Room, Mirror
Кирилл Коротков
Room, Mirror
Post by Кирилл Коротков » Wed May 20, 2009 16:01
interested in the product Miracle mirror recently saw a similar mirror in the company of Aires, the Matrix
interestingly, in addition to the GDV device, what other measuring devices can be tested, and, most importantly, will the result (positive of course)
АСД
Re: Drawing Rooms, Mirror
Post by АСД » Sat Jun 06, 2009 0:47
Кирилл Коротков wrote:interested in the product Miracle mirror recently saw a similar mirror in the company of Aires, the Matrix
System integrator-time MIRROR (hereinafter SIVS) design LIK solves the problem of the reversal of the temporary structural distortion of the person. The device is fundamentally different from the mirror Aires as the active tasks, and ideology. Structural distortion of time of life is not limited only to this man's life. There are tribal line stretches far into the past and into the future. Time warp is on this line often does not give the person the opportunity samorealizatsii, as this is offset by the feeling of journey and the person tries to realize a variety of external programs and models offered to him by the social Strigoi. CIVS restores connectivity time-lines, allowing him to successfully implement his true desires.
As You rightly pointed out, you can see the influence of SIVS on the person using the GDV. But the GDV-method only allows to see the increase in brightness and density of the glow, not allowing to highlight some features of human interaction with the Mirror.
In the Krasnodar medical University under the guidance of Professor Savina investigated the effect of SIVS per person with a special Biological Test System (BTS) the principal components of which were provided with an aqueous solution of amino acids (tyrosine, tryptophan, leucine, glutamic acid, series, valine, arginine, lysine) in the structuring agents (aqueous solution of sulfate magnesia). Following are some excerpts from the research report of this issledovanii.
"On the basis of research conducted by us earlier, we established that amino acids have the ability to perceive information wave radiation and to transmit it in the form of convertible structures (monograph Savina L. V.)
The study involved 10 volunteers aged 23 to 70 years, which was used SIVS.
As a control, used data from 10 healthy individuals of the same age.
The research was carried out as follows:
recorded information and energy field (IEP) of CIVS, simple mirror device without modules, as well as in the dynamics examined the IEP of the person that have applied CIVS. Zones, which took the readings were:
- frontal lobes (the center of the forehead) of the brain - the area of the projection intensity of the course of metabolic processes in the brain;
center of the parietal area of the human head — the area of the projection of the pineal gland, the center of the regulation of biorhythms of the body;
- thyroid gland - the organ that regulates all types of metabolism, produces hormones - thyroxine, triiodothyronine, which ensure the permeability of cell membranes, the metabolic cells;
- the pulse - area monitoring "mirror" the speed of metabolic processes;
biological and calendar age.
In addition, we observed the condition of the skin, by registering radiation from the skin of the cheeks.
The impact of SIVS evaluated at the membrane and cellular levels. The collection of information was carried out by applying 0.02 ml of BTS on a glass substrate, which was placed in the study area of the projection of one or another regional field, kept it for 2-3 minutes, dried under controlled conditions and studied using a polarizing microscope with a quartz compensator.
Volunteers worked with SIVS according to the following scheme: the first three days they looked at the mirror surface for 15 minutes three times a day, then for 8 minutes three times a day for three days.
The following week - for 5 minutes three times a day and the rest of the time daily 1 minute, three times a day.
The total number of calendar days to 45 days. The measurements were made according to the following scheme: initial data, then every 3 days for one week later - one week, i.e., each volunteer was under the study of 8 times.
Some of the results:
1.Was the stimulating effect of CIVS on the functional activity of the pineal gland.
Practical relevance: the time-phased application of CIVS enhances immune system function, nervous and endocrine. New opportunities of using the model of SIVS in geriatric practice (the fight against premature aging), for the prevention of seasonal exacerbations of chronic diseases, to prevent antioxidant stress, in preventing the occurrence of tumor diseases.
2.We have developed a method of testing the age of the person, which includes entire a glass plate coated BTS in the area of the projection of the pulse (rapid testing age. // Consciousness and physical reality.-2006.-№5.- P. 45 - 50). We have developed a scale of "decades" on the calendar age of a person. According to information received, the first decade corresponds to a fine-grained mosaic structure of the BPS, then, with the increase of age in the field of view appear larger elements.
Present data on the identification of the phenomenon of transformation of the structural elements of the BPS in the determination of biological age in individuals that have applied CIVS.
