tones, corresponding chakra, which is gradually layered tones of the two conjugate chakras (creating a chord), and ends again with clean tone."
Whether the track structure is proposed to cover the scheme, and prevents its implementation. What is meant by the associated chakras for the second chakra is the seventh and the sixth ( under the scheme ) or the first and third ( follow tracks on the disc ). If You expected a schema, then is it not preferable to look ...the sequence 2;6;1... instead ...2-(6+2+7)-2;6-(1+6+2)-6;1-(5-1-6)-1...( in brackets "accord"). IMHO the oil oil out. :cry:
Do You think with the activation of some chakras to start the cycle, if you listen to all nine tracks? :)
Post by Андрей Патрушев » Mon Nov 22, 2010 15:32
Last edited by Андрей Патрушев on Mon Nov 22, 2010 17:02, edited 4 times in total.
Post by Андрей Патрушев » Mon Nov 22, 2010 15:34
Myrtle
Please read the description carefully and study the picture. :?
Мирта
Post by Мирта » Mon Nov 22, 2010 19:06
OK, thank you. As seen in the picture ( and this is the fourth I've ever seen the option ( on the disk, the cover, tweaked one attentive validating + this ) should start with Agni. It is a pity that the rest of the question You want to answer. If You do not understand what the numbers mean in my previous message - it's just plain marking chakras ( 1st-Muladhara, 2nd-svadhisthana, etc.).
Post by Андрей Патрушев » Mon Nov 22, 2010 19:45
Мирта wrote:it is a Pity that the rest of the question You want to answer.
"It is a pity that we failed to hear the chief of transport shop"... :?
Мирта
Post by Мирта » Sat Nov 27, 2010 5:01
Than You were guided, when defining Agni the first place? :oops:
Post by Андрей Патрушев » Sat Nov 27, 2010 23:31
Мирта wrote:What was the reason, determining to Agni the first place? :oops:
In a number of sources of meditation on the chakras should start and finish Agnoy that, in principle, is not without a certain logic, as ajna is "responsible" in some way, for self-control...
Королевский Тигр
Post by Королевский Тигр » Sat Mar 12, 2011 5:03
One more question. Bought a set of discs "Smart music" and bonus received "Healing on the magic river." On the box, which goes to disk, it is written that copying files from disk is not recommended, as it will worsen the properties of the program. I would like to know if it is actually "bad", because for me it is much easier to throw all the files from the disks on the mini-player or PDA, and listen to them wherever I please. And the disk may be scratched. So maybe you can still copy the audio files to removable media without compromising the quality of the effect? Thanks in advance for the answer.
Post by Андрей Патрушев » Sat Mar 12, 2011 10:06
king Tiger
It is possible in WAV-format.
