Began with a question to Andrey Patrushev about the effect of the anesthesia from MM, I decided to create a separate topic. In the book "Discovering anew technology ABC" is written about using MM as a means of anesthesia. Decided to try MM as a means to do the splits. The result of experimentation: although MM probably provides a little help in the stretching - relaxing, calms the mind, while away the time for a gradual rastarivanie of full anaesthesia cannot be considered. The verdict is negative.
Used session r2 Enerplus in 19 minutes (not listening) ColorTrack glasses blue.
Mind machines and anesthesia
Идущая вперед
- Been thanked: 6 times
I start every morning with the energy of the session or disc endorphins... and then stretch... first trainer... then weights... then the ball is so big it pull back... but not together...
to enter in the ISS I need a static stillness... a state of complete relaxation.... but not the dynamics but after the ISS when the whole body relaxed very well stretch all ....
body...
going forward
going forward
Re: Mind machines and anesthesia
Mindmachine - not a pill.Пророк wrote:was Andrei Patrushev about the effect of the anesthesia from MM, I decided to create a separate topic. In the book "Discovering anew technology ABC" is written about using MM as a means of anesthesia. Decided to try MM as a means to do the splits. The result of experimentation: although MM probably provides a little help in the stretching - relaxing, calms the mind, while away the time for a gradual rastarivanie of full anaesthesia cannot be considered. The verdict is negative.