The source data
The biological age of volunteers amounted to an average of 50.2 ±5.7 years, in the field of view present a single large structural elements with a diameter of 35 to 50 µm
Summary:
Found a clear effect of "rejuvenation," reducing the biological age. Discovered the emergence of "young" structural elements 40 -45 day from the beginning of the experiment. Biological age corresponds to a scale 38, 5 ±6.2 years, with a statistical significance of p=0.02. These results indicate that the change of the course of metabolic processes, identified the phenomenon of their acceleration.
Professor KSMU,
Doctor of medical Sciences L. V. Savina"
The findings of this study suggests that Mirror the FACE successfully cope with the task of the reversal of the temporary structures of man.<
Post by Guest » Tue Jun 23, 2009 20:57
Hello. Looked supplied with the mirror - so there are two of them, or what ? Why ? And then, they are as small as they look then? If someone already bought, share impressions, pliz.
Post by Андрей Кабанков » Tue Jun 23, 2009 21:18
Has anyone sekkala on the reverse side paste these two structures at a distance of 15 cm,look not in them,and in the mirror.
Владимир Никонов 2
Post by Владимир Никонов 2 » Wed Jun 24, 2009 13:03
On http://www.mindmachine.ru/infokonstrukt ... /about.htm
you will find the story of the author about the mirror.
АСД
Post by АСД » Fri Jun 26, 2009 12:59
Андрей Кабанков wrote:has anyone sekkala On the reverse side paste these two structures at a distance of 15 cm,look not in them,and in the mirror.
Labels will be placed vertically along the Central axis of the mirror approximately at the level of the person. The thickness of the mirror glass needs to be 4-5 mm.
Рептилоид
Post by Рептилоид » Sun Jul 05, 2009 6:56
Advertising on www.infoconstructor.ru it is written that with the help of the Mirror just to fix past events. In the example shown unsuccessful jump into the water. Type, you can go back and jump well. The author even understands what the nonsense says? Why then not remove ago Beslan, Karabakh, Auschwitz? Even the slightest change in the past will lead to unpredictable changes in the future. Read Bradbury, though?
Рептилоид
Post by Рептилоид » Sun Jul 05, 2009 7:10
Here this nonsense, is also leaked:
With the help of a Mirror you can walk into the past, into the future for the purpose of modifying and implementing the event plan is the key which opens a new crucial events that affect the life of the object.
The mirror, in this case, plays the role of an amplifier of the "strength" that increases the capabilities of the object.
To the materialization of the desired included driver time of fulfillment that is necessary to generate plasma of love, fantasy of obviousness and intent of the object. You must create and save the desired state by acting on time and not subject to the control of time.
Imagine the athlete who stands on the tower preparing to jump into the water. A short run-up, flight... but due to a small technical error, the body enters the water at the wrong angle, causing the fountain of splashes and waves diverging from the crash site. It would be great to turn back time to fix the bug and get a high score. All of the spray flock, the waves run back to the place of falling water, “giving birth from the sea foam”, throws the slim body right to the tower and the surface of the water instantly freezes in the pristine surface.
Alas! Although this picture is quite common to see in films or on TV, turned in time during the process and is contrary to our everyday experience and the second law of thermodynamics (which States that the system tends towards maximum entropy).
A similar picture is nevertheless quite real. This is possible thanks to the remarkable property of reversibility of the stroke of light rays, which is known in optics for a very long time.
This is for those who class 3 the parish done? Unscrew the back of Hitler, Stalin, Putin.
Весельчак У
Post by Весельчак У » Mon Jul 06, 2009 22:49
IMHO, the Mirror is just techniczny variant of the technique of recapitulation. Cm. K. Castaneda. And "remove" anyone other than themselves is impossible. And himself only in terms of the return lost energy. It's clear that nobody will allow to release the device that would literally changed the past. Although impossible in this nothing. And no, because in addition to entropy there is fortunately negentropy. That's great uncles, the kind that built HAARP and similar "toys". And for people of small toys. Cause changes only within the sandbox.
АСД
Post by АСД » Wed Jul 08, 2009 2:32
Рептилоид wrote:advertising on www.infoconstructor.ru it is written that with the help of the Mirror just to fix past events. In the example shown unsuccessful jump into the water. Type, you can go back and jump well. The author even understands what the nonsense says? Why then not remove ago Beslan, Karabakh, Auschwitz? Even the slightest change in the past will lead to unpredictable changes in the future. Read Bradbury, though?
