phobia
Сергей808
phobia
Post by Сергей808 » Fri Sep 25, 2009 7:09
How about treating social phobia and depression a minimal set of Luma 10+ glasses standard?Will that be enough?Just doubt the effectiveness for such problems,and then Patrick Swayze died from pancreatic cancer...If you can help it such ridiculous money.Just the wind so much money invested that I can't believe in anything.Please reply
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Wed Sep 30, 2009 19:17
Сергей808
Post by Сергей808 » Thu Oct 01, 2009 14:23
Thank you so alfaria better to buy?
Вадим А.
Post by Вадим А. » Sun Oct 04, 2009 19:40
Сергей808
Do not get fooled. It all network marketing. And mindaliny is just "placebo-toys"
Been thanked: 182 times
Post by Андрей Кабанков » Sun Oct 04, 2009 19:45
Вадим А. wrote:Сергей808
We are not engaged in network marketing and are not a member of any network.And talking about MM,that it's a placebo , given that they are on the market for over 10 years and are manufactured by many companies, at least naive.
Новик
Post by Новик » Sun Oct 04, 2009 21:15
But I still think phobias complexes cured with the help of the machine not really :?
The machine can simply remove symptoms(anxiety, irritability, etc) for a while.
If necessary to cure it to the appropriate specialist should :wink:
Post by Guest » Sun Oct 04, 2009 21:44
Personally used Transair-02 ( apparatus for TES-therapy ), subjective abruptly Alfaria ( appearance ( headband with 4 electrodes not sickly, the developer... ) for about a year in the hope to reduce the level of anxiety and depressive symptoms-effect "0"
Post by Андрей Патрушев » Mon Oct 05, 2009 10:14
A good specialist, of course, is not a hindrance... But MM is not a pill, but the training, so "the machine doesn't just remove the symptoms" and teaches the brain alternative behavior... 8)
Идущая вперед
Post by Идущая вперед » Mon Oct 05, 2009 10:44
but still there is a magical disk Explorer... it changes the perception of the world and adjusts to a more positive reality...
1. we need to understand why it suddenly had social phobia (fear of society) is usually in the immediate vicinity there is a person who mocks and belittles... or some deeply entrenched children's complexes... i.e. to find out the cause and work through it... at least with the aid of a rainbow-arc for example... or other prog...
2. depression develops when a person does not have GOALS... i.e. man lives AIMLESSLY... consider why OPTIMISTS salt of the EARTH and pessimists sluggishly lagging behind and get in the way... if in life you set goals and are implementing them every day for drop - brick by brick closer to execution - and you have something to do every day and every minute of the day and you start to realize that 24 hours is too little.... :D :D :D tady depression finally to you not even close... and if you go tell her nah... let go... let it pile expensive stamps...
3. imagine the mind looks like your depressed... well, there is the face or image of what... (very good in the commercials portrayed Microvote... now we know what it is aunt over 60 fat and ugly or toon green) well, imagine that your roads diverge - or escho can think of a bunch of different images of the outputs raspadenie with depression on different components - and to practice every day over and over until you fall behind :wiz :wiz :wiz
Сергей808
Post by Сергей808 » Wed Oct 07, 2009 14:28
Thank you all for your answers,use the rainbow and all the forces no matter what.
Димитрий
Post by Димитрий » Thu Oct 08, 2009 12:49
...Their heels kobakov let down...
Why do we always think, "here read this book, buy MM-Altario (or anything else), go two times to yoga-karate-Wushu-qigong-massage and all! Become rich-smart-kind-wise-strong..."? And may have and to work on yourself USING these techniques? Or two times a week or a month... After all, Champions aren't made in two workouts with the Champions... using the MM feel the threshold of entering the meditative state, right now quite well at it too (have felt like this. The yoga 4th year almost two years with meditation was - no - VD prevented :? ) MM use 2 years - no complaints, but only a statement - it works. And not just there works, and works in a particular situation, whether it's meditation, just relaxing or studying...IMHO... And phobias famously said Vadim Zaporozhtsev (about the Maya) here somewhere http://www.happyoga.narod.ru/3_audio_yo ... anjali.htm - sorry I do not remember what the lecture...
