Affirmation with MM
Артемчик
Affirmation with MM
Post by Артемчик » Mon May 25, 2009 12:51
Hello!
Who combines affirmations with MM? Acquired inner pulse which is better the program to run for affirmation and stimulation visualization?
And another question for the advanced on affirmations, if the words to say to yourself it is clear that we should start with the words I, and if you record on the player and listen, no need to write the affirmation with YOU.
It's logical when you talk about yourself you say I,I,I. And when just listening with the word I think it's someone next says to himself.
Share your experience thread who.
Re: Affirmation with MM
Post by Андрей Патрушев » Mon May 25, 2009 13:05
Артемчик wrote:Hello!
The Program L03. The most interesting results are obtained if you write each affirmation in the sequence: YOU, WE, I.
Good luck!
Артемчик
Post by Артемчик » Tue May 26, 2009 5:33
Thank you for your answer, I do not quite understand, for example, an affirmation about confidence recorded for bugging like this?:
You every minute you become more confident
You with every hour become more confident
(Later)
We every day become more confident
Every year we become more confident
(Finish)
I am the most confident person on Earth
I am absolutely confident
Or how that on another? Please tell us, because it's important
Асель
Post by Асель » Tue May 26, 2009 11:48
I'm on the top of financial success
Post by Андрей Патрушев » Wed May 27, 2009 20:35
Артемчик wrote:Thank you for your answer, I do not quite understand, for example, an affirmation about confidence recorded for bugging like this?:
(Later)
(Finish)
Something like this, only time frame is necessary to keep... :?
On the other hand, these statements have a hidden meaning that You are not a confident person, so useless. Please read carefully the beginning of this topic http://www.mindmachine.ru/viewtopic.php?t=577&start=0
and my articles about affirmations and affirmatsii.
Post by Андрей Патрушев » Wed May 27, 2009 20:37
Асель wrote:I'm on the top of financial success
It's a metaphor that there is nothing good in itself does not carry... In the best case, You pull onto the roof of some Bank... :?
Post by Guest » Thu May 28, 2009 11:57
And you can just take affirmations and affirmatsii of the files of the Rainbow record of them on the player and listen?
Or, if You, ie, Andrei Patrushev is not difficult, write here some short affirmation about confidence, not very long, I would have taken it.
Thank you, for earlier.
Идущая вперед
Post by Идущая вперед » Thu May 28, 2009 13:29
Артемчик wrote:Who combines affirmations with MM? Acquired inner pulse which is better the program to run for affirmation and stimulation visualization?
for a visualization session called
in order to reach the subconscious I use a very cool app (assuming that you see the stereo image) if you do not see then its use does not make sense and need to practice to see the image three dimensional
http://youryoga.org/med/sssp-nlsk_program.htm
affirmations to prescribe better method Sedona then they are better absorbed
take the confidence.... first you dig in yourself..
and where did this uncertainty .... what was the count? ask yourself different questions about uncertainty... external factors... what factor influenced by the well, etc.
further, when questions are received
cut prog...
there are 7 affirmations you can register your name
let's take the same confidence
1. I EVERY DAY BECOME MORE CONFIDENT
2. I CAN BE MORE CONFIDENT
3.I ALLOW MYSELF TO BE SURE
4.I KNOW HOW TO BE CONFIDENT
5. I DO IT ALL TO BECOME CONFIDENT
6.I HAVE CONFIDENCE IN MYSELF
7.I BELIEVE IN MYSELF and MY STRENGTH!!!! uuurrrraaaaa!!!!!
8.NAME
so first I use this app quit Smoking now for a month don't smoke
wait, I work with this program to become slender... the subconscious makes aggggg to run in the morning and picks up at 6 a.m. and said run :D :D :D :D I go nuts :) :) :)
therefore it is always necessary before working with affirmations to think about it - and it you want for the sake of orderliness to get up at 6 am and run or sleep until 7-30
and in the Sedona they say that the brow have to get rid of emotions and desires (invented yoga 5000 years ago) and tady confidence itself arguing with terrible force....<
Просто_идущий
Post by Просто_идущий » Thu May 28, 2009 14:53
first, I use this app quit Smoking now for a month don't smoke
Hello, Going forward!
And you can about Smoking as much detail as about confidence.
No it does not lag behind and this fatal passion from me.
Thank you!
Post by Guest » Fri May 29, 2009 4:14
Гость wrote:And you can just take affirmations and affirmatsii of the files of the Rainbow record of them on the player and listen?
It was Artem, I do not understand why a "Guest" went :?
Артемчик
Post by Артемчик » Fri May 29, 2009 5:17
Thank you going forward!
Always try, even now with Rainbow do, then this app will try.
And MM can be combined with this prog, I mean the sound from MM and video from the tab? Or, for example,your sound play, as in the Rainbow.
Идущая вперед
Post by Идущая вперед » Fri May 29, 2009 13:39
Артемчик wrote:AND MM can be combined with this prog, I mean the sound from MM and video from the tab? Or, for example,your sound play, as in the Rainbow.
I combine THIS PROG drives a HYPNOTIC TRANCE or MUSIC FOR hypnosis AND self-HYPNOSIS... I THINK THAT IS the best OPTION :ay :ay :ay
Идущая вперед
Post by Идущая вперед » Fri May 29, 2009 13:44
Просто_идущий wrote:And you can about Smoking as much detail as about confidence.
I really want to quit Smoking
I can stop Smoking
I allow myself to quit Smoking
I know how to quit Smoking
I'm doing everything to fast to quit Smoking
I'm quickly becoming a non-person (non-Smoking model I don't like that word
I am completely free from bad habits - Smoking
well, that's where it is :) :) :)
Post by Dimas » Fri May 29, 2009 13:47
Prostii
Try to speak it: Why I'm happy to lead a healthy lifestyle?
Просто_идущий
Post by Просто_идущий » Fri May 29, 2009 15:20
Going forward
Thank you
Post by Dimas » Fri May 29, 2009 15:28
Prostii
Not at all!By the way, Going forward and I quit Smoking...but she for a fortnight (sort of) experience clean...more and I'm counting from may 10...First 4 days a bit difficult,but then...!!!!CLASS!!!!The food is maybe delicious,smell, internal sensations...the main thing is not to stand on the position of the victim,saying You have deprived of something good.On the contrary, every moment when You remember about the cigarette, rejoice that You are freed to enjoy his new status!If that,write, work together to recover much easier. If there is interest in this issue, we can arrange a separate topic here and help each other, support and share experiences on the issue of refusal of SMOKING.
Данила Мастер
Post by Данила Мастер » Fri Jul 03, 2009 18:15
Hi guys, can someone tell me on what basis the disk Sviyash "I am a Money magnet"?
The disc belongs with the category of affirmations, but I have not heard any affirmations....
Post by Guest » Fri Jul 03, 2009 23:25
Данила Мастер wrote:hi guys, can someone tell me on what basis the disk Sviyash "I am a Money magnet"?
In psychology there is a term "self-fulfilling prophecy." From questionable based on it (most likely "explanation" is not quite the same exercise from Wave to them. R. Monroe) and running. Maybe 10 rubles for the year and will attract... :D And, most likely, no. :)
Well, (for my taste) - I wouldn't start with this CD... :)