Lyrics jump into the water, it's a quote from the work of academician Zeldovich, dedicated to the reversal of the wave front. And it says it is not a substance but a wave function. Like the movie Vice versa. This allows you to change the structural component, which may apply in a temporary space and begins to affect the possible trajectory of future implementation. While Bradbury wrote about something else.
АСД
Post by АСД » Wed Jul 08, 2009 2:53
Рептилоид wrote:Here the nonsense turns out, is also leaked:
Hitler, Stalin, etc. - their influence leads to distortions and breaks in time relations, the ancestral lines. Hence, the future corresponding is obtained. The mirror allows you to recover communication not cancelling Hitler. And implement the other scenarios of the future, where people have new opportunities to realize their creative potential. Then there is what is called the support of the ancestors, as a structural link with the generic databases.
Рептилоид
Post by Рептилоид » Fri Jul 10, 2009 18:14
A person to resurrect in this way can? What you write bravely I associate with hornbeam.
Рептилоид
Post by Рептилоид » Fri Jul 10, 2009 18:19
By the way, he really raised. Only the machine it was powerful. The schema downloaded from the Noosphere or from akasha, whatever. It was crystal module, like the Atlanteans. Now he, of course, the FSB. Terminology you one to one with Grigory Petrovich and theory too. So I thought maybe your Mirror able to resurrect?
Рептилоид
Post by Рептилоид » Fri Jul 10, 2009 18:22
For example, in an alternative event is to jump over? Where eternal youth, everything is alive and everything is OK? Why not? Such options is in Infinity? There is, anything.
АСД
Post by АСД » Sat Jul 11, 2009 0:01
Рептилоид wrote:by the Way, he really raised. Only the machine it was powerful. The schema downloaded from the Noosphere or from akasha, whatever. It was crystal module, like the Atlanteans. Now he, of course, the FSB. Terminology you one to one with Grigory Petrovich and theory too. So I thought maybe your Mirror able to resurrect?
Judging by Your remarks in the terminology and theory of Grigory Petrovich You do not understand, and in our too. Therefore, one of akasha in the head. And about the resurrection, so it you every week, at the end. So use the technology... :ay
АСД
Post by АСД » Sat Jul 11, 2009 0:10
Рептилоид wrote:for example, in an alternative event is to jump over? Where eternal youth, everything is alive and everything is OK? Why not? Such options is in Infinity? There is, anything.
So jump.
Post by Guest » Sat Jul 11, 2009 0:30
Reptilians you are confusing written and really manifest ......
also written on the fence :(
Рептилоид
Post by Рептилоид » Sat Jul 11, 2009 13:33
In the Teachings of Grabovoi really nobody understands, including himself. He, like ass broadcast information, that's all. Exactly the same thing happened to Tesla. He could not explain why there are drawings of devices.
The prison was nothing - crystalline Module, hornbeam nothing at all. Perhaps his former friends from the FSB, slightly corrected his once gifted the brain using Psychotronics, only slightly different from the one sold here.
go ahead.
You can jump until you're blue. The question is. Using your Mirrors can reto jump?
Do not understand do not understand? Yes lectures, ZPO read in the MOE contain all the things I said to you, and much more. Only these people did incredible things, without even realizing. And your Mirror what can you do but make sure that hair has diminished, and wrinkles increased?
About the resurrection question passes? Still. One is already planted, now all the so-called "scientists of the new wave of" scared sick on this topic. Don't want to compromise the name of Grabovoi?
Want to say what is written ASD has nothing to do with reality? It looks like it. An ordinary mirror and the placebo effect.
АСД
Post by АСД » Sat Jul 11, 2009 22:09
Рептилоид wrote: You can jump until you're blue. The question is. Using your Mirrors can reto jump?
That is possible with our mirror to do, read the description and conclusion of Krasnodar honey. Institute. I have already referred to this report.
Kind of a sore subject for you - a resurrection.
Resurrection we do not do. The doctrine of Grabovogo have no relationship.
Post by Guest » Sun Jul 12, 2009 0:25
Reptilians
of course ... otherwise, as the incredible effects would have long ago used ... even in the Kremlin this is not !!!!!!!! rooted and the Kremlin pill a common battery :lol: :lol: :lol:
and famous people with money ... for example Mikhalkov a lot of money on miracles translated and even personal healer with herbs ,amulets, and all methods for 2,000 years China has caused and probably a bunch of parlor bought ... but no ... it hurts ... like a simple worker, atheist :?
