Dear!
I am the owner of a not very nice illness...
Namely, not long ago, the neurologist diagnosed with:
"neurogenic bladder in early autonomic dysfunction"
At the moment the reason is not arc not found.
While being treated medically.
Do you think maybe the window or the device is based on a similar concept to help it?
As far as I understand the theme of the instrument adjust(harmonize) the integrity of data transfer between the organs of the entire body?
A neurogenic bladder is nothing short of a violation of the relationship of the bladder with other organs...
The room and the therapeutic effects from it!!!(give examples)
Re: the room and the therapeutic effects from it!!!(give examples)
I doubt someone will give you guarantees your case. As far as, you know, that all have different effects because of different characteristics of the organism and the environment finding.Новик wrote:Dear!
Describe your example. After birth, I was diagnosed with prolapse of the kidneys. Often, there was a recurrence of inflammation, which continued for many years. Now use the Svetlitsa - Super. Just beginning discomfort in the bladder, localizou SS in this area and drink large quantities of structured on SS of water (1 liter per hour, at least three liters). If you had recovered for a week, now per day, and often, the inflammatory process stops immediately. It does not exclude various herbs.
Александр86
Александр86
and here's another
http://vodalechit.narod.ru/
Novik
use everything you have if you have enough money ...
that Yes work ...
visit all the doctors nevropatologa , surgeon , physician , urologist , venereologist , psychotherapist , that sometimes the doctor of the same discipline do not know the reasons for another and comprehensively advise will not be able to see the pathology to another doctor too ...
so go ahead and good luck ...
that Yes work ...
Идущая вперед
this is just the main problem of modern Orthodox medicine.... not to treat the body in a complex and to treat the individual body thus injuring all the rest... if you drink antibiotics for throat disease put the entire intestine... and it would not recognize a person in addition to body escho and energy systems...Гость wrote:visit all the doctors nevropatologa , surgeon , physician , urologist , venereologist , psychotherapist , that sometimes the doctor of the same discipline do not know the reasons for another and comprehensively advise will not be able to see the pathology to another doctor too ...
the inertia and conservatism of the Orthodox sometimes comes to the ridiculous... sometimes up to a medical error....
