"Smart led" will soothe your nerves after work
Наблюдающий
Post by Наблюдающий » Thu Jul 16, 2009 16:02
Interesting article on www.strf.ru.
"Smart led" will soothe your nerves after work http://www.strf.ru/science.aspx?Catalog ... d_no=21822
"The principle of its operation is based on human exposure through both natural and artificial lighting and sound effects, including widely studied technologies in the world of so-called "intelligent light""
"As the light sources will be subject to special multichip led emitters, which can "generate" almost any color available to the human eye and light of any intensity. Can be "programmed" sunrise, sunset, twilight. "
Interestingly, this is MM, or up to her quite a bit?
Maybe will see something the size of a iPhone and with all the necessary range of functions and features?
Post by Guest » Thu Jul 16, 2009 16:15
No one bothers to connect to the iPhone points to the headphone output and the sound to transmit via bluetooth to the headphones relevant. Will remain soft to write. Processor 600 MHz is not a problem to do all sorts of special effects like "random" screams of birds or the noise of the forest in Mind WorkStation. And cost such a mind-machine console would cost at least 3 times cheaper. And probably the demand will be higher during these 3 times.
Instead of expensive iPhones you can use paketi. B/y shnye now 2 million cost. Processors from 300 MHz is enough to get a same InnerPulse "break".
Don't know what mm. ru hinder to be honest...
Post by Dimas » Mon Jul 20, 2009 12:44
And no one hinders. :wink: The fact of the matter is that the whole point in the sessions, and x have to be able to make more.
