TEO(EFT)
Миф
TEO(EFT)
Post by Миф » Fri Sep 04, 2009 14:37
Hello) I would Like to discuss this technique. Online found 2 manuals on it - http://www.koob.ru/craig/eft
http://www.prorabotka.ru/eft.html.
Tried it on, it seems to work) anger removes all great, just at times) But with physical nedomoganie not yet good at, like headaches.
Who does this technique? How are the results? As you have the process of "liberation"? For example when I start rattling point that you feel as you begin to breathe deeper and easier. A fracture occurs usually when the songs begin to consider.
Another question on technique, I don't quite understand. The reminder phrase is necessary to speak in sequence 9 or just when tapping points?
Re: FS(EFT)
Post by Андрей Патрушев » Fri Sep 04, 2009 16:06
Миф wrote:Hello) I would Like to discuss this technique. Online found 2 manuals on it - http://www.koob.ru/craig/eft
Hi!
I like this technique - I have a couple years of use on myself and on people :). Works and emotions and somatike.
The last question is not understood. :?
Миф
Post by Миф » Fri Sep 04, 2009 16:45
1) Utochnyu question)
There is the process as I understand it this happens:
1. Installation
Repeat 3 times for example even if I'm angry I deeply and completely accept, etc.
2. Click on the point
3. 9 do actions(open, close our eyes, sing a song, etc.)
4. Again, click on point
Here guidelines are recommended during the procedure to say the "reminder phrase"(as she takayazhe and approval). Well, ie pushing some points and sentence "though I'm angry I deeply and completely accept." So the question is whether proiznesti(keep in mind or even kaknau) the phrase in step 3 or only when performing 2 and 4.
Well, another question to the heap)
2) let's say I now feel some feelings, let it be anger, annoyance, Abid. But in a word it is problematic whether it is possible instead to insert "'the feeling". Ie the installation will succeed "even though I get this feeling I deeply and completely accept." There are also some feelings that I don't even know what to call it:) is it Possible in this case is simply to focus on them, so the attention and use "that feeling"?
Post by Андрей Патрушев » Fri Sep 04, 2009 16:49
Yeah, I understand. :?
1. Only 2 and 4, and 4 modificeres: "despite the remnants of this feeling..."
2. Frankly, I never called (how do I know - what is this feeling actually :)) simply said - "this feeling"... :?