АСД
Post by АСД » Sun Jul 12, 2009 3:51
Anonymous wrote:Reptilians
Confuse You all. Interfere in one pile and the Kremlin pills and herbs and Chinese techniques and atheists with the Kremlin. Trying to compare incomparable things you probably want to cast a shadow on our products. Therefore, there is no reasoning, no logic and no sense. Then why write? To show his ignorance in modern technology? You did it. :D
We do not make medical products and do not offer a panacea. There are specific devices with specific properties and the tasks to solve. But to understand how they work, you should at least something to read.
Рептилоид
Post by Рептилоид » Mon Jul 13, 2009 8:25
You have a very vulgar is energetic with elements of NLP. I showed on the example of "loose shots". The typical "rubbing".
She is sick not for me, but for Russia. FSB of intrigue compromised really powerful reservoir of ancient Knowledge. And the devices of immense power, made on the basis of the Atlantic technology confiscated. So I hope, suddenly one hornbeam possessed the secrets of the Atlanteans. Look at the forums... One bullshit. Committee members would never allow Russia to have appeared on the market something serious. They cling for their Reich. Anything, the crisis is still piled up this Power.
Post by Guest » Mon Jul 13, 2009 13:53
ASD
You Confuse everything. Interfere in one pile and the Kremlin pills and herbs and Chinese techniques and atheists with the Kremlin. Trying to compare incomparable things you probably want to cast a shadow on our products. Therefore, there is no reasoning, no logic and no sense. Then why write? To show his ignorance in modern technology? You did it. Very Happy
I'm not confused ...
I'm just looking for indirect evidence of the presence of those effects about which you write !!!
I don't want to compromise your product but rather want to buy a real product ...
and your arguments of type a buy and unconvincing and check your facts like Reno unsubstantiated ... what you post in the form of experiences are interesting only to specialists ... te YOU are RELUCTANT to give clear evidence to men ...
so I'm trying to find an indirect expression through the examples of their lives concerned with their health moneybags !!!!!!!!!!
and why is there no logic ? logic is a chain of cause and effect ... if you have them invisible in my post that is negative to you ....
I'm certainly not comparing the pill Kremlin and your chamber I can only compare the arguments and declared the result with real ... te looking for where open argument and where zavualirovannost and zabaltyvanie pseudo-scientific phrases to CHECK which can only be a highly skilled spets not consumer uses it for example liistory Fomenko , liefst tihoplav , hornbeam , sellers zirconium bracelets - all who praised and promoted ill and get sick from what he alleged they were treated... and here is a good facts for potrebitelya no !!!!!!!!!!!!!
t e for them to learn them (their essence) and the words I tell you anything to prove and will show the certificate and the alleged experiments (why ostensibly because checking their correctness can only be special well or the presence or absence of applicants in the world practice)
PS I would have understood if you wrote about all the known phenomena and has already proven axioms ... and you write about the WONDERS of science but as something in passing like what stuck like and know little about these your effects and eminent scientists do not like about the miracle of Grabovoi and tihoplav, etc...........<
Post by Андрей Кабанков » Mon Jul 13, 2009 14:24
Science is only a model of the world.A lot of models.Most are familiar with the models that describe our daily existence,in a very narrow range of parameters.Models describing the micro world will seem to you just "Miracles".
If existing phenomenon fails to describe the usual models,this does not mean that the phenomenon cannot be.
Post by Guest » Mon Jul 13, 2009 19:20
Андрей Кабанков wrote:Guest
thanks ... but if translated into plain language you are saying that THERE is a PHENOMENON which can NOT EXPLAIN the SCIENCE ? And I am supposed to repeat what they say there is no science of explanation and the fact no ?
YOU're CATEGORICALLY not about that !!!!!!! I say that to sum up your research database needs then when there is the phenomenon of and you are just challenging pseudoscientific theories explain what is easily explained in the usual model of the world and most IMPORTANTLY IT CAN be REPEATED .... your hypothesis is how to describe the reason for the bad mood radiation aliens ... also a lot to prove and prove and then to offer a special shield from erchonia the size of a coin and the mood will immediately go up .... escheb such fears saved az