Сергей808
Post by Сергей808 » Fri Oct 09, 2009 16:59
Well, here, as with antidepressants:drink Until I stopped and again was blown away.Because I want some small miracle.To have the strength to work on yourself.Talk about lazy R burner,motivates for 2 days then again nothing +guilt from the fact that I am degradant and lazy animal.Again, like the wheels will have to eat
Димитрий
Post by Димитрий » Mon Oct 12, 2009 15:46
Sergey, of course I'm with You in that I agree, I have 15-16 hours of wakefulness a day - laziness visits andak times 15-16 :( ... however, when people really corners to the wall, then laziness and speech can not be (i.e. when he realizes that this day may be the last and only due to the fact that he was too lazy so-and-so to do, Oh, how...) We ourselves are the blacksmiths of his future az There is nothing worse than illusions that we can imagine. And for example, when I beneath one's dignity to do something really help breathing exercises (komelkov a lot of different)...
Джим
Post by Джим » Tue Oct 13, 2009 0:38
Сергей808 wrote:Well here as with antidepressants:drink Until I stopped and again was blown away.Because I want some small miracle.To have the strength to work on yourself.Talk about lazy R burner,motivates for 2 days then again nothing +guilt from the fact that I am degradant and lazy animal.Again, like the wheels will have to eat
Deflated/inflated... All the popular drugs, can be positioned as antidepressants -- the essence symptomatic, ie, if, (I assume that You their Doctor prescribed) for two days does not help (sometimes, they say, it happens) -- not only not to treat, but will try to make Your condition chronic, and even worse-will provoke You on an "as-just-something-bad-need-is-eat" -- without regard to the objectivity of the testimony.
Elah, burns ... well, a little push, try, learn (1-2 hours before [the alleged] sleep) to relax. To begin with. Well, lying down or sitting, eyes closed, achieve a representation of how heat is distributed in Your body (on a couple of exercises will be enough heat spreads through my mind, just for starters -- just on the face). Further-everywhere. You can (and should) use by any Association, for example, with the warmth of steam from the open pans, the heat from washing, etc.). Yes, from the first class depression You probably can't do it -- But. Don't set yourself this goal. "I want to learn to relax, and my criterion of accomplishment would be the feeling of heat" (And even -- "I don't have more important things to do than this"). All. This is the beginning.
MM and/or all sorts of disks (alpha/relaxation) to start can be a very serious backup.
Well, by the way, if the depression is strong, I'd begun to connect the "physical therapy" not earlier than after the first success "without backups" -- on the other hand, if You are able to write in an Internet forum-it is likely that "increased suggestibility" You not only won't hurt and will help.
And forget about the guilt, etc. -- to solve the task "learn to relax" and "to control the process [of relaxation]" to start with, held for the pouring of the heat in the body. Let it be, to begin with, just until You specifically "work" - when completely will begin to happen (I assure you that it is not so long to wait) -- You'll understand how and what You need next (and what is not necessary, too).
(Oh yeah, I of course idealize the picture of -- but, honestly, the way it is, ideally. In needele-with the zigzags, but if you try, even the zigzags You need to eat only food :o and not spare parts for vehicles :) ).<
Идущая вперед
Post by Идущая вперед » Tue Oct 13, 2009 13:08
and I want to tell you about the magic tea.... in Russia since ancient times have consumed kipany tea.... fireweed... apart from the fact that it is very useful - it gives energy escho he has such a great feature - it soothes raschitanno-disorderly neuri... this tea can help the body to significantly improve and to correct the pile health....
Димитрий
Post by Димитрий » Wed Oct 14, 2009 12:45
Going forward A Lope of time(days-years) and at the Nada drinking? :o
Идущая вперед
Post by Идущая вперед » Wed Oct 14, 2009 13:05
Yes, our русск0-Slavic ancestors drank it constantly before the revolution... then I went to the expansion of Sino-Indian teas... but they are not as useful as someone very bad...if it is at elevated pressure for example drinking coffee and black tea... or Vice versa... hypotension-reduced blood pressure drinking green...
and it is increasingly reduced...
and kipany tea-Vedic...I get to drink it in the morning... and the leaves I chew... they are delicious :D :D :D (a FAQ Tama in these bags Greenfield ponapihano - tryndets full, and Ahmad with bergamot - finally eau de Cologne pour :) :) :)
