There is no effect - what to do?
Денис.Д
Post by Денис.Д » Mon Apr 20, 2009 16:29
Acquired a machine InnerPulse ,worked with her for over a month. Listened to various session-relaxation, visualization or meditation, but there is no effect from this, either during the session or after.
What can you recommend to proper ?
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Mon Apr 20, 2009 16:39
I mean, there is no effect? Even relaxed I can't?
In obdata in the first month it is recommended that only the alpha session to listen to. Everything else can wait. Venigred do not need to interfere.
Денис.Д
Post by Денис.Д » Mon Apr 20, 2009 16:49
Логик wrote:I mean, there is no effect? Even relaxed I can't?
EXACTLY!!! Can't relax before , during, and after the session there is no difference in sensation
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Mon Apr 20, 2009 20:18
Then start with disk A. Patrushev: Conductor or Healing! Through the machine - trample for sure!
Post by Dimas » Tue Apr 21, 2009 0:45
Denis.D
The first 21 days you need to listen to ONLY the alpha program (session on relaxation) for the adaptation of the brain. not more hours in the day.
андрейtver
Post by андрейtver » Tue Apr 21, 2009 18:33
I just do greedy for information was after this machine,or this planetary transition is to blame don't know,it flooded me Institutskii lectures and all kind of information to listen read watch etc
Post by Dimas » Tue Apr 21, 2009 19:58
андрейtver
The same garbage! :ay
Post by Андрей Патрушев » Wed Apr 22, 2009 8:19
The most common reason - the overcontrol (gradually goes away with regular practice), the second - too bright (sometimes but much less often, too loud sound).
Аркониэль
Post by Аркониэль » Sat May 02, 2009 11:41
Андрей Патрушев wrote: The most common reason - the overcontrol (gradually goes away with regular practice), the second - too bright (sometimes but much less often, too loud sound).
And all the same?
There is idiosyncrasy technology. What factors besides violations of the rules of use can cause immunity to the effects?
Post by Андрей Патрушев » Sun May 03, 2009 14:26
And all the same?
Perhaps, only the absence of organs of sight and hearing... :?
Read the following topics:
http://www.mindmachine.ru/viewtopic.php?t=867
http://www.mindmachine.ru/viewtopic.php?t=327
http://www.mindmachine.ru/viewtopic.php?t=94&start=0
http://www.mindmachine.ru/viewtopic.php?t=878
Димитрий
Post by Димитрий » Fri May 08, 2009 12:46
I have a friend about 2 months. yuzal MM - comes in and says "cheto does not insert...", ask - "what do you expect? What do you think you should achieve with MM, but at least you tried to read the forum where to start and all that, but he - and what for, tyzh said - turn on, adjust the light, sound and forward. In General he honored carefully the forum, the proposed literature." Days later, four rings - "e, work, a paragraph of what that! :lol: "From these parts... Maybe something You missed, write where you started, how it was prepared (tolkuse noise-the light-the neighbors-baby-mother-in-law-wife, etc.). :) 8) What from it expect? And on the forum of voimsusele once wrote - MM is not caletka some, IMHO, and the way your assistant or something... In the dumbbell, barbell... 8) That muscle appeared - it is necessary to swing... az
